Bryan Sears
posted on 3/11/05 at 11:03 PM |
Thanks for that Marc will put it on the list of parts I will need from you. Bryan
MNRRRRRRRRRRRRRRRRR!
RichieC
posted on 8/11/05 at 08:50 PM |
What about fitting the Inner CV joint from a Lobro, to the standard shaft of a drum setup?
Rich
![](/galpreviews/a279953-3.jpg) ![Rescued attachment 3.jpg](/gallery/a279953-3.jpg) Rescued attachment 3.jpg
Mr G
posted on 14/11/05 at 11:35 PM |
I was under the impression that this was'nt possible due to the shaft diameter being different (Lsd Lobro thicker).
Are the shafts the same diameter on non-lsd lobros as tripod fitting? (All the lobro's I've dealt with have been from lsd back ends)
G
[Edited on 14/11/05 by Mr G]
RichieC
posted on 15/11/05 at 12:05 AM |
Yeh, I was under the same impression but apprently not.
This comes from a bit of a guru over on the Sierra Forum
Rgds
Rich
Mr G
posted on 15/11/05 at 01:14 AM |
Is that apparently not for the shafts being different diameters (I know for definate that the exposed part of the shaft is larger on lsd lobro than
tripod) or for the non lsd compared to lsd lobro shaft diameter being different?
EDIT: Just seen THIS thread.
All I can think of is shaft size must taper down on the splined section of the lobro then to the same as the tripod spline??
G
[Edited on 15/11/05 by Mr G]
RichieC
posted on 15/11/05 at 08:12 AM |
Thats the thread. Ive emailed Marty directly because the how to isnt accesible, and thats one of the photos from his how to.
Yeh, for all the shaft diameters are different, the splined section is not (with the exception of the Cosworth).
Im not entirely sure how easy the old joints will be to remove, as I dont have one in front of me, but I dont see much of a problem with a decent set
of pullers (might even be bone idle and have the local garage do it)
Rgds
Rich
[Edited on 15/11/05 by RichieC]
G.Man
posted on 15/11/05 at 04:56 PM |
it may fit on a 7 inch diff, but don't think so with a 7.5 inch diff...
Opinions are like backsides..
RichieC
posted on 15/11/05 at 05:20 PM |
Yep, thats the way I understand it.
I didnt get the 7.5" diff in the end, the bloke was a muppet so Ive got a 7" 4x4 cossie diff on the way.
Rgds
Rich
Flat Pack
posted on 6/12/05 at 06:56 PM |
Sorry to bump this thread back to the top, but did you get anywhere trying to use the tripode outer joints and lobro inners with an LSD?
I've managed to get myself into a bit of a mess with some Golf rear calipers, I can't fit the brake banjo as it fouls the outer lobro
joint. I've got an LSD so I can't swap to a complete tripode setup, but if I could change the outer one to a tripode then that'd
solve my problem.
RichieC
posted on 6/12/05 at 10:17 PM |
Nah not had a chance to do it myself, but it is a widely accepted procedure over on the Sierra Owners Forum.
With a bit of luck, Ill get the new joints at the weekend and get it done.
Rich
marc n
posted on 8/12/05 at 09:48 AM |
some of the larger drum braked shafts plug straight into the sierra disc diffs after you have removed the outputs
RichieC
posted on 28/12/05 at 05:16 PM |
Just an update for anyone wanting to do this.
Finally got the time to fit the new joints. Bit of a pain as you need to get hold of a donor set of shafts if you intend to fit new joints because
Ford dont sell the backing plates now and they dont come with the new joints.
All in all a good learning experience. Im happy there is going to be a bit of a weight saving but theyre not the easiest parts to source.
Just shout for any more info
Rgds
Rich
![](/galpreviews/a300879-Shafts After.JPG) ![Rescued attachment Shafts After.JPG](/gallery/a300879-Shafts After.JPG) Rescued attachment Shafts After.JPG
