Angel Acevedo
posted on 9/9/18 at 01:40 PM |
Great result!
That shows you learnt from your previous experience...
craigdiver
posted on 9/9/18 at 02:37 PM |
quote: Originally posted by Angel Acevedo
Great result!
Yes Angel, wasn’t going to make that mistake again. Been back to check the paintwork and I can report that the paint has stayed on the car and not all
run off onto the floor!
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
cliftyhanger
posted on 9/9/18 at 06:57 PM |
Was the white 2k paint a cheap ready-mixed colour (as opposed to mixed to your paint code)?
It seems a lot of the ready mixed stuff is just 2:1, it certainly seems thinner than the far more expensivemied to code stuff I have bought.
I had some runs in a hardtop I was spraying for a friend. Turns out it is worth about £1500, and he supplied paint that is £20 a litre. I let it
harden off for 24 hours, flatted with 600 then 800, and wacked another coat on this time without the thinners. Job done....
craigdiver
posted on 9/9/18 at 07:10 PM |
It was colour matched to my GRP nose cone and custom mixed specially for me. The mistakes I made were adding the thinners and spraying too much paint
in one pass.
ArAKern
posted on 10/9/18 at 06:25 AM |
Looking good!
I just finished spraying my phoenix first time DIY. The advice you have been given so far is spot on especially wetting down the floor.
Only thing I would add is read the data sheets for the paint and follow them.
One question did you swap back to a smaller 1.3 / 1.4 needle gun when doing the base coat ? May explain your Niagara falls issue.
Also just expect a fair amount of dust in the clear it cannot be helped.
Ps I learnt from "The Gunman" on YouTube.
craigdiver
posted on 10/9/18 at 06:55 PM |
quote: Originally posted by ArAKern
Looking good!
Yes, switched back to small spray gun with 1.4mm nozzle. Also just mixed paint and hardner - never added any thinners. Watched a few of the gunman
videos - top man, definitely knows his way round a spray gun
