<<  1    2    3    4    5  >>
New Topic New Reply
Author: Subject: Who used the GSXR Throttle bodies?
paulf
posted on 14/1/05 at 10:33 PM Reply With Quote
I called a breakers today and as soon as i said i wanted a set of gsxr 750 bodies for a car he said £180 +vat and non negotiable.Needless to say i didnt bother.
I am now thinking about my original plans to make patterns and get some cast , I can machine them myself but have to decide on what bore size to use.
It seems as if i may be able to produce them for a price in the region of £200 a set for the basic bodys plus the linkage.They would be individual bodys with weber flange sizes, and an air bleed adjuster on each one.
Paul.
Originally posted by Rob Lane
I see on Ebay that prices have doubled for Tbs now!
[Edited on 14/1/05 by Rob Lane]
ady8077
posted on 14/1/05 at 10:40 PM Reply With Quote
Hi Guys
Thank for the help, I'll dig the camera out tomorrow and see if i can upload a pic
As for prices i got mine off ebay £75 this week, the same sellers got some more
ebay item 7946290246
Adrian
forgot to say mine are 750's have to try and find out about injectors
[Edited on 14/1/05 by ady8077]
Browser
posted on 14/1/05 at 10:57 PM Reply With Quote
For info, I asked one breaker what bore size the 750 bodies are and the reply was 42mm. I know from previous chat on this that the 1000 bodies are 44mm dia.
DEAN C.
posted on 14/1/05 at 11:17 PM Reply With Quote
Adrian,thanks a lot for telling everyone and his dog about the item I happen to have the highest bid on.
Unless you are are willing to pay £150 + dont bother bidding against me as they're exactly what i'm after.
Anyone play poker?
I'll warn you I used to make a living buying cars at auction every week!
Once I've finished a project why do I start another?
posted on 15/1/05 at 12:32 AM Reply With Quote
Anyone play poker?
Then you'll know when to give up if some fool goes into a bidding frenzy!
DEAN C.
posted on 15/1/05 at 01:10 AM Reply With Quote
Bring it on!
DEAN C.
posted on 15/1/05 at 01:12 AM Reply With Quote
I'll let you know the results!
stevebubs
posted on 15/1/05 at 03:10 PM Reply With Quote
Originally posted by ady8077
Hi Guys
Adrian
Standard Car injectors can be fitted, but you'll need to remount the fuel rail.
Stephen
PS The US Ebay Site is where I got mine from - less than £100 *including* shipping from the US.
stevebubs
posted on 15/1/05 at 03:15 PM Reply With Quote
I don't think the injectors would cope with your fuel requirements for 1600cc or above, they are for 600cc bike engine if GSXR 600.
You be surprised - don't forget that they are designed to flow much faster due to the bike engine revving much higher, e.g. a if Gixxer 600 has a redline of 11k RPM then you'll be able to run a 1200cc car engine at 5.5k RPM without stressing the injectors anymore than they are in the bike.
(PS don't actually know what the Gixxer engine max RPM is)
Northy
posted on 15/1/05 at 04:22 PM Reply With Quote
Right guys, I could do with some advice. Which would be the better throttle bodies to fit to an xe? GSXR, Blackbird, or other? Anyone know any websites where someone has done this to an xe?
You've got me thinking now guys......
Graham
ady8077
posted on 15/1/05 at 04:50 PM Reply With Quote
HI
Have a look at
http://www.jenvey.co.uk/~Tech_QA.htm
The gsxr ones are tappered, mine are 48mm in, 42mm butterfly and 40mm out
Adrian
Rob Lane
posted on 15/1/05 at 08:43 PM Reply With Quote
I'm still waiting for my Megasquirt kit to turn up. I've already done one but sold it all, now I will build another and program it with MS Extra for the Toyota. This will have cold start and other more desirable items in it!
I've searched on gixxer injectors and found the value as 95cc for the GSX-R600.
This is well down compared to the 4age car engine which has 200cc injectors. Most engines have an average around 250cc and are uprated for tuned applications.
I've also found this blurb :-
Quote-----
"Peak torque is now listed as 3 percent stronger. This is achieved in part
by the use of a new fuel injection system, which is 370 grams lighter
than last year's. Where the 03 used four, single-barrel throttle bodies,
the 04's feature dual, double-barrel units with Suzuki Dual Throttle Valve
(SDTV). Containing two butterfly valves inside the throttle body, the
primary is controlled by the rider, the secondary by the bike's smaller,
lighter Electronic Control Module (ECM). Reading information from
sensors located on the crankshaft, the gearbox and the throttle, the
ECM uses a stepping motor. This opens and closes this secondary
butterfly, depending on the engine rpm, the gear position, or how much
throttle the rider is dialing in. The result is a feel that is similar to that of
CV carburetors, allowing the bike to pull strongly from as low as 6000
rpm. Pretty amazing when you think it revs to 15500 rpm!"
---------End quote
That explains the dual butterflies then
ady8077
posted on 15/1/05 at 10:36 PM Reply With Quote
From searching the web a gsxr 750 can have anything from 120 to 141 bhp, i'm only hoping to get my pinto to 150 so i'm hoping mine are from the more powerfull ones
As for your's Rob have you seen
http://venus.13x.com/roadracingworld/issues/apr00/gsxr.htm
Theres a good diagram of how the twin butterfies work
Adrian
Rob Lane
posted on 16/1/05 at 09:42 AM Reply With Quote
Bears out what I said on my original post regarding smooth transition when throttle opened, even mentioned accelerator pump enrichment.
I looked at the 'motor' and thought it must be current variable, I didn't see it as a stepper motor but a linear version of same.
I'm making up some ali blanking plugs to fill in the injector ports and the butterfly spindle holes.
paulf
posted on 16/1/05 at 04:53 PM Reply With Quote
Ive just won a set of gpz1100 throttle bodies on Ebay.I didnt know what bore they were but have just established that they are 34mm bore and fitted with 180cc injectors. Any views on whether they will be ok on my lightly tuned 1600 crossflow?
They do seem to be very popular for bike conversions as they are easily split, the injectors are the same as nissan 200sx.
Paul.
ady8077
posted on 16/1/05 at 06:03 PM Reply With Quote
Hi Paul
Depends on what bhp your after
I was recomended 300cc's for 200 bhp
Adrian
ady8077
posted on 16/1/05 at 06:06 PM Reply With Quote
Does anyone no what other car injectors will fit the gsxr bodies?
Just been told on the sevens list that mine are likely to be 190cc, which is a bit small for 150+ bhp
I've been recommended 250cc+
Thanks Adrian
stevebubs
posted on 16/1/05 at 06:07 PM Reply With Quote
I believe Claire Rule on the BEC list ran her Crossflow on these 'bodies without any problems. IIRC, Nissan 200SX goes around 160ish BHP so you should be fine.
Paul.
stevebubs
posted on 16/1/05 at 06:09 PM Reply With Quote
I'm fitting Cossie Blue Injectors with Jenvey rail to my respaced Gixxer750 'bodies.
If you're not respacing then you can probably use the original fuel rail with these, but you'll need to alter the mounts to relocate the rail for the injector inlets.
Thanks Adrian
stevebubs
posted on 16/1/05 at 06:11 PM Reply With Quote
BTW I think the rough rule of thumb is divide by 5 then multiply by the number of cylinders to get the expect engine power.
190cc/5=38
38*4 =152bhp
[Edited on 16/1/05 by stevebubs]
ady8077
posted on 16/1/05 at 06:35 PM Reply With Quote
Hi Steve
Found an sizing calc on the web, but that siad 125 bhp?
As for cossie blue's aren't they a bit big? my DT cat says their 437cc's
Also do they fit the bodies ok? I still have my old pinto injectors and their to big for the hole
Adrian
stevebubs
posted on 16/1/05 at 06:58 PM Reply With Quote
I'm going by a rule of thumb that I know people use. I'm sure there's other, better, more scientific ways (which you calculator is probably using) (bearing in mind divide by 5 multiply by cylinders doesn't take into account where in the rev range the peak power is.)
Light Blues are 400+ccs and are part of a stage 3/4 upgrade.
Dark Blues and Yellows are good for approx 200-250bhp. Think they're about 300cc.
WRT fitting, the blues fitted my GSXR750 rail/inlet holes without any issues (see pics on Page 1). However, the seal is created by the rubber O-Ring. Different sizes of o-ring may allow them to fit your bodies and rail without drama.
stevebubs
posted on 16/1/05 at 07:07 PM Reply With Quote
BTW I am not an expert on this...just relaying bits I've picked up over the last couple of years.
I'd definitely ask the same questions on the Megasquirt forums at http://www.msefi.com/. There's a number of *real* experts there!
Good article on injector sizing here
Looks like you're right - you'll either need slightly bigger injectors for 150bhp, or run the fuel rail at a slightly higher pressure than normal.
Stephen
ady8077
posted on 16/1/05 at 07:34 PM Reply With Quote
Just cheaked your pics, they fit the same, thought the O ring had to go in more?
Dont worry I no your not an expert
But its nice to follow someone elses lead
Looks like dark blue cossy's then
Adrian
stevebubs
posted on 16/1/05 at 07:50 PM Reply With Quote
Adrian
So long as you have a good seal then you should be OK.
<<  1    2    3    4    5  >>
New Topic New Reply
