theduck
posted on 4/3/12 at 08:09 PM |
Doesn't sound like it wants to fire at all. Just cranks over on the starter.
When you say is the distributor in correctly go you mean the distributor itself or the leads on the cap?
Edit; ah ok, that's fine then.
[Edited on 4/3/12 by theduck]
lotusmadandy
posted on 4/3/12 at 08:13 PM |
The dizzy. Make sure the rotor is pointing at no 1 with the engine timed at
top dead centre.If it is 180deg out it wont go.
theduck
posted on 4/3/12 at 08:17 PM |
Right ok, at the moment with cyl 1 at tdc the rotor arm is pointing roughly at 4/5 o'clock if 12 o'clock is towards the block.
lotusmadandy
posted on 4/3/12 at 08:23 PM |
Put the dizzy cap on and make sure that the lead
is going to no1.
If it is going to no4,then it is 180degs out.
If it is,take the dizzy out and rotate the shaft to point at no1.
theduck
posted on 4/3/12 at 08:27 PM |
I'm lost, when i put the cap on I can pick which lead goes on which terminal, so I put the lead to cyl1 on the terminal the rotor points to.
lotusmadandy
posted on 4/3/12 at 09:03 PM |
u2u sent
Andy D
posted on 4/3/12 at 09:38 PM |
If there's no fireing at all, not even a backfire, I suspect there's either no ignition at all or no fuel. If the plugs are wet, you have
fuel, and no or not good ignition. Dry plugs, mean no fuel.
theduck
posted on 4/3/12 at 09:51 PM |
I checked the spark plug and it's definitely sparking.
Not had it out again since trying to start it so don't know if they are wet.
Lotusmadandy sent me a u2u with some checks for timing which are all ok.
Is there anyway the cam can be timed wrongly on the cam pulley?
lotusmadandy
posted on 4/3/12 at 10:00 PM |
There is a woodruff key on the cam,so unless
someone has left it out the cam cant move.
Check the compression on no 1 when its on the firing stroke.
If all is ok then no problem.
theduck
posted on 4/3/12 at 10:02 PM |
Cheers.
Will try a different carb tomorrow
jollygreengiant
posted on 4/3/12 at 11:13 PM |
It is possible to put the cam sproket on the wrong way round, ie front face to rear and that will put the cam timing out relative.
Also I have known the resistor in the rotor arm break down, you get a spark, but not enough to fire or no spark at all, I know of one mechanic who
changed the distributor becuse of this, he thought it was the distributor.
If you have spark and wet plugs the trick with a VV carb was to get someone to turn the engine over while you held the needle slide fully open.
posted on 5/3/12 at 12:04 PM |
It's not quite that simple - the rotor should be pointing to no.1 with the engine set to TDC on the compression stroke. It could quite
legitimately be 180 degrees out if you set the crank timing marks to TDC exhaust stroke.
Not Anumber
posted on 5/3/12 at 12:09 PM |
If in doubt turn the dizzy round half a turn and try again.
owelly
posted on 5/3/12 at 12:30 PM |
Simple things......
Check you have the correct firing order and that the rotor arm is spinning the same way as you are numbering the plug leads.
Quick squirt of Easystart down the carbotooter will tell you if you are looking for an ignition fault or a fuelling fault.
Then we're looking at compression testing.....making sure the valves are all closing.
http://www.ppcmag.co.uk
theduck
posted on 5/3/12 at 12:51 PM |
Just to confirm the timing checks that have been done. Cam lines up with tdc Mark, crank lined up with Mark on pulley, distributor as photos shows
above.
Tried easy start down the carb and still doesn't fire.
Checked spark at plug and it does spark.
Checked rotation of rotor arm and that matches lead order.
Have cranked off battery alone and with jump lead to try and eliminate possible weak battery.
Other than these what else cannot be? Am thinking this morning either compression or coil, leaning towards coil as same fault on two engines?
owelly
posted on 5/3/12 at 01:30 PM |
Try getting an old spark plug and opening the gap to 5-6mm and see if it still sparks. If it does, I doubt the coil is at fault.
Did you have the butterflies open on the carb when you tried the Easystart? Is there any way there is air getting sucked into the inlet? Dodgey servo
or open tappings etc? If the engine is sucking air in, rather than fuel......?
In my experience, Easystart will fire with a very weak spark. Even if the timing was miles out, it would backfire.
theduck
posted on 8/3/12 at 11:36 AM |
Ok so getting back in the garage tonight. Plan of action is as follows:
Crank engine
Remove plug to see if wet with fuel
If dry change carb and try again and hope it starts.
If wet try an opened out plug to check strength of spark and come back for advice. Lol
bartonp
posted on 8/3/12 at 01:06 PM |
Crank engine
Could also chuck some fuel down the inlet & it should start & run briefly (probably been suggested already).
theduck
posted on 8/3/12 at 01:18 PM |
Think it has een suggested, tried easy start and and not even a cough.
theduck
posted on 8/3/12 at 07:41 PM |
It's teasing me now!!
Tried the spark plug test and got good spark on this plug
So I changed carb to the 34ich, remembering to connect a live to the fuel cut off and this is the result
May need to click picture for video
theduck
posted on 8/3/12 at 08:05 PM |
Link first video. http://i1128.photobucket.com/albums/m492/stumac1985/cec283c4.mp4
Link to better video. http://i1128.photobucket.com/albums/m492/stumac1985/15db3c77.mp4
theduck
posted on 8/3/12 at 11:06 PM |
Owelly just seen what you said about servo. Can I blank off the servo outlet to eliminate that as a problem??
Chippy
posted on 8/3/12 at 11:58 PM |
In your second vid, it did sound as though you were getting a slight chuff every now and then. I havent read the complete post but was it a running
engine when you got it, have you stripped any of it? Battery didn't sound in the best of health! I would be inclined to check the valve timing,
ignition timing, and ensure that the carb was clean without any blocked jets. Check that the earth connection from the battery is good to the engine.
HTH Ray
theduck
posted on 9/3/12 at 08:37 AM |
Engine was sold to me as running though I have not heard it running.
Came with a VV carb which I couldn't get any life out of at all so swapped to this webber 34ich which seems to be better but still not starting.
have tried easy start also and that is still the best I am getting. Timing has all been checked and all line up with relevant marks.
Could it be a vacuum leak? Can j block off the pipe to the servo to remove that from the equation?
owelly
posted on 9/3/12 at 08:57 AM |
Yup, block off pipe to servo.
