<<  1    2    3  >>
Author: Subject: My Shiny New Panther!
G.I Ginge
posted on 5/3/14 at 08:18 AM Reply With Quote
ARGH! I need some help please guys. I've been driving the car around quite merrily for the last few weeks and it has performed faultlessly. However, this morning I went to start the car and couldn't!
I can turn the key in the ignition for two 'clicks', i.e. I can get the battery switched on, but the key will not turn any further to get the motor started. I've got no idea why this could be! Is it the immobiliser? If so, how do I fix it? I'm totally gutted that this has happened because it was working perfectly just this weekend. Any advice much appreciated.
eddie99
posted on 5/3/14 at 09:44 AM Reply With Quote
Give me a call mate on 07590 804865 and see if I can help diagnose it
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
G.I Ginge
posted on 5/3/14 at 02:56 PM Reply With Quote
OK, thanks Ed. I tried you this afternoon, but you phone was off. I'm going to go home and have another try- perhaps it was something to do with the cold... Don't think so, though...
G.I Ginge
posted on 27/4/14 at 05:26 PM Reply With Quote
Hi again, it's me- the total imbecile that knows nothing about the kit car he's bought! Except that it's awesome, of course
Anyway, my next ultra-newbie question is can someone please identify the name of the bushing in my picture? I'm pretty sure it's on the end of the tie rod, but I could just as easily be COMPLETELY wrong about that. All the other bushes on the front suspension seem to be holding up well, but (as you perhaps see in the picture) these bushes are perishing on the driver and passenger side, so I want to replace them with some poly bushes. However, those things are expensive and I don't want to spend a tonne of money on the wrong ones!
Any help much appreciated.
Ah. Despite linking up the picture it doesn't seem to want to display. You can right click on the icon and open it in a new tab or just check out the picture in my photo gallery. There's only two pictures in there!
[Edited on 27/4/14 by G.I Ginge]
G.I Ginge
posted on 27/4/14 at 06:06 PM Reply With Quote
Anybody?
me!
posted on 27/4/14 at 06:25 PM Reply With Quote
They're not bushes, they're protective rubber boots covering ball joints. You should be able to buy some replacements pretty cheaply, you'll probably need a ball joint splitter of some description to get at them though.
The boots should be filled with grease to keep the joint lubricated, if they've been like that for a while you may need new track rod ends- this will be obvious if they feel like s*** when you get them apart.
G.I Ginge
posted on 27/4/14 at 06:32 PM Reply With Quote
Thanks for the info. Some more pretty basic questions:
What's a ball joint splitter? What's to stop one from just putting something in there to pry the ball joint apart?
When you say 'feel like s**t'- can you be more specific? Should the track rod end just be smooth and rust free or is there more to is than that?
Many thanks!
me!
posted on 27/4/14 at 06:49 PM Reply With Quote
Many thanks!
There are a few different types, but they all pry the joint apart- see here for three different ones (if the link works) http://www.halfords.com/webapp/wcs/stores/servlet/SearchCmd?srch=Ball+joint+splitter&action=search&storeId=10001&catalogId=10151&langI d=-1
The joint you split is a taper fit into the upright, not the ball joint itself (you push the threaded end down through the hole in the upright).
I normally avoid using the fork type as they tend to destroy the boots- not so much of a problem if you are replacing them anyway. Having said that they are very effective if you get a difficult ball joint- I've had them defeat my scissor type splitter and the fork do the job in a couple of hits. When you split the joint leave the nut on a few threads- they tend to go with a bang! You can do it with a lever and a hammer, or even just a couple of hammers, but I've not tried to be honest.
The joint should feel smooth with zero play- any notchiness or movement and they need changing.
me!
posted on 27/4/14 at 06:54 PM Reply With Quote
Ps the rubber boots are held on with wire clips wound around the rubber. They are like a key ring but thinner gauge wire. Remove these carefully and reuse when you replace the boots.
G.I Ginge
posted on 27/4/14 at 07:08 PM Reply With Quote
Thanks again for the sage advice.
The new boots I've ordered come with replacement clips, so no need for me to be careful, I hope. I'm learning as I go here, so delicate work presents an issue when you've got only the barest inkling of what you're doing!
I shall certainly look into the splitter and shall inspect the rod ends carefully when I change the boots.
One last question: will I need to get my tracking aligned after I do this work? It seems like probably not, but it never hurts to ask.
me!
posted on 27/4/14 at 07:37 PM Reply With Quote
If you just change the boots it'll be fine
G.I Ginge
posted on 27/4/14 at 07:54 PM Reply With Quote
Great thanks very much. I hope all shall go well!
G.I Ginge
posted on 19/7/14 at 07:49 AM Reply With Quote
(Sigh) So after my big talk of 'if it ain't broke don't fix it' the car IS now broken and I do need to fix it. I'm having an issue with the battery/ alternator/ wiring. All the slashes are because I have no idea which. I'm hoping I can tell the collective what I have done so far and you guys can give me some tips about what I can try next:
1. A couple of weeks ago I had to booster start my car. When I went to use it the time after that it would not start and I had to charge the battery.
2. Took car to a mate's house to sort out a small issue. When I tried to start it, battery dead again. Partially charged the battery- enough to get me home.
3. Test-started the car every day for the next four days. Just starting the car, letting it run for a minute, then turning it off again. All seemed to be fine.
4. On the fifth day, I took the car to work. Got me there fine, but when I tried to go home, battery was flat again. Jump started the car, but it still conked out on me on the trip home. TWICE. My wife was not impressed having to come out and jump start me in rush hour.
5. My digi-dash has a voltmeter reading. It was always below 10v during that trip home (which I know is not good) and was slowly dropping as I drove and dropping sharply if I kept my foot on the accelerator.
All this makes me think it's an alternator issue. The battery held a charge for four days but driving the car is draining the battery and nothing seems to be filling it back up. Ed also told me that the alternator 'only charged the battery at higher revs' when he sold me the car which could be an indication that it was already on its way out? Either way, how can I test this for sure? If I need a new alternator what should I get? The engine is a ford 1.8 blacktop.
Many thanks for any responses- I know this is basic stuff but I'm just a newbie!
[Edited on 19/7/14 by G.I Ginge]
G.I Ginge
posted on 19/7/14 at 03:23 PM Reply With Quote
Bump! Any help would be MUCH appreciated guys... I'd really like to try to find my way towards a definite solution by the end of the weekend.
maccmike
posted on 19/7/14 at 04:23 PM Reply With Quote
Starting the car 4 days in a row and allowing it to idle wont recharge the battery. Its likely youve drained it more.
Run the engine at a couple thou revs and let us know what the multi meter reads straight off the battery.
Youve probably just got a tired battery.
Invest in a trickle charger.
G.I Ginge
posted on 21/7/14 at 07:37 AM Reply With Quote
Back up one or two steps there please:
1. Multimeter? What are we talking about here? Is that another tool I need to buy?
2. If it's just a 'tired battery', what does that mean and why would charging it with a trickle charger be beneficial?
3. My biggest question is why even a 'tired battery' would have enough juice to start in the morning, then be flat by the time I reached work 45 minutes later? Surely my alternator should have juiced up my battery enough in that time to start the car again if it were working? Also, why was the voltage reading steadily dropping whilst I was driving if the problem is the battery? Shouldn't the alternator be taking over the power supply once the car is running, with the battery just acting as a capacitor?
Many thanks for the reply.
INDY BIRD
posted on 21/7/14 at 08:10 AM Reply With Quote
as said you need to check voltage with multi meter,
this kind of item
link
http://direct.asda.com/george/george-home/draper-digital-multimeter-52320-16-functions/001240572,default,pd.html&cmpid=ppc-_-ad-pla-_-ggle-pla-_-H ome-_-001240572&cm_mmc=ad-ppc-_-ggle-pla-_-Home-_-001240572&istCompanyId=71f4ae42-94c5-4821-aa58-05eff6da2486&istItemId=axxxiraa&istBi d=tztx
you can then put it on a setting like 20v to determine what volts you are getting, ie on idle around 14.2 volts and higher with increased rpm,
also is the battery light on? or all connections made as this will also not make connection to alternator and wont charge or see correct voltage?
if you are getting below 12v it will be draining the battery,
if above 12v then its prob a dud battery and as stated above dont do run the car for short periods as drains battery and invest in trickle charger its better for the battery,
best of luck
G.I Ginge
posted on 21/7/14 at 08:36 AM Reply With Quote
Thanks for the reply. I shall go and get a multimeter today or tomorrow and get back with some readings.
The battery light is a funny one. It always comes on at ignition, no matter how full the battery is, but the light goes straight off as soon as I rev the car above about 3000 revs. Strangely, though, the light turns off after revving the engine no matter how low on charge my battery is, i.e. the light switched off 'as usual' on Friday even though I know the battery was critically low because the car cut out, due to lack of power.
I will try to check the alternator connections today. Is there anything that commonly comes loose that I should look out for?
daveb666
posted on 21/7/14 at 11:17 AM Reply With Quote
Read up on what a battery light is/does here:
If, on driving and even idling your battery voltage is not above 13.3/13.4volts then there is a problem with something in the charging circuit which is likely to be:
1 - Alternator belt has come off
2 - Alternator plug/wires have come off
3 - Alternator bushes are worn (easiest to buy new alternator)
There is the potential for other wiring issues but it's most likely to be one of the above though.
G.I Ginge
posted on 21/7/14 at 03:58 PM Reply With Quote
Thanks for your ideas. The link you tried to post seems to be missing, but I'm sure I can do battery light research on my own.
I've had a quick look at the alternator. Irritatingly, it appears to be in good nick! I was hoping for a simple solution... The belt is definitely still on- tension seems reasonable. The wiring appears to be as it should be, but I'm going to strip all the tape and stuff off later to properly inspect it. I'm waiting for the battery to reach full charge before turning it all on again so the meter readings are reliable, but when I do I shall see whether the alternator seems to be working properly as well.
G.I Ginge
posted on 22/7/14 at 02:22 PM Reply With Quote
Having done more testing, I am, if anything, more confused. I couldn't buy a multi-meter at my autoparts shop- they were out of stock. Instead, I bought a Gunson Startcheck device like this:
Gunson Startcheck
as it purported to test the function of the battery and alternator, which is just what I need.
Just to make sure the tester was functional, I tried it on my little Ford fiesta. When started, the 'battery charging 75-100%' light and 'Alternator O.K.' lights both come on straight away. I swapped the battery in the Fiesta with the one from my kit car and it too read as working fine when installed in the Fiesta, so the issue is certainly in my kit car.
When plugged into my kit car, power off, it reads 'battery charging 75-100%'. When powered on, the reading changes to 'battery charging 25-75%' and does not improve after a few minutes of revving to different rpms and idling. Neither alternator indicator light comes on on the Startcheck device, which, the instructions tell me, indicates an alternator issue. I also put the Fiesta battery into the kit car and it read exactly the same way.
Whilst running at idle, the voltmeter on my car read 11.9, which I know is low. When I revved the car, switched the lights+fog lights on, the indicators, etc, this number dropped to about 11.2. When I went back to idle and turned the devices off, the reading went back up to 11.8. Does this mean anything conclusive to anybody?
Where do I go from here? All I've managed to figure out is that I definitely don't need a new battery (I think!). I've tried looking at the alternator wiring- I found two big brown cables coming out the back, which both go to the positive terminal of my battery, and a small blue wire, which disappears into the car's internals, presumably the battery light sensor? The big brown wires, it seemed safe to assume, carry the juice to the battery. They are very solidly attached at both ends and the tape wrapping around the remainder of the wires remains intact and unscuffed anywhere, indicating that they are still in one piece. Should I check the blue wire? What else can I check?
As I said, the alternator appears to be in good condition. It is clean, the power leads appear to attach well, it spins around quite happily when the engine is on and makes little discernible noise when functioning (or possibly functioning). WHAT AM I MISSING!? I'm too skint to buy a new alternator if I don't need one- I've got to find a way to verify the problem for sure before I pay out to fix it.
[Edited on 22/7/14 by G.I Ginge]
matt5964
posted on 22/7/14 at 04:19 PM Reply With Quote
you wont need a battery if you have confirmed the kit car battery is functioning ok in the fiesta.
must be either wiring issue in kit car or alternator failed.
If you have cheques the wiring both ends then that points to alternator failed.
have you cheque the other electrical circlets on the car to see if there is a loose connection, short or drain there (lights ,starter, ignition, instruments etc.).
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
matt5964
posted on 22/7/14 at 09:02 PM Reply With Quote
Nippon Denso Light Weight Competition Alternator 40 Amp
datsun / nissan alternator built in reg powerfull small unit ideal kit car etc
MikeR
posted on 22/7/14 at 09:22 PM Reply With Quote
Quick question ......
What did Eddie build the car for?
Its possible to wear out an alternator by continual running at very high revs, the solution is to change the pulley on the alternator so it spins slower. This means at low revs it doesn't charge the battery and at high revs it charges it normally.
(before someone comments about 'wear out' i'm trying to keep it simple)
Its possible you've got a modified alternator or a generally broken alternator.
Macbeast
posted on 22/7/14 at 10:28 PM Reply With Quote
In your first post you said the trouble started after you had to boost start the car. I would suspect that fried the alternator.
But, before you replace it, there could be a very heavy-duty fuse ( 80 A or so ) in the feed from the alternator to the battery. I should check that first.
<<  1    2    3  >>
