<<  1    2  >>
New Topic New Reply
Author: Subject: I'm new and need help!!
stressy
posted on 5/8/04 at 11:39 AM Reply With Quote
Good find
Phelpsa's find above is a good option or the bellhousing to use at it places the clutch release arm nice and high so as not to use up drivers foot space.
ned
posted on 5/8/04 at 12:49 PM Reply With Quote
beware, i think that caterham use the xr4i type 9 as mentioned in the description which have a longer input shaft and are quite rare now..
Ned.
beware, I've got yellow skin
stressy
posted on 5/8/04 at 01:00 PM Reply With Quote
They do indeed use an xr4i box which does have a longer input shaft.
They use it because it has a better set of ratios and has the reputaton for being a little more robust. Its still not good ratios for a k series really tho.
You can buy bellhousings elsewhere if you want to use a type 9 5speed from an inline 4 engine. (really bad gear ratios)
There are also sometimes issues with the diamter of the input shaft.....
Chris
<<  1    2  >>
New Topic New Reply
