<<  1    2    3    4    5  >>
Author: Subject: Quick update on Mini
R1minimagic
posted on 8/1/06 at 01:29 PM Reply With Quote
Any new progress on the mini??
welderman
posted on 8/1/06 at 10:35 PM Reply With Quote
update
Breif update after today. Finnished welding fuel tank up, made a Z-cars style tubular inside bumper thingy(Anti intrusion / crash bar which has brackets for fixing the radiator. )From Z-cars site.
Fixed my polo gti radiator to that. stuck(literally) front wing assembly on with Duck tape, put bonnet on. Did a bit more wireing it now turns over but no water in as yet.
Next job to sort is under car plumbing as per Z-cars then hopefully fire it up.
[Edited on 8/1/06 by welderman]
Thank's, Joe
I don't stalk people
welderman
fuel tank
Thank's, Joe
welderman
posted on 8/1/06 at 10:36 PM Reply With Quote
under bonnet
Thank's, Joe
welderman
posted on 8/1/06 at 10:37 PM Reply With Quote
tank in
Thank's, Joe
welderman
posted on 8/1/06 at 10:38 PM Reply With Quote
tank in again
Got a 150mm gap between tank and radiator now.
Thank's, Joe
welderman
posted on 8/1/06 at 10:43 PM Reply With Quote
SORRY
Sorry about the other posts, forgot how to put pictures on. Can you tell.
Thank's, Joe
welderman
posted on 16/1/06 at 10:18 PM Reply With Quote
Well it now runs, sorted all those little things, stainless under car pipes for radiator, silicone hoses all conected. Fuel pump still needs direct feed but what the hell. Bang first turn and it started. Now to sort out front bodywork, then strip it down.
Need to chose a colour now. Er Stealth Black?. Maybe.
Thank's, Joe
R1minimagic
posted on 16/1/06 at 10:36 PM Reply With Quote
It's strange how they fire up instantly when you first try them but after fitting to the car and leaving over the winter they are a bastard to get started!!
welderman
posted on 16/1/06 at 10:43 PM Reply With Quote
I like the sound of the motor, so will probably start her up quite often. Should have changed the oil etc, but you know how it is. Men and their toys. We never grow up.
Thank's, Joe
R1minimagic
posted on 16/1/06 at 10:46 PM Reply With Quote
I wouldnt start it up that often unless you are gonna drive it, they like to blow plugs if you just run them in the garage..
welderman
posted on 16/1/06 at 11:17 PM Reply With Quote
Once it's on a rollins shell, may put down some dark rings outside the workshop if you know what i mean. Or even inside if i get cocky..
Thank's, Joe
welderman
posted on 16/1/06 at 11:29 PM Reply With Quote
Could try white with balck sports. Snoopy.
Thank's, Joe
welderman
posted on 17/1/06 at 07:56 AM Reply With Quote
Thank's, Joe
Coose
posted on 17/1/06 at 03:19 PM Reply With Quote
I'm quite tempted to sell my R1 Striker and build an R1 Mini. It'd go beautifully with my Yamaha bike collection and 'er indoor's '66 Mini 1000!
[Edited on 17/1/06 by Coose]
Spin 'er off Well...
RMK
posted on 18/1/06 at 03:43 PM Reply With Quote
good to see someone else building a bike engined mini
welderman
posted on 18/1/06 at 11:52 PM Reply With Quote
Are you building one.
Thank's, Joe
RMK
posted on 19/1/06 at 03:17 PM Reply With Quote
yes R1 . z cars set up.
welderman
posted on 19/1/06 at 03:29 PM Reply With Quote
How far you no with your build and have you and pictures.
Thank's, Joe
RMK
posted on 19/1/06 at 06:30 PM Reply With Quote
need doors painting then suspention setting up then ready to go .send me your email address, will send you some pics. cheers rob.
[Edited on 19/1/06 by RMK]
welderman
posted on 2/3/06 at 12:30 PM Reply With Quote
Been a long time since i last updated, not done alot6 for 5 -6 weeks on it.
Sorted all electrics out now.
Rollcage fully finnished.
Started strip down prep for painting.
Thank's, Joe
welderman
posted on 2/3/06 at 12:31 PM Reply With Quote
Thank's, Joe
welderman
Thank's, Joe
Coose
posted on 2/3/06 at 01:35 PM Reply With Quote
Fan-blimmin-tastic!
Nearly as good as your hypnotic avatar!
welderman
posted on 17/3/06 at 07:50 AM Reply With Quote
Update again as of last weeks strip down. Rescued attachment !CID__0Bi3nA7o5X_.jpg
Thank's, Joe
<<  1    2    3    4    5  >>
