<<  1    2  >>
Author: Subject: More front braking needed
coyoteboy
posted on 10/10/24 at 11:43 AM Reply With Quote
Originally posted by MikeP001
Isn't the larger master cylinder usually on the fronts? The bias bar is biasing pressure rather than movement, larger on the front results in more pressure at the slave side on the fronts as pressure/motion is transferred there from the bias bar. if I remember my hydraulics (double check me, I may well not!).
This might be your problem, if that's how you have it set up?
<<  1    2  >>
