<<  1    2  >>
New Topic New Reply
Author: Subject: Panels
Volvorsport
posted on 27/1/05 at 03:34 PM Reply With Quote
watch this space .
www.dbsmotorsport.co.uk
getting dirty under a bus
Mix
posted on 27/1/05 at 04:11 PM Reply With Quote
I have experience of kevlar used in both structural and cosmetic applications. I would agree that it is a viable, (though probably rather expensive) option for panels. I would not consider it suitable for flooring in its basic laid up form with no other form of protection.
Mick
posted on 27/1/05 at 05:08 PM Reply With Quote
Originally posted by Volvorsport
a fully bonded kevlar floor would tho
GRP --Marine Ply- Grp fully bonded would make a goo floor and rear bulkhed.
kb58
posted on 27/1/05 at 05:29 PM Reply With Quote
Kevlar is lighter than carbon fibre and is cheaper and represents the best kind of panneling if you can work it.
That's the key, if you can work it. We use a waterjet... which isn't much help for the rest of us...
[Edited on 1/27/05 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Volvorsport
posted on 27/1/05 at 07:13 PM Reply With Quote
a GRP bonded marine ply floor would be like having a garage roof underneath ya - sry - i used to GRP roofing .
It would in essence lead us to marcos chassis .
i think using coremat and some good decking paint(polyurethane) would leave a strong and durable enough finish for most of us .
chunkielad
posted on 27/1/05 at 09:30 PM Reply With Quote
I think I'll just use Ally and rivet it!!!!
Sorry to start this guys
I'll double fold into the chassis and fix internally.
Interior panels (OMG did I just say that) will cover them!
kb58
posted on 27/1/05 at 10:24 PM Reply With Quote
Then plan ahead that you have enough room for the rivet tool. It's all too easy to drill holes in a corner where it's impossible to get the head of the riveter into...
chunkielad
posted on 27/1/05 at 10:36 PM Reply With Quote
Good point mate
timmy
posted on 28/1/05 at 12:32 AM Reply With Quote
Another idea on panelling
Has anyone ever considered using polycarbonate (lexan) as panelling on their car? I was planning on building my bonnet out of it, but then thought about panelling the rest of the car in it. It's damn near unbreakable and certainly won't show up any dents like the ali would. And it's lighter (particularly the 1.5mm stuff)
One drawback is you need a brake press to fold the stuff, but once you rivet it on it won't go anywhere.
So you can have a totally clear side panelling if you don't feel like painting it.
kb58
posted on 28/1/05 at 01:37 AM Reply With Quote
1. It's rather soft. 1.5mm would be like a piece of cardboard in rigidity. It won't stiffen the chassis any.
2. It is very temperature sensitive. I have a Lexan interior bulkhead window between me and the engine. Assuming worst case, from freezing to 150deg F or so, the 48" window widtd will change length by 1/4", or about 6mm!!! How will your rivets deal with that.
3. It'll get scratched up easily.
4. It's expensive.
Sorry to rain on your parade, but it's an expensive way to go that you'll probably not be happy with.
[Edited on 1/28/05 by kb58]
chunkielad
posted on 28/1/05 at 09:19 AM Reply With Quote
Maybe welding thin panels is now possible without warpage
Metal Cooler
posted on 28/1/05 at 10:30 AM Reply With Quote
He's gas welding.
You don't get that much spread with mig anyway. If you button weld through 8mm holes you should be able to avoid distortion if your sheet is well clamped.
chunkielad
posted on 28/1/05 at 11:53 AM Reply With Quote
I have a low powered Arc welder (the mig I got died and had to go back)
It'll work to 80 amps and 5mm steel (more than enough for any part of the car) and will go down to 1.5mm (or so it says)
kb58
posted on 28/1/05 at 03:34 PM Reply With Quote
You don't need hi power to weld sheet, just the opposite in fact. You want to put the minimum amount of heat into the sheet to avoid warpage.
How about brazing the panels on? The appeal is that it's less heat, plus the brazing would flow between the panels making them extremely strong, far stronger then welding because of the larger surface area. It also solves the corrosion issue, since the space between the sheets is brazed, it won't rust.
andyps
posted on 28/1/05 at 03:59 PM Reply With Quote
I saw a Lotus 340R (the totally stripped back Elise) which had a polycarbonate body. It was quite thick but teh weight saving it had over the usual fibreglass body was amazing. See more about it here
chunkielad
posted on 28/1/05 at 04:50 PM Reply With Quote
Braising - now there's an idea!!
I will have to get the gear for it though unless I can find someone local.
Watch this space it may just be the way to go!!!
kb58
posted on 28/1/05 at 05:03 PM Reply With Quote
I hope someone who's done it can chime in. My only concern is that brazing an entire sheet onto the car is going to make that portion of the car expand quite a bit. When it all cools down I'm not sure what will happen. Worst case it might end up with ripples. Has anyone tried this?
Dale
posted on 28/1/05 at 05:15 PM Reply With Quote
I would not be too worried about warping the sheet but I think it would cause some warping of the chassis.
Dale
Mark Allanson
posted on 28/1/05 at 07:10 PM Reply With Quote
To braze effectively, you need to get both pieces to an equal temperature. You would need to throw a great deal of heat into the chassis, and very little into the sheet. Brazing heat is cooler, but is spread over a much learger area so the distortion in the sheet would be epic, but you could use you sexy ahotalene to shrink it back. Distortion in the chassis would be a different matter, but it may bring the front end down (most home built chassis's have an upward distortion at the front end).
chunkielad
posted on 29/1/05 at 07:32 PM Reply With Quote
I think I'm gonna start my doing the floor pan with holes and plug welds.
Then, if it works well, I'll do the sides, if not, it won't be too much of a worry for distortion as you won't see it!!!
Dale
posted on 29/1/05 at 09:43 PM Reply With Quote
A tip on the plug welding of your floor pan.
I drilled my floor pan for the plugs and then used an adhesive on the edges of the tubes and clamped in on-- aparently not quite tight enough and to top it off----some of the adhesive ouzed into the holes to make welding a pain in the ass. to put it as politely as possible.
I ended up stitch welding the inside edges of the tubes from inside the car as well just for my piece of mind for safety.
I would not use the adhesive if i did it again-- I would use a sealer on the edges after all welding was done.
Dale
chunkielad
posted on 29/1/05 at 10:05 PM Reply With Quote
Yes mate thanks for that - I was planning on doing a plug weld and sealer anyway if I go that route as it'll make sure that the space between the panel and the frame has less chance of rusting.
Then on the outside, considered a long weld where the body panel and floorpan meet then a tidy up with a grinder and file should make a nice neat job. If the heat doesn't cause any warpage, it'll look great and would maybe even turn the space frame into a semi monocoque.
<<  1    2  >>
New Topic New Reply
