ned
posted on 18/5/05 at 10:34 AM |
James,
I did consider putting the tubes outside the bolts, but then i'd have real issues getting the bolts into the holes and doing them up!!
the horizontalness is as NS Dev says the height of the engine mounts on the block (different on each side of the engine) and the height that the
engine has to sit in the chassis to get clearance for the bonnet..
Ned.
beware, I've got yellow skin
garage19
posted on 18/5/05 at 11:17 AM |
Try Landrover V8 mounts. About 3 quid each and very strong.
Look about the same size as the fiesta ones if not smaller and 36mm thick.
James
posted on 20/5/05 at 03:00 PM |
quote: Originally posted by ned
James,
Yeah, guess so. The tube could always be to the side (front or back) of the bolt hole. Wouldn't make any difference structurally I'd have
thought. If you use socket caps the tube could still be pretty close to the bolt.
James
- Muhammad Ali
ned
posted on 20/5/05 at 03:04 PM |
i do plan on using socket caps, but didnt have any to hand when cutting the angled ends of the tubes, so i may have been a bit generous with the gaps
skippad
posted on 21/5/05 at 09:24 AM |
I did mine like this
They were cut down Nissan tie bars(i think) Hard rubber very little movement and light!
Bugger pic didnt load up!
Ill try again
[Edited on 21/5/05 by skippad]
skippad
posted on 21/5/05 at 09:27 AM |
Try this![](http://locostbuilders.co.uk/upload/a215906-Image(081).jpg)
