Samuele
posted on 10/8/16 at 08:44 AM |
I saw that there are also alternatives to the RS2000 and are also made of aluminum.
my question and especially if it goes in the tunnel.
whells are from citroen and they are aluminum 4x108 6x15 et18.
4,6kg Piece.for this size have an excellent weight.
much less than the super expensive OZ.also why I bought several
[img]http://[/img]
Sundaydriver
posted on 4/10/16 at 04:23 PM |
Great thread, any updates
Striker Light !
Samuele
posted on 23/10/16 at 08:57 PM |
I had to change my plan of construction.
so I spent some time in new pieces.
I'll use it for steering as aircraft aluminum metal.
and a bar of 18mm in titanium.
the supports for steering are also of the same aluminum.
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Samuele
posted on 23/10/16 at 09:03 PM |
in the meantime, after doing some tests on welding aluminum I decided not to buy the petrol tank.
but to build it myself.
They will use aluminum 2mm thick.
a question but I would l:
the fuel pump inside the tank or external to the better?
[img][/img]
[img][/img]
Samuele
posted on 25/10/16 at 08:17 AM |
Today I received back the pieces anodized for the gear lever.
also in this case I used gr5 titanium and aluminum aircraft to maintain the lowest possible weight.
[img][/img]
rdodger
posted on 25/10/16 at 09:56 AM |
These parts you are making look amazing!
Regarding the fuel pump I would make it internal with an integrated swirl pot, just to make packaging easier and neater and in the end cheaper as only
1 fuel pump.
I guess final choice would be down to engine choice. If it's to be BEC then most use the bike pump.
I used one from a Range Rover on my build.
Range Rover Classic 86-92 V8 EFI Fuel Pump PRC8318
It was easy to extend to fit the tank and was easily man enough for 250bhp supercharged engine.
Samuele
posted on 29/10/16 at 05:15 PM |
thanks for the reply.
I'll try this option then
Samuele
posted on 29/10/16 at 05:20 PM |
After several weeks of measurements, drawings and preparations I finally started the frame.
the result and good up to this point.
Now to move on I need more pieces from England.....
[img][/img]
[img][/img]
peter030371
posted on 29/10/16 at 07:58 PM |
Wow, you certainly have access to all the tools!
Samuele
posted on 29/10/16 at 08:32 PM |
this is my luck
MadMaxx
posted on 30/10/16 at 07:44 AM |
Realy very nice rebuilding. If it could of help, here some photos of my Fury chassis rebuilding from an italian forum with the full story still under
progress:
http://www.llcc.it/YetAnotherForum.NET/default.aspx?g=posts&t=13448&p=18
I decided for a new improved chassis when I found the original one had some cracks and visibile distorsions. Some tubes added to increase the
torsional rigidity and avoid tipical cracks of the standard chassis.
My re-building diary:
Samuele
posted on 30/10/16 at 03:11 PM |
progress:
thanks for the advice.
I still intend to introduce at different points of the frame reinforcements
Samuele
posted on 30/10/16 at 03:17 PM |
meanwhile other works which proceed temporarily to the construction of the frame.
Yesterday I received the radiator
and the throttle body and ready to be mounted
[img][/img]
[img][/img]
obfripper
posted on 30/10/16 at 08:22 PM |
A bit of late call, have you still got those red hubs for sale?
Are they for the standard mk2 escort (not rs type hubs) & do they match the dimensions on this diagram?
If so, how much do you want for them including shipping?
Dave
Samuele
posted on 30/10/16 at 09:12 PM |
Dave
I'm afraid I have already been sold
Samuele
posted on 31/10/16 at 08:22 PM |
finally start taking the right forms ...
[img][/img]
[img][/img]
[img][/img]
peter030371
posted on 1/11/16 at 09:03 AM |
Are you getting all the measurements from the old chassis?
Samuele
posted on 1/11/16 at 03:43 PM |
I've taken the measurements from the old frame.
Fortunately it seems that the frame that I was done well and was not ever changed.
In fact, the measures are almost symmetrical everywhere.
except for the tunnel and the guide side.
I can try more in the bodywork and the like to be sure that everything is fine.
Samuele
posted on 1/11/16 at 04:12 PM |
progress:
you have a U2U
MadMaxx
posted on 1/11/16 at 04:40 PM |
Replied
yogibear1969
posted on 1/11/16 at 06:30 PM |
The tunnels on Sylva's are not central, be careful.
Edd
Samuele
posted on 1/11/16 at 07:06 PM |
Edd
I seem to have written that the tunnel is not symmetrical.
maybe they do not and understand it.
Many thanks anyway of warning.
tims31
posted on 2/11/16 at 01:36 AM |
Sammi,
Are you still needing the measurements for the gearbox mounting plate, I'll be in the garage tomorrow and will try and get them for you if you
do.
Martin
Build: http://www.martinsfurybuild.co.uk/
Samuele
posted on 2/11/16 at 08:14 AM |
quote: Originally posted by tims31
Sammi,
do.
Martin
Thanks Martin,
I speak of this point as seen in the photo.
I would like to know roughly what position is this support for the change.
that of the 4-speed gearbox seems very moved forward
[img][/img]
tims31
posted on 2/11/16 at 07:14 PM |
Sent you an email Sammi with the dimensions, hope they are what you need.
Martin
