<<  1    2  >>
Author: Subject: Aluminium Honeycomb
Syd Bridge
posted on 24/10/05 at 09:43 AM Reply With Quote
Originally posted by Triton
You can actually buy slimline honeycomb stuff like that found inside those luvvly B&Q doors....used in carbon fibre work..weighs nowt but stiff as a stiff thing
The stuff in doors is mostly cardboard treated to be fire resistant. Not for weight bearing structural applications.
The honeycomb in pucka cfrp composite work is resin impregnated nomex, a type of kevlar. I get ali honeycomb from Hexcel, and occasionally small quantities from SP Systems, as they're local.
For foam, you need rigid pvc, as used widely in boat building. Try Scott Bader.
Balsa core is also common, but I haven't used it for years.
<<  1    2  >>
