<<  1    2  >>
Author: Subject: MS self build kits
lotusmadandy
posted on 3/6/11 at 06:45 AM Reply With Quote
Ok then, my mind is made up.
I am already using edis with MJ to do the sparks so an MS1 with
v3 board will do for me.
My order is going in today for my squirt,i should have it this time next week.
I will sell the MJ and carbs to help fund the squirt.
Lookout for my forthcoming questions
And once again the LCB massive has
come up trumps.. I thank you all
[Edited on 3/6/11 by lotusmadandy]
Jimbob
posted on 3/6/11 at 07:37 AM Reply With Quote
I got one delivered last week from diyautotune.com
MS2 V3 full kit unassembled, stimulator kit and a tuning cable
came to £285.94 all in with £43.55 import VAT & £13.50 parcel farce clearance fee
lotusmadandy
posted on 3/6/11 at 07:38 AM Reply With Quote
Well peep's,
I have just ordered my MS1 with a v3 board,it came in at
£147 including shipping and insurance.
I should have it by thursday or friday next week.
Thanks again for all the advice and help.
matt_gsxr
posted on 3/6/11 at 07:58 AM Reply With Quote
Originally posted by Lars
how much bigger are tables in MS2?
I thought it was MS3 that had larger tables.
But if MS2 has larger tables I may upgrade to that soon, as it will help with mapping
Lars,
Mine (Ms2 running MsExtra) has 16x16 but that is one benefit. It is a bit of everything.
The sync on the trigger wheels is logged.
You don't have to use easytherm or reflash to change sensor values
Clever acceleration enrichment methods (AEA)
Faster serial link
You can log the individual teeth on the trigger wheel
Ramped up time for staged injection
C-code so you can easily change things
Boost control, more idle control
Many more options and tables and toys.
I like MS1 and it does a good job, but Ms2 is nicer still.
I can send you a msq and you can see the additional flexibility (if you want), just e-mail me.
Matt
coyoteboy
posted on 3/6/11 at 09:21 AM Reply With Quote
Indeed I work with MS2 at work and it's much more pleasant to deal with than MS1, but MS1 does the trick nicely, you just need to know how to massage it round your problems
r1_pete
posted on 3/6/11 at 10:26 AM Reply With Quote
I'm researching this at the mo, am I right in my findings that MS1 will not control sparks via EDIS without internal mods and MSEXTRA code??
I've just been reading through the msextra section on EDIS, but need to test my understanding....
lotusmadandy
posted on 3/6/11 at 11:42 AM Reply With Quote
The way i understand it is,that it controls pip and saw the same as a megajolt
but will not trigger the coil pack.
This will be just fine for me as i am using edis for the ignition.
ed1801
posted on 3/6/11 at 12:18 PM Reply With Quote
Mine is running EDIS in the way you describe. I had to build in a couple of internal mods as detailed in the manual. It was basically miss out some bits and add in a couple of wires. Works a treat.
I am running the low res msextra code as I have peak and hold injectors. Don't know why you wouldn't use the MSextra code anyway?
lotusmadandy
posted on 3/6/11 at 02:06 PM Reply With Quote
I have just had an email conversation with Russ at DIY Autotune.
He tells me that the MS1 with a v3 main board will take full control of both
ignition and fueling straight out of the box. Well once its put together.
So complete tuning can be done all at the same connection point.
As already said it can be upgraded to ms2 spec,with the addition of a sister board
for £80.
<<  1    2  >>
