<<  1    2  >>
Author: Subject: Soapbox go kart build
posted on 23/12/15 at 05:00 PM Reply With Quote
This is no. 1 boy's go-kart, smaller wheels and a bit slower, but very stable and safe.
MikeR
posted on 23/12/15 at 06:56 PM Reply With Quote
Guy Martin did one, if you watch that program he explains the principles.
ken555
posted on 23/12/15 at 08:53 PM Reply With Quote
I wish there was something like this near Aberdeen, looks good fun
Deeside Speedfest
I plan to be going the other way for the hillclimb if you need a tow to the top.
[Edited on 23-12-15 by ken555]
dmac
posted on 23/12/15 at 09:15 PM Reply With Quote
Originally posted by nick205
I opted for wheelchair wheels on the front as they're designed for single side mounting. I fabricated the steering with castor and camber in favour of swing arm steering as the latter seems to foil others to good effect.
Trike rear wheels are designed for single sided mounting, or alternatively re-spoke the wheelchair wheels for a larger/narrower rim.
Dmac
posted on 24/12/15 at 08:55 AM Reply With Quote
Dmac
The wheelchair wheels weren't cheap and a fellow LCBer helped immensely by collecting them and delivering them for me!
They are strong and have good bearings too - I fabricated the steering uprights for them. Hard work, but they worked well and made for good steering too.
posted on 24/12/15 at 11:00 AM Reply With Quote
No. 1 boy's go-kart was derived from this, although a pretend V8 motor would have been nice they were quite pricey at the time...
ETA...I even copied the rear hinged suicide doors as well and my neighbour donated a GRP cart seat to finish it, which really helped!
[Edited on 24/12/15 by nick205]
StevieB
posted on 24/12/15 at 10:32 PM Reply With Quote
Could you use a bit of suitably sized steel flat bar across the chassis to act as suspension, in a similar vein to cooper 500 single seaters? It'd be very crude, but coupled with a simple damper might be all you'd need (like a boot lid damper or something).
[Edited on 25/12/15 by StevieB]
ettore bugatti
posted on 25/12/15 at 05:37 PM Reply With Quote
Maybe streamlining is worth pursuing?
Wide front track, narrow rear track put into a streamlined monocoque shell?
<<  1    2  >>
