DIY Si
posted on 16/11/14 at 08:52 PM |
Do you have to use the big ally blocks/mounts? Are they integral to the AV mount you have to use? If they can be replaced somehow you could use a
mount shaped something like mine, but higher up on the block.
Sun Tzu, The Art of War
KFC
posted on 16/11/14 at 10:59 PM |
They are expensive to replace. I have to use them as it's easier and the steering column is badly placed for this mod. The gap at the minimum
between the column and the mount is 30mm.
The subframe is heavily corroded as they seem to be.
v8kid
posted on 16/11/14 at 11:32 PM |
quote: Originally posted by 40inches
Good luck unscrewing the large banjo bolt on the engine mount. That is one tight mother
You are not kidding I just sheared a halfords pro 0.5" extension with the strongarm getting it off. Anyhow good tips I think I'll copy
you
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
DIY Si
posted on 17/11/14 at 08:51 AM |
Given that you're looking at a plate on a mount onto an AV mount, I'd do away with all three and make something better/less complicated.
Can the bit that bolts to the subframe be easily removed? If that were replaced with a poly bush type mount you'd get a better angle up to the
block or maybe go higher up the block and still clear the column. The other option is to have something like the existing AV mount, but angled in
towards the engine. That would give much better clearance and allow you to angle it up the block. It would also lessen the twisting motion put into
the mounts as they are now as the force would go more directly into the rail rather than above it.
OK, it would mean the money you've spent so far is wasted unless you can sell the bits on, but it's what I think I'd do with that
set up. It's a cleaner solution and works round the problems so far.
KFC
posted on 17/11/14 at 01:10 PM |
Yeah that sounds like a good idea but the hours involved with that alone is far too much for me. With all the other mods to get where I am now
I'm guessing it would be at least 100 hours. I want to drive this car by the spring, not be an ongoing project. I really enjoy the challange and
at the same time knowing I'll be driving it soon is exciting. I want this to be a conversion that will use as many standard parts as possible so
that maybe others can do it well, sell my adapter kits.
Anyway, I think we should get back to the thread title, how about a supercharger?
v8kid
posted on 17/11/14 at 01:19 PM |
This thread has wandered so much I've lost the plot as well The title was jag V6 weight !
Cheers!
chainsaw
KFC
posted on 17/11/14 at 03:33 PM |
Cheers!
Oh yeah, I might have another thread about more power, displacement..
DIY Si
posted on 18/11/14 at 06:32 PM |
In which case, I would get it going as it is and then look at improving the design down the road. Just don't expect to sell too many kits if
others can look at something and see a way to simplify things, as that's what they'll do. Any kit needs to make doing it another way cost
more or folk will just do it the other way. It's part of why I never looked at buying in my ITB set up. Most things that I can buy, I can make
at least as well as I view my time as free, whilst others will quite rightly want paying for theirs! This means I can do things like spend hours port
matching in a way that you just wouldn't pay someone else to do for such marginal gains.
And 100 hours is nothing!! I've probably spent near that that just researching bits for my front suspension before I put angle grinder to metal.
I know my rear suspension has taken at least twice that, if not way more. But counting hours is dangerous on a hobby!!
KFC
posted on 18/11/14 at 10:25 PM |
True but I don't want to spend all my time in the garage like I am at the moment, I do like other fun in my life. The only kits I want to have a
go at selling is the RX8 gearbox to klde V6 adapter plate with moded flywheel to complete the pairing.
DIY Si
posted on 19/11/14 at 01:03 PM |
In which case I wish you the best of luck!
CosKev3
posted on 19/3/19 at 10:30 AM |
Just weighed the AJ30 going in my car
Engine with sump on,
ST200 inlet manifold,
Small denso alternator,
ST200 solid flywheel,
RX8 gearbox adapter plate,
130kg.
Engine complete with 6 speed RX8 gearbox and updated Mondeo 240mm clutch,
183kg.
Engine with Denso alternator on,
119.7kg.
[Edited on 19/3/19 by CosKev3]
spegru
posted on 4/3/21 at 08:33 AM |
so pleased to find this data as this AJ30/RX8 combo is almost exactly what I have nfor my Gilbern Invader.
What I'd really like is some relaible weight data on the original setup which was Ford Essex & Type F box.
PS what 'update' did you do to the clutch flywheel for the Jag/Mazda combo?
[Edited on 4/3/21 by spegru]
CosKev3
posted on 4/3/21 at 08:15 PM |
Cut the starter ring gear off the AJ30 auto flywheel,had the ST200 ring gear machined down into a 4mm spacer then fitted the AJ30 ring gear onto the
ST200 flywheel, you can then use the AJ30 starter.
The other way which big_wasa off here has done is swap the bendix out of a Ford starter into the AJ30 starter,then redrill the RX8 adapter plate to
move the starter motor inwards so it works with the standard ST200 flywheel
posted on 5/3/21 at 07:15 AM |
Gilbert Invader, there’s a blast from the past. The first kit car I ever helped build around 1971 , much nicer than a Reliant Scimitar . Good luck
with your conversion
spegru
posted on 5/3/21 at 10:06 AM |
Thanks for the thoughts Rustynuts. I don't know whether there is any way to tell if it was originally a kit or not - but it certainly is now!
In fact it has replaced my Scimitar - which I thought was a bit too big and heavy.
CosKev3 did you use a standard dual mass flywheel? I'm unclear if an ST200 is any different to be honest
thanks
spegru
PS you can see me messing around with this project here: https://www.youtube.com/results?search_query=spegru%27s+garage
CosKev3
posted on 5/3/21 at 10:47 AM |
thanks
spegru
No ST200 is a solid flywheel and way lighter than a dual mass
spegru
posted on 7/3/21 at 07:18 PM |
Thanks coskev3
To be honest I'm quite unfamiliar with these so I just did a quick search on ebay
I found this:
https://www.ebay.co.uk/itm/BF-FLYWHEEL-BRAND-NEW-20090225661/284180011393?fits=Model%3AMondeo%7CCars+Type%3A2.5+ST+200&epid=12028232024&hash=i
tem422a72d981:g:sLcAAOSwyahgJEAA
Does that seem correct?
thanks
spegru
big_wasa
posted on 7/3/21 at 09:02 PM |
It doesn't look correct to me. But it's a bit hard with the info on there.
CosKev3
posted on 8/3/21 at 02:47 PM |
It states it weighs 32kgs!
As above unless they can send you pics of the exact flywheel its hard to say
mgb281
posted on 17/3/21 at 08:00 PM |
The generally accepted weight of a 3.0 Essex engine is 400 lbs, some sources say 379lbs. To put it into perspective the weight of a 1990's Ford
302 V8 is circa 425lbs complete less fluids.
big_wasa
posted on 17/3/21 at 08:38 PM |
Wonder what a Cologne weighs ?
That’s what mine will be replacing.
big_wasa
posted on 17/3/21 at 08:44 PM |
So the Duratec 30 isn’t much heavier than a Zetec. Felt like it pulling it out of the mondeo.
mgb281
posted on 17/3/21 at 08:51 PM |
The Cologne is lighter than the Essex, bear in mind the Essex was originally designed to have a diesel version, again the weights are all over the
place, some will be for OHV and others OHC but 365lbs is a good figure to use.
spegru
posted on 18/3/21 at 12:20 PM |
I just invested in a weight scal to attach to my engine crane.
So I can confim the weight of the AJ6 complete with Alternator, AC compressor large Jaguar inlet manifold but no flywheel per se (only an auto box
starter plate) - plus the RX8 adaptor plate previously discussed
162.5kg
I also weighed the R8 6 speed gearbox
42.8kg
mgb281
posted on 19/3/21 at 09:00 PM |
I think that you will find that either a five or six speed RX8 gearbox will weigh 50kgs, I have weighed several on different scales and they have
always weighed 49/50/51 kgs. The variation maybe the scales or just some had oil and others did not.
