<<  1    2  >>
Author: Subject: delete first speed busa
SJL
posted on 5/2/12 at 10:32 PM Reply With Quote
http://ecuhacking.activeboard.com/f392256/suzuki-gsx1300r-hayabusa/
Remap the stock ECU and then reflash it back after the test
Lots of info on that site, I built the interface and have successfully flashed my ECU
[Edited on 5/2/12 by SJL]
veld
posted on 6/2/12 at 07:57 AM Reply With Quote
Thanks for the link...
It's very interesting, you keep the stock Ecu and change the functions ?
SJL
posted on 6/2/12 at 02:00 PM Reply With Quote
Yes that's it basically no need for power commanders etc.
I would register on there and get their advice they have some very knowledgeable people on there.
:{THC}:YosamiteSam
posted on 9/2/12 at 08:33 PM Reply With Quote
why not put a physical stop on the throttle pedal so you cant press the pedal further? simple bolt with a locking nut will do. makes it adjustable and removable. wind it closer to the pedal to stop you putting your foot down - back away gives you more pedal - simplzzzzz
T66
posted on 9/2/12 at 08:48 PM Reply With Quote
Why not source some of the autograss Busa users, if losing first gear is relevant they will be doing it, and know how for washers.
A1
posted on 9/2/12 at 09:51 PM Reply With Quote
how about sound insulating your airbox a bit?
veld
posted on 10/2/12 at 05:51 AM Reply With Quote
During the test the controler open the air box to see if the admission is totaly open , so it's not possible, in the past they don't open the air box....
I's can be interesting to have come back about the user of megabusa who have repaired the first speed....
loggyboy
posted on 10/2/12 at 08:35 AM Reply With Quote
So the test is done without an airbox? or u must use a standard airbox? surely its possible (and easier) to spend time and ennergy on a standard looking enhanced airbox!?
veld
posted on 10/2/12 at 07:09 PM Reply With Quote
During the test there is an air box, i have finish the transformation of the hayabusa air box with the help of Cosmick....
The controler just defuse the air box before the tests to see if everything is ok ....
I have discuss with the man who succeed the tests with a megabusa.
He limit the rpm at 6000
Big air box
insulate everywhere (bonnet, side, under...)
1 exhaust in the side one other under the car.
The results are 82 db and the limit is 77 db.....
But after 3 essays , he have a "gift" and he pass the tests in the 3 speed instead of the 2.....so he win the 5 db.....
Sorry if i am not clear with my english.....
That is the reason why i think it's necessary to delete the first speed but if somebody can find an other solution i will be very happy and he has a nice gift for chrismas.....
cosmick
posted on 11/2/12 at 10:19 AM Reply With Quote
veld,
I am still looking into blocking 1st gear for you and I will be looking at an engine this weekend. Please be patient and I might have a solution.
cosmick
If it can't be fixed with a hammer then its probably an electrical problem.
daniel mason
posted on 11/2/12 at 10:33 AM Reply With Quote
can you not fit 2x large silencers in line.
veld
posted on 11/2/12 at 10:37 AM Reply With Quote
Originally posted by cosmick
veld,
cosmick
Ok thanks i will wait news....
And for the exhaust i have already preview 2 silencers.....thanks
<<  1    2  >>
