James
posted on 6/8/04 at 05:16 PM |
Mick,
Nothing to stop you using Megasquirt with a Zetec. It's cheap compared with other aftermarket systems.
There's a few posts about it here. Rob Lane is using it on his 4Age and CairB has done one for his Pinto in practice to soon fit it to a
Duratec.
It's about £100 for the kit plus a bit more for the stimulator which apparently is worth having.
It's the route I'll use for my next engine (prob. 2 years away) which will be either Duratec or S2000.
HTH,
James
[Edited on 6/8/04 by James]
James
posted on 6/8/04 at 05:28 PM |
quote: Originally posted by bob
I'm baffled
I always thought you looked like the inside of my sump!
Anyway, re-reading the posts I just realised you were talking about ignition- I read it at first as injection!
I was trying to say you could move the injection manifold round to the side (as opposed to on top of the engine) like Mark Allanson has done so nicely
for his Pinto. He's written a .pdf document as a guide- it's on here in a couple of places.
Anyway, I'm gonna go home now as it's too late for work on a sunny Friday!
James
phelpsa
posted on 6/8/04 at 05:45 PM |
There are two types of 1600 zetec, the E and the S. The S is the one in the Fiesta, focus and fusion, the E is the one in the escort and mondeo. The E
is the same basic design as the 1.8 and 2.0, the S is completely different. Hope I got it all the right way round.
Adam
bob
posted on 6/8/04 at 06:54 PM |
I'm baffled
James
James
I'm still baffled,you didnt re-read the posts far enough.
Its zetec and ignition for it,the pinto will get binned.
zilspeed
posted on 6/8/04 at 08:41 PM |
quote: Originally posted by cdp
Hi zilspeed,
I notice you have used a 1600 zetec along with an inlet manifold from Burton power. Which one was it please?
thanks
Carl
Sorry mate, can't quite remember. I think there was only the one available back then. I figure that a manifold to suit a bigger engine would
definitely work with the smaller one as if the ports were any different then they would most likely be smaller on the 1600.
Mix
posted on 7/8/04 at 08:23 AM |
Dave
2.0l sump is 215mm at it's deepest, (mating surface to base at sump plug,externally).
It may also be worth mentioning that the Escort and Mondeo sumps have the oil reservoirs at opposite ends, (Mondeo one is at the gearbox end).
Cheers Mick
dave1888
posted on 7/8/04 at 09:08 AM |
I fitted the bellhousing to the engine last night and the bellhousing sits 10mm lower than the sump. Surely i dont have to shorten the sump if the
bellhousing is lower than the sump?
Steve Hnz
posted on 7/8/04 at 02:24 PM |
Wyn, magic photos, beautifully clear & very neat job, any others you care to post will be drooled over!
Adam, Would I be right in thinking that a rear sump is a no no, oil starvation under braking & that sort of thing I imagine? so I`ll have to look
out for an Escort zetec, definietly harder to find than a Mondeo one out here.
lsdweb
posted on 8/8/04 at 09:16 AM |
Many thanks Steve
I'll post more photos when I get a chance. The most impressive bit (which I didn't think of!) is the clutch pullrod mechanism - it does
away with the hassle of trying to get a cable to fit and bend in a tight space: it's really smooth as well. I'll post photos soon.
Wyn
zilspeed
posted on 9/8/04 at 06:03 PM |
Another pic of a Zetec in a Se7en. This time running stock injection and in a Caterham SV
dave1888
posted on 9/8/04 at 07:16 PM |
Top quality photo zilspeed where did you get from
zilspeed
posted on 9/8/04 at 08:16 PM |
Right click the pic and check the properties - I've linked direct to the pic. A bit naughty, but it keeps 'our' bandwidth down.
It's an american caterham specialist that I stumbled upon
dave1888
posted on 9/8/04 at 10:10 PM |
Found the site then realised it was american looks good. I have stored the picture as it's the same plenum as the one i intend to use
Big Stu
posted on 10/8/04 at 07:14 AM |
There are two problems you will need to over come if you want to use this injection. The steering as mentioned and also the diagonal bar that goes
from the footwell to the front of the chassis. What injection would you use for this?
bob
posted on 10/8/04 at 07:52 AM |
Looks like a home made job but will overcome the steering link prob if you have one,also i've seen other builders cut the tube out that runs
across a 1/3 of the engine bay.
zilspeed
posted on 10/8/04 at 08:20 AM |
Re : OE plastic manifold.
I was obviously having one of my 'slow' moments - the fact that it was a LHD car completely escaped me. This fabricated manifold looks
much more like the thing for a RHD narrow bodied car. It also has the air intake at the front which has to be better.
bob
posted on 10/8/04 at 10:10 AM |
Yep air intake looks ok,i was also posted this pic too.
zilspeed
posted on 10/8/04 at 01:10 PM |
That looks like a distributor hanging off the N/S of the block
bob
posted on 10/8/04 at 02:55 PM |
Actually i'm not too sure its a zetec,i was looking at the plenium at first.
dave1888
posted on 10/8/04 at 03:00 PM |
Don't think it is a zetec oil filler is in wrong place?
zilspeed
posted on 10/8/04 at 03:33 PM |
That's a Toyota 4A-GE
Just studied the position / angle of the dizzy and the shape of the cam cover.
A friend has one in his sprint car running on carbs and a ford dizzy for simple sparks. Goes like a whippet.
bob
posted on 24/8/04 at 05:54 PM |
still gathering info here on zetec and box combo's price effect and all that.
Anyone else with any input much appreciated ?
dave1888
posted on 24/8/04 at 05:57 PM |
Clutch setup tried to get a friction plate today cant find anyone who sells the parts individually only kits. Mind you i got a price for friction and
thrust bearing £47 or 3 in 1 kit £44.99
RobC
posted on 15/3/05 at 12:58 PM |
eariler on there was mention of a QH CCT133 release bearing?? what capri is this off?
big_wasa
posted on 15/3/05 at 08:37 PM |
Im most intrested in this post aswell, as im already collecting the bits for the job..
I have already
1993 2ltr zetec 75 k
R1 motorcycle carbs (quad 40mm)
Bogg brothers have started on the manifold today
1.8 l escort flywheel
1.8 l escort sump+pick up
mt75 gearbox from 2ltr Dohc..
I plan on using a good zetec clutch,as for the thrust bearing it will depend on how much cash ive got on weather it will be a home made spacer on a
new trust bearing or the westfield one....
Question?????
Does the sump need cutting ? I understand that a cut and shut sump is about 165mm and will cost another £200 but for that Ill only gain 15mm or so
?Can I not just put a bulge in the bonnet like the avon?And raise the engine just enough to get the ground clearance?
Question 2????????
What about ignition?? I was going to have ago at megajolt ,but I can not find the info I need to get the bits in this country?? can anybody help??Or
if I can find the cash how good/user friendly is the emerald setup??
I would also like to no other peoples experiance on using the zetec.....
