Marcus
| posted on 23/5/05 at 05:05 PM |
What about the curved bits from rear shock/rollbar mounts to top of chassis to follow wheel arch?
Marcus
Marcus
Because kits are for girls!!
Mark Allanson
| posted on 23/5/05 at 05:46 PM |
But then again, it may not
Avoneer
| posted on 23/5/05 at 07:09 PM |
Radius is biger at the bottom and I can do the fibreglass thing and will be spraying the rear arches...and they will fit when i'm done!
Going to use Stuart Taylor rear arches so I don't need to put in the cuved bar for the front top quarter of the rear arches.
With regards to the towing loops, can I weld two small tubes through the bottom chassis bars at the front and back of the car and then just bolt on
one of those hoops for an aerial mast as and when it is needed?
Pat...
