<<  1    2  >>
New Topic New Reply
Author: Subject: My Winter Upgrade 2011
bobinspain
posted on 7/1/12 at 07:27 PM Reply With Quote
You MUST have wings on the back. (Bat shaped of course).
fullpint
posted on 7/1/12 at 07:35 PM Reply With Quote
Dash is looking well tasty Neil.. Look forward to seeing more of your handy work..
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
Nash
posted on 9/1/12 at 08:20 PM Reply With Quote
Quick update, tonight I replaced the chome panhead setscrews with black ones to blend in better with the CF vinyl. I ran the fuel lines and wired in the digidash, cut the Ali composite and shaped the tunnel sides. Although I still need to final shape the edging and put the edging trim on but I can't until the CF vinyl arrived from the bay later this week. Finally I fitted the zorst back having repacked it and swagged the joints a little to ake it a better fit.
Hopefully tomorrow evening I will wire in the rest of the guages in and then I can bolt the dash in place and start finishing off the long list of little assembly jobs.
cheers........ Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
bobinspain
posted on 9/1/12 at 09:03 PM Reply With Quote
Neil,
Your note by your username put me in mind of a joke by the US comedian Steven Wright.
Whenever I pick up someone hitchhiking, I always like to wait for a few minutes before I say anything to them. Then I say, "put your seatbelt on----I want to try something I saw in a cartoon, but I'm pretty sure I can pull it off." :
Nash
posted on 10/1/12 at 09:34 PM Reply With Quote
So this is my job list to get the car reassembled and finished.
To Do:
1. Suspension assy (Done)
2. Cycle wings (Done)
3. Wheels (Done)
4. Exhaust Repack (Done)
5. Exhaust primaries on (Done)
6. Exhaust Silencer on (Done)
7. Dash wrap and fit (Mostly Done)
a. Speedo bracket
b. Paint bulbs red
c. Resize ali plate (Done)
d. Rubber edge (Done)
e. Spray rings black
f. Carbon wrap (Done)
8. Steering column refit
9. Steering cowling fit
10. Wiring (partially done)
11. Fit front bonnet lugs
12. Make tunnel sides and wrap (Partially Done)
13. Fit cargo net to tunnel side
14. Trim vinyl edges underneath
15. Trim wheel arch edge
16. Fit Tom Tom Bracket
17. Fit number plates
18. Refit carpets
19. Refit Roll Cage
20. Refit Scuttle and front plate
21. Repeater lights
22. Geometry set up (corner weights, ride height and geometry setup booked for 19th Jan)
23. Refit Seats
24. Make & fit Radiator duct
25. Refit front indicators
26. Run flow and return fuel lines (Done)
like I said a lot of little reassembly jobs I reckon a nother couple of days work over the next two weeks (work and limited access to the car is holding me up now)
.....................Neil
Nash
posted on 16/1/12 at 09:33 PM Reply With Quote
Right I am all but finished the Upgrade. There is some tidying up to do and some wiring (oil pressure and temp guages) and I have it booked for Corner weighting, ride height an geometry set up on Thursday but the car is in a "presentable" state now so I have updated the thred here:
http://southernkitcars.com/forum/viewtopic.php?f=7&t=2177&p=32703#p32703
but here are a couple of photos of the car:
Thanks for looking.
Nash
posted on 20/1/12 at 11:49 PM Reply With Quote
Hoping to take the car out and shake it down tomorrow!!?!?!? Bound to rain. But how will I know if the colours run
............Neil
fullpint
posted on 21/1/12 at 06:28 AM Reply With Quote
Forecast for the south is windy with may be the odd shower!! I reckon you will be fine.. As for the paint running?? Just take it thru a car wash
Nash
posted on 28/1/12 at 12:24 AM Reply With Quote
So to all intents and purposes my winter upgrade is finished. I have a couple of tweeks to do but nothing major (set up digi dash etc) so here are a couple of photos of the car before and after.
Thanks for looking.
before
After:
Original (how I bought it:
IVA ready
Before:
After:
Cheers......... Neil
welderman
posted on 28/1/12 at 12:41 AM Reply With Quote
Done a good job there. Massive transformation well done
Thank's, Joe
I don't stalk people
<<  1    2  >>
New Topic New Reply
