Agriv8
posted on 2/7/13 at 10:37 AM |
AWDC ! playing with the big Boys Does Robin Clarkson still attend events 240z powered 4wd Warrior.
Co-drove a Warrior in Welsh Hill rally 88/89 IIRC still miss the good bits, I will have to scan the Photo off my wall at some point.!!
good luck with the racing.
ATB Agriv8
PhillipM
posted on 2/7/13 at 10:39 AM |
He's running a Nissan 350Z V6-powered spaceframe car with a Pug 306(ish) bodyshell these days - actually his second one IIRC, he sold the first
- mainly NORC but he turns up to the odd AWDC/joint event too.
[Edited on 2/7/13 by PhillipM]
PhillipM
posted on 2/7/13 at 10:45 AM |
And the next few weeks:
Right, no, we haven't been spending all our time in the pub (more's the pity), just haven't had much time with the photos due to
pulling the engine/gearbox/etc all back out again so we could change the clutch (cracked the plate and worn yet another splined center out), and weld
in the upgraded suspension bits:
As you can see, the torsion bars have been removed, along with the frankly knackered bushes and spring plates (they wear out rapidly from all the grit
that gets in, then the back wheel toes in and out of it's own accord and the car steers where it likes!), the bushes are about £120 a set and
when they're dying after an event and knackered after a few it's a bit tiring.
Anyway, if you look, the whole thing has now been replaced with a chromoly rose joint, clamped in double shear between those plates (the gap will be
plated over and welded between the pegs to stiffen the whole thing up at the front).
In case you are wondering, the gap between the plates is that large as the rose joint runs side spacers - these serve two purposes - one, they allow
me to wrap the joint in a neoprene sealing boot to keep the mud and water out (which will also be packed with grease to reduce the heat and wear in
the joint).
In addition to that, the gap should allow the mud to drop out of the back of the plates, to prevent damage to the boot - seems a little backwards
having a larger opening for the mud to get in there to start with I know, but with a small gap all you need is one small stone/clump of mud to stick
and then all the muddy slop/stones build up behind it.
More pictures soon, I promise
I'll have to as Rob over at www.gtechniq.com has kindly donated some more water/mud repellent products that will now work on the side
polycarbonate windows, some of their P1 polish, and dirt repellent coating for both the paintwork and the mudguards in an effort to keep the buildup
of mud off the car and the stickers visible - seems a little tarty for us I know, but it's not uncommon to scrape 30-40kg of mud off the car if
it's a wet event, that's a fair chunk on a light car such as ours, and being able to see is always a bonus!
Personally I think Rob's sitting at home laughing his tit's off at me having to polish this thing, it's gonna take a tub of elbow
grease the size of a swimming pool!
Edit: You can also see the upper secondary torsion bar there - the one that runs across the back above the beam - it's attached via rocker arms
and rose-jointed droplinks, and can be set as either a secondary spring that lifts the spring rate at a certain point in the travel, or stiffened up
and set to use a softer version of a bumpstop to prevent the chassis hitting the floor, depending on the course.
And a week later:
And a bit of makeshift modifications to the arms to space the rear dampers apart so that we can run springs on both pairs of coilovers, it also grabs
the shock in double shear instead of single - as the bumpstops are on the dampers rather than the body now it makes it less likely to bend a bolt on a
big impact.
Not the best arm design in the world due to the cut and shut but it's more than functional, we'll probably make a couple of lighter,
stiffer ones during the break in the race come summer.
The open area to the right you can see will be plated in with some drilled/pressed 1.2mm steel sheet to tie the upper and lower tubes together, which
will stiffen up the connection between the inner damper and the hub without adding much in the way of weight.
In other news, the Bay of E has turned up trumps with a brand new half-decent TIG welder without breaking the racing budget, picking it tomorrow, so
lots more formed alloy components and brackets to save weight will be appearing through the year after a bit of practice, hopefully.
PhillipM
posted on 2/7/13 at 04:02 PM |
And a few days later:
Anyway, all the new suspension is oe and setup - the dampers want some valving changes but we're waiting on the new sets of rear springs (for
some reason, Demon tweaks and Rally Design don't keep 24" long coilover springs in stock, : ), so I'll leave those until I know
precisely how it behaves on those. There's also another 20mm travel available with the new parts so I'll need to alter the stops in the
dampers anyway.
Waiting on a new paddle clutch arriving (mullered the centre in yet another one), before we can put the engine in and rear cage/bodywork, etc, on
though, so going to be some long nights this week!
Friday before the next race:
Well, springs are here
Brake pads are here
Nice clutch firm sent us some new splined centres out for free because they couldn't do us a plate, which are being machined to fit the old
paddle plate as we speak
And the engine is still sat in the corner and half the frame and bodywork is on the floor, 's gonna be a looong day today!
And Saturday morning before setting off at warp speed to attempt to get there in time for scrutineering:
Well, shiny red new arms, casing and rose joints:
Shiny red new XP10 brake pads:
And new damper mounts to allow twin springs so the torsion bars can be chucked:
Out went the XP8's and in went these, XP10's from Carbotech - the XP8's have been fantastic, we used to go through a set of pads
every 1.5 events, and pair of discs every 3 events, we stuck Xp8's on the front and back after trying all sorts of different pads, and the rears
did 9 events, 10 test sessions and a trackday, and still had some left.
Initial bite and outright power are superb, and the consistancy has been great, it doesn't matter if you've got the discs orange or
you've just been through a muddy stream full of ice cold water, they just work, perfectly, first time, every time.
Getting ahead of myself here but the front XP8's have been on the car for 3 years now and they're still only half worn!
Anyway, back to the story:
Oh, and the disc 'wear' after ~15 months of racing abuse.
That'd be, errr, none then.
And onwards to Waterbeach for the next event!
PhillipM
posted on 5/7/13 at 12:59 AM |
And the race report from Waterbeach:
Well, the weather was fantastic, the course was nice - albiet a bit of an outright power course - lots of fast stuff, the engine didn't explode,
the temperatures stayed reasonable, all the wheels stayed on, new brake pads feel like someone threw a brick wall in the way, the new suspension held
up just fine and the car rides the rough stuff like a bloody magic carpet with a rocket up it's arse
Unfortunately, we had the Curse Of Waterbeach return in an exact re-run of last year the bloody throttle cable snapped just before the finish on the
last lap!
After burning our hands and removing a few yards of skin trying to wedge it open to trundle the last straight to the finish in first, we had to give
up and take a maximum, a little unfortunate as it was feeling pretty quick all day.
We'll see what we were doing when the run times come through on Tuesday (issue with the timing printer/computer), car was much easier to drive
with the new suspension though.
And the next day:
Right, the drill and hammer has been out and she now sports 2 throttle cables, take that yer swine
Rear dampers are apart to give a little more damping to match the new spring rates, and the driveshafts have been tweaked to give us a touch more rear
suspension travel. Next job is to pull the front suspension apart and replace the worn bearings and bushes (again), and perhaps some tweaks to the
side scoops to flow some more cool air around the gearbox as the oil is getting a bit too warm.
And beat all the dents out of the skid pans with a sledgehammer....
Waterbeach pictures:
Really must stay off the pies.
Definately less pies.
(You can see the modified front dampers on that one too - the old Bilstien canisters and floating pistons hooked up with some braided hose to an
adaptor running into the original gas-emulsion (well, they're not emulsion now the canisters are on) Fox dampers.)
And another
1st in class again (in fact the only 2wd that actually finished), 7th overall in the awdc results, and, because we've been fairly consistant in
pace through the events, we're now 3rd overall in the championship. Long way to go yet but we're hoping if we can hold off on the big
upgrades whilst winter (new front suspension in the works) and just concentrate on current suspension setup and reliability mods, then we might be
able to hold station there and end up with a podium, with a lot of luck.
[scooby doo mode]
Would have been second if it weren't for that pesky throttle cable!
[/scooby doo]
And a mix of pics from both Walters and Waterbeach:
![](http://img.photobucket.com/albums/v89/Rippthrough/WaterbeachWoods3.jpg)
PhillipM
posted on 10/7/13 at 12:27 PM |
And some more
quote: Right, not got much in the way of improvements this time around I'm afraid, bar making up the new side scoops, then deciding they looked
crap and didn't allow the air to expand enough and shelving them, back to the drawing board.
Anyway, with this weekends event being a 2-day race rather than one, we decided to concentrate on a bit of maintainance and setup work rather than
introduce yet more new parts (got some front suspension/arm upgrades in progress, and some stiffer damping settings, but we'll wait until we can
get some more testing time before fitting those)
So, spent this weekend having various sensors recalibrated after some replacements, just to ensure they're accurate, tidied some of the wiring
up that had been chopped about before to add new bits, and then sat with the laptop refining the engine mapping.
Mainly been focusing on the throttle transients to get it to respond as smooth and crisply as possible, as it sometimes had the odd hiccup when it
was still on the cold engine map, and added as much fuel up the top of the rev range as possible without killing the power in order to cool the engine
a little more.
And the most important bit, the nice 3ft long over-run flames are back
Reliability tweaks and refinements this month really, sorry, no pictures of new shiny bits for a change!
Regrease all the bushes and bearings on Friday, set the tracking, load up and off to Baden Hall and see how she goes!
After the weekend:
Lots, and lots, and lots and lots and lots of water from the sky.
I'll give a race report in a week when I've dried out...but there's a lovely shiny trophy in the house....![](/images//smilies/bigsmile.gif)
And that report:
Oh, also had a slight arguement with a concrete post.
http://www.youtube.com/watch?v=kEq1enypU6g
For once, the car won
(Seal bust in the front damper and let the gas out overnight, hence the weird bounce that threw it into the fencing).
Definately going to have step up with saving the money to get that limited slip diff as soon as possible though, it was so wet today that if you came
out of a corner behind a 4wd car they pretty much disappeared whilst the car sat spinning wheels, once it got going you caught them back up under the
brakes but it's a fair struggle to keep the car up where it needs to be in the results once the heavens open
Meanwhile, well, this was Sunday morning....
And it still looked shiny on Monday morning after a day of racing:
One lap later it looked like this...
1st in class again (in fact the only 2wd that finished), 7th overall in the awdc results, and, because we've been fairly consistant in pace
through the events, we're now 3rd overall in the championship. Long way to go yet but we're hoping if we can hold off on the big upgrades
whilst winter (new front suspension in the works) and just concentrate on current suspension setup and reliability mods, then we might be able to hold
[scooby doo mode]
[/scooby doo]
PhillipM
posted on 10/7/13 at 05:59 PM |
And a couple of weeks later, more bad news....
Right, had the rear dampers apart and put in some more low speed rebound - to compensate for the friction lost with the new rear suspension - and also
put some more compression damping in the range for landing over jumps, as it's a touch soft at the back at the minute. Sounds simple but it was
a pain in the arse
See how it fairs this time out - probably tweak the fronts a bit to match but we'll see how it goes first.
Two new aluminium plates ordered for the sump and gearbox guards too as we've worn a hole in them...
And two new mudguards, give the hole in the rear one from firing a rock through it off the rear tyre, and the post incident with the front
one!
Couple of days later:
quote: Well, dampers back on, new skid pans made and fitted, new mudguard on, fresh fluids, new mastercylinder for one of the brake circuits (score on
the bore from some debris), new power steering valve and pump, and she's strapped down to the trailer ready to roll again
Even given her a polish!
And the bad bit at the next event:
Won't start hot.
Lost power through the revs.
Won't go past 7k.
Oh dear.
PhillipM
posted on 27/7/13 at 05:07 PM |
Sorry about the pictures going, the account should reset next week so I'll update again then ![](/images//smilies/bigsmile.gif)
PhillipM
posted on 4/8/13 at 02:29 PM |
Right, onwards we go again, on the subject of the engine, again:
Side seal gone in the engine again I think. Just not up to the heat generated in race use.
Forlorn hope that it might be a sensor or something electrical but the symptoms are there...
I think that's game over for the championship podium now
Bit of comparison testing for Gtechniq who supply our mud/water repellant window coatings:
C1 crystal coating on the drivers side panel, G3 rain-repellent on the drivers side window and their C2 product on the plastic mudguards and mirror
(the rear mudguard was fairly clean too until it got ambushed by a tree at the bottom there, hence the crack!).
Gtechniq side:
versus:
This side had a very popular wax know for it durability applied too. Didn't last that long!
And, we had the results through from the event where the engine died:
Results through tonight!
Now 2nd in championship, and 3 points behind 1st.
[homer]
Doh!
[/homer]
And after a bit more diagnosis, the inevitable with the engine:
quote: Looks like RX8 engines at the moment are going for a fair old chunk, so it's probably season over, we didn't budget for a spare
engine I'm afraid!
We'll keep on the hunt, and I'll let you guys know if anything happens on the engine front.
If not, I'm sure we'll manage to sort something silly out over winter instead...
[Edited on 4/8/13 by PhillipM]
PhillipM
posted on 4/8/13 at 02:36 PM |
However, just over 2 weeks later, we stumbled across a cheap motor and decided to risk it and slap it in:
quote: Late on a Saturday afternoon, an engine barks into life...
...and promptly covers half the town in blue smoke from burning the presevative oil film off the inside of the rotor housings
Unfortunately, the weatherman said we couldn't go racing:
quote: Well, cars ready, all packed up, loaded on trailer...and Ed gets called into work because the weather has dried the crop out, bloody
farming!
Sat twiddling thumbs all day on the off-chance that we can get down there tonight if he finishes in time, but it's not looking likely now -
it's a 6 hour drive, and it'll be at least 2 hours to walk the course in the morning and half an hour for scrutineering too....
Doh!
Next month:
quote: Right, didn't make the last event
All that work wiped out by the weather and farming! Ah well, down to 7th in the championship now but we'll see what we can claw back.
Loaded back up and on the trailer ready to head to SevenOaks tommorow though, supposed to be a nice tight and twisty track, so might be good for us.
Hopefully!
And a quick writeup from there:
quote: Well, few issues again, that's what you get when you've not got anywhere big enough to test it - car misfiring badly when it got
warm, which meant we took a maximum penalty time early on for not completing a stage.
Think it was down to a couple of failing coils, however, we didn't have enough spare coils to replace them all and completely get rid of the
issue, but we got it better and good enough to run around all day, albeit still with a misfire and about 40bhp down from a reduced rev limit to
preserve the engine/coils.
Apart from that, it was an absolutely fantastic course, with something for everyone - some faster stuff through a couple of fields, plenty of lanes
through forests, turning into tight tree-dodging sections (which the new suspension and fiddle brakes on our car were fantastic, I don't think
there could have been anything much faster through them), and then some nice narrow flowing tarmac and gravel sections back through the forests again.
Think it's up there for one of the best events we've been to.
It also gave a great proving ground for some alterations to the brakes and the suspension work, and they were flawless all day, so at least the rest
of the car is about where it needs to be now, on pure laptimes we weren't all that far behind the podium guys even with the dicky engine, which
was encouraging - in fact, if we hadn't abandoned a stage to try to sort the coils out, we would have been 4th even with the misfire all day!
Pity about the engine as it's cost us any chance of regaining a podium this year, but that can be sorted and it's proven the rest of the
upgrades anyway.
However, since the engine was playing silly buggers anyway, we spent half the day giving passenger rides, which judging by the grinning faces when
they got out went well
Hopefully we can still hang on to some more points at the next event after sorting the engine, and make sure we get a single figure race number for
next year
We did get the highest jump over a bump in the field though
And that night after doing some sums:
quote: Just working out the times and points, and it appears nobody can actually catch us in the 2wd championship again, even if we don't go to
the next event and the nearest guy wins, so at least we've won the 2wd trophy again
PhillipM
posted on 4/8/13 at 02:42 PM |
More photo's time!
Sorry about the quality, pictures of pictures again
Look, there's at least one or two in there with wheels on the floor as well! ![](/images//smilies/wink.gif)
PhillipM
posted on 4/8/13 at 06:16 PM |
Anyway, back to engine issues (sound familar?):
quote: Well, in the hope of sorting out the munching coils issue, there's a set of D585 coils on the way from the 'states, they're a
lot more powerful than the stock mazda coils, but more importantly, the components are rated for a higher ambient temperature (120*c instead of 85*)
and they come with their own heatsink on the ignitors to help with cooling.
Should help with coil life, they're a damn sight cheaper too, bought 8 x D585's for less than the price for 4 Mazda OEM coils.
Got some rewiring to do to make them fit, and need to make some new ends for the Magnecor leads (do Magnecor still do custom leads, seem to remember
they used to?), and some tweaking to the dwell tables in the ECU to charge the new coils for longer.
Fingers crossed!
Followed by a bit of mucking around trying to find the issue and myself getting slightly annoyed
Right, this bloody new engine is making me loose what hair I have left:
Mis-fires badly from 3.5k to 7k.
After 7k it clears and goes like poo off a shovel.
Engine starts just fine, no excessive cranking, idles smooth as butter.
All injectors are working and staging okay, coils are working, variable valves are working, there's nothing stuck in the intake tracts, the
earths are all good and clean.
Leads are relatively new Magnecors, new set of spark plugs. Swapped two coils for brand new spares that made a small improvement but not much.
Fuel pressure is fine, fuel lines are clear.
Throttle pot checks out okay, new throttle pot makes no difference. Same for the shaft sensor.
Our rudimentary coil tester (patent pending) - otherwise known as a trailing plug with the bar snapped off - shows a consistant spark across all 4
coils - albeit a relatively weak sounding orange spark, but with no difference between 'em that would mean we'd have to have got 2 duff
new coils too...
Winding the coil dwell up just to check makes no difference either.
Only change between this engine and the old one is the timing (S1 > S2 timing is different), checked with a timing light and it's right,
tried it 20 degrees retarded and no difference bar a lack of power.
And a week after cursing, just before the next event:
quote: Okay, looks like the 2 brand new coils we had were a pair of duff ones, so all that fun was for nothing :hehe:
Lesson learnt, if all the symptoms point to coils, even if you've swapped them, it can still be coils....
Anyway, over the weekend we've done a very fast conversion to some D585 Yukon coils - which are rated for more ambient temperature, have a
built in heatsink and are also much more powerful, rigged up with some universal leads most of the misfire went away (bar a little @5krpm, but the
spark plugs are sooted up from running them before).
Have to say a big thank you to the people at Magnecor, who after a hurried e-mail over the weekend, sorted out a rush order on some custom
ignition leads for us to suit the new coils, which arrived first thing this morning, ready to put on and test before we set off down to Minehead on
Friday.
I'll get a picture tonight if I remember of the new coil setup! At the moment it's a case of some very fast work to correct the timing and
coil dwell maps...
Hour or two later:
Shiny new leads, beefy coils and new wiring, hopefully should stand up to the heat and abuse a bit better than the Mazda ones!
Still had a bit of a stutter between 4 and 5krpm, but we put it down to perhaps the plugs being carboned up, so we called in on the way to the next
event (Minehead) and picked up a fresh set of plugs, which cured most of it, although running around the service area at the event revealed the engine
was sluggish up top (that's what you get with taking a risk on a cheap one I suppose).
PhillipM
posted on 4/8/13 at 06:21 PM |
Unfortunately, this time something else decided to stop play:
And the oops moment:
It actually finished the lap and drove around like that, but not making a very healthy noise
Looks like the flex from impacts over the years started a crack off, and the heat buildup in the diff let the oil break down enough for it to pickup
and take the teeth with it - it doesn't help that there was a slog sideways up that grass bank we're coming down in the pics above that
had the car spinning the unloaded wheel for quite a while, the spider gears will have been going like sh*t off a shovel for a while.
Doh!
alistairolsen
posted on 5/8/13 at 07:42 PM |
Great read, thanks for posting it up, looks like you guys have had a lot of fun along the way (along with your fair share of late nights!)
My Build Thread
PhillipM
posted on 5/8/13 at 08:22 PM |
I think late nights is probably something everyone on here has had more than their fair share of
There's more to come yet, it gets a little more interesting shortly, I'm just trying to keep in in readable chunks instead of a massive
wall of text
[Edited on 5/8/13 by PhillipM]
PhillipM
posted on 5/8/13 at 11:26 PM |
Right, on with the repairs, again, this was the weekend before the last race of the season:
quote: Arrrgh, spare gearbox in, test run, stuck it in reverse and it jammed there and won't come out. Engine out again...
An hour later:
quote: Engine out, gearbox apart, 5th gear synchro/selector was worn just enough to move ~1mm on the shaft and jam the whole selector mechanism.
frown
Put a 45* bevel on the edges of the selector to help if anything similar happens in future, and 5th gear/selector and it's fork are on the bench
looking lonely
Gearbox back together, engine and box back in, radiators back on, fluids refilled and bled, test driven, works beautifully.
4-speed gearbox now, it's lighter, might go faster
And then raceday!
quote: Right, after a very rough event at Kirton today, we've managed to claw a couple of places back and end the year 8th overall in the
Championship, albeit after battering the skid pans to death, punching two holes in the floor, cracking the windscreen on a hard landing and hitting
the engine skid pan hard enough to dent it the whole way across and put a dent in the sump too.
Oops.
This stand-in engine was feeling decidedly unhappy towards the end of the day too tbh, just about managed it but it doesn't have many ponies
left!
We got 4th at that event, although 3rd wasn't on the cards with the engine dying, it might have been close if not.
And over winter, we went to a party and collected another one of these:
Of course, winter off-season, means winter upgrades, no? ![](/images//smilies/tongue.gif)
PhillipM
posted on 5/8/13 at 11:28 PM |
Can't end a season without some pictures eh?
![](http://img.photobucket.com/albums/v89/Rippthrough/001.jpg)
PhillipM
posted on 6/8/13 at 07:12 PM |
Right, first modification ready for the new seasons, off-road spec welder!
And something to use it on:
quote: We decided to fabricate some new front arms to reduce the friction in the suspension, modify the geometery and give a bit more travel at the
same time, so new arms getting mocked up:
4 degree's of static negative camber, 7.5 to 16 degrees of castor (varies with travel, not much I can do about that), 4 inches of extra travel,
1 inch less scrub, more progressive spring/damping rate, and 2 inch wider track
and the next day:
quote: Yes, I know, the mudguard is miles out and the wheels are about as round as a 50 pence piece - don't worry, making new ones, gotta move
the mudguard as we're making new damper mounting towers too, improve the motion ratio and change the progression curve. Gives you an idea of how
much travel there is though, that's not quite full compression - it's got another half an inch or so.
![](http://img.photobucket.com/albums/v89/Rippthrough/NewArmsFullDroop.jpg)
And after a week of counting pennies and trying to see if anyone would part ex. our old dampers:
quote: The things we go through in the name of money saving...couldn't really stretch the winter budget to a set of longer 10" stroke
front dampers to match the arms, so we're having to trying and make the old 8" units do the job, doesn't do the motion ratios any
favours, but needs must:
Damper goes the other side of the bracket but the old shock tower was in the way, I've had the angle grinder out since and there's a lot
of front steelwork sat on the floor now though
Best get on with making the real replacement arms properly now though!
Ed's finished welding the jigs up tonight so should be able to knock the proper T45 tubular arms out in the next couple of days, got a few bits
of chopping and tweaking on the chassis we weren't expecting just to add a little clearance around the tie-rods, and possibly move the rack a
little more, but it's almost there, just waiting on some spacers/fitting for the new steering arms.
In other news, engine should be back together just in time for christmas, it's had a bit of light port work to boot as well, see what Santa
brings when you've been good...
Hopefully should get chance for a run around the yard and lane after christmas just to give it a quick check over (I'll get some video this
time, I promise!), then it's back to ordering yet more springs, damper oil and valve shims/stacks, as the whole lot needs re-valving and
re-springing again, doh.
And another 6 wheel rims to make and weld up too, bit more offset now the track is wider.
Once that little lot is sorted, we'll start on the rear suspension!
Right, no takers for the 8" Foxes so needs must, on they go, proper arms nearly finished:
Few weeks off for Christmas and back on the job:
quote: New upper mounts in progress for the damper, didn't really want to put a kink in the arms (need to be as stiff as possible) but
couldn't clear the damper when it's fully compressed without, good enough anyway, another tie-rod to go down the chassis toward the rear
mudguard mount too - may as well - but it's stiff enough without tbh:
Don't worry, it's not getting heavier, it's all thin-wall T45 tube, lighter than it looks!
Certainly lighter than the plate tower that was there before anyway.
From the side:
And the passenger side pretty much finished:
Bit of a delay after that as whilst moving the rack and tie rods we discovered some play in the rack, and needed to make some spacers for the uprights
to correct the bump steer after moving them, so a few weeks later we finally got there:
Weekend in pics:
Finished these at last, car on the floor again!
Pushed her outside today for a look at the front from afar, and to see what it looked like at full articulation (one wheel on floor, one in air, with
car still perfectly level, lots of travel!), didn't get a picture as it was dark and raining but she certainly looks a bit more purposeful
now!
We've lost a shedload of friction in the front end with the new bush/bearing/arm setup too, which should help the ride and handling.
Slight technical hiccup with the bonnet...
Needs a bit more than some T-Cut to sort that out...
PhillipM
posted on 9/8/13 at 01:23 AM |
And a bit more text for you to skim through and skip to the pictures
quote: Right, wiring ripped out, new connectors here, ready to start making a fresh new loom again, what fun. Only 4 weeks before the first race and
the car's a frame with some suspension on at the moment!
Ed's just mounting the new fans whilst I 'enjoy' rewiring some parts of the car loom that were rather tired
Looks like the new rear damping system we were hoping to do as well is going to have to wait until the second event, as we'll be pressed to get
everything together and the car shook down for some testing at this rate, haven't heard back on the new gears we've ordered yet either
quote: Gear man's ears must be burning, he rung me not 5 minutes after posting that, might just have them in time
Spent the weekend fabricating the new front mudguard mounts, made new steering tie-rods, and stripped the steering rack.
Rack had loads of play in it and no provision for any adjustment for wear and tear, so I had to sand the whole case down by hand with wet + dry paper,
until it got back to a nice, tight sliding fit again, then bond tiny strips of 0.25mm thick shim steel to the rack bar to bring it back into proper
engagement with the pinion, and then make some more tiny strips of shims to give the appropriate clearance back on the casing, as well as changing all
the support bearings.
It involved lots of swearing.
And it's a good job the firm that make the rack have gone bust so I can't go over the pond and kick them square in the nuts.
Even started rubbing down and painting the front arms, shiny things on the car for once!
And, we paid for a full engine rebuild on our '09 motor from a specialist, which is why we didn't buy much in the way of shiny parts this
winter and just made them instead
quote: Just fetched engine tonight, it's had a rebuild (apex seals warped from the heat) and some light port work - tbh, because they wanted a
look at the R3 motor a bit closer, he did it almost as cheap as we could get the parts to do it ourselves, no brainer really.
We wanted a fresh engine for the year, and a check over the rest of the engine to see if we'd sorted the trouble we've had before with
side seals/springs, which seem to be good now (bar needing a bit better intake filtering), so we'll get a few events on the engine to make sure
all is okay, then supercharge her.
So, it was engine in, all the vital bits connected, and a quick run around the lane:
And some bonnet work:
quote: New prefilters + secondary airbox:
Would probably be better with a couple of cotton filters up there so we can wash them out, but budget dictates paper for the moment!
Accidentally made it flow enough air for 500bhp, oh and the supercharger can go where the primary airbox is at the moment too.
Fancy that!
Then it was off to race at Walters Arena:
quote: Well, weekend went fairly well. Bar doing 3 miles on 3 wheels, and the next run with no brakes....
Writeup later!
Oh, and 'Wheeee!'
daveb666
posted on 9/8/13 at 06:31 AM |
When and where is the next event?
PhillipM
posted on 9/8/13 at 12:18 PM |
Not for a while for us, she's having work done at the minute, I just haven't got that far yet
However, I think the next AWDC event is on the Sweetlamb Rally Complex near Llangurig on the 18th.
PhillipM
posted on 9/8/13 at 12:53 PM |
Oh, and it's not a safari unless you find some mud:
As for the 3 wheeled excursion, well, we re-used the old VW link pin washers that hold the upright to the arms, turns out they weren't up to the
job any more, one folded over and the upright fell off, leading to dragging a front wheel sideways along for a few miles on one lap. Doh.
That also killed a brake line with a hairline crack at a joint we didn't spot, which resulted in doing the next run with just rear brakes on
the fiddles, no pedal, so we had one driving, one braking
So, we weren't exactly fast, we spent the rest of the day just going steady so we could get it home in one piece, but the new suspension worked
nicely when it wasn't hanging off
Had a few issues with the new engine being a bit slow to start, so a few tweaks to the startup map might be required.
After getting home from the event:
quote: Shiny new paperweights waiting for us when we got home!
Need a lot of hours putting in to profile the selector teeth by hand, as they couldn't get their cutting gear in for the right angles, but they
were cheap so it was worth it, only way we could afford it
Shorter 3rd and 4th gear, so they're a bit more useful, currently 3rd is good for over 90mph and 4th is good for about 135mph, which the car
struggles to pull when it's on a gradient, the new ratios should drop that to 80mph and 108mph.
And a bit of damper maintenance:
Hey, the old shock oil doesn't look too bad for 2 years of abuse, sure, it's a little dark, but it's clear, not cloudy and no real
debris in there either, gotta be good, right?
I mean, even the seals and shims look spotless, next to no wear on them at all
And the new oil is just the same colo.....oh, wait, maybe the old oil was a little tired then....
We swapped the VW retaining washers on the upright for a couple of 10.9 grade hardened structural ones too...![](/images//smilies/bigsmile.gif)
PhillipM
posted on 9/8/13 at 01:57 PM |
And off to the next event at Waterbeach, near Cambridge:
Well, the site was better suited to swimming today - pressing the throttle pedal down in any gear at all just meant the mud flew higher - the car
didn't go any faster
Unfortunately, we had trouble with the alternator on the second run, which lost us 10 minutes whilst we bodged it back together with side cutters and
tie-wraps.
However, the next few laps we barely made it around - literally creeping along sideways on full lock at 1mph through a few sections they were so
slippery, and then just to top it off, on the very last lap, either the gearbox or the clutch plate let go with a bang whilst launching off the start
line
Bah!
Had a lot of issues with starting the engine again too, which isn't good....
A photo so I can remember what the car looked like when it was clean:
That's the lightest bit of rain we got!
Well, up until the racing finished, when in the usual UK-weather trick, the rain stopped and the sun came out.
Extra points if you can spot the vital performance upgrade it's had!
And a couple of pics:
Whee!
And here's some more of that muddy stuff:
PhillipM
posted on 9/8/13 at 09:26 PM |
And just before the next race a month later:
Well, got our nice new 15 tooth starter gear and new clutch centre yesterday, so, in a mad rush today, we chopped the starter mount off, fitted the
new pinion gear, moved the mountings welded it all back up, refitted the clutch, lifted the engine in, bolted the rear frame/cage back on, fitted the
exhaust/wiring/oil/fuel lines/etc, and fired her up!
With an hour of tweaking with some cold start enrichments it's now faster at starting again, great.
So, fitted the floor, seats, belts, etc, put it in gear to reverse out of the workshop and load up to go racing tommorow. And no drive.
Feck.
So, by this time completely knackered from rushing around, and after lots of energetic swearing, we got stuck in and ripped it all back out in about
10 minutes. Only to find the clutch pressure plate has died and there's no way of fixing it or getting a new one in time for tommorow.
I am just very slightly annoyed. A little bit. About a hairs-width away from setting the thing on fire.
So, we missed that event, but at the next one, we did this:
Unfortunately, 2 laps in, the engine blew up again. Should have guessed what the slow starting was, sigh....
[Edited on 9/8/13 by PhillipM]
PhillipM
posted on 9/8/13 at 09:38 PM |
And some more pictures:
![](http://img.photobucket.com/albums/v89/Rippthrough/7477523130_7f87a14c58_z.jpg)
