ockwell1980
posted on 7/11/05 at 09:59 PM |
WHILE I HAVE PUT A TEMPORARY CABLE FROM THE SUPERDREAM'S RED/WHITE TO THE BATTERY'S + AND THE SUPERDREAM IS PUTTING OUT A STEADY 14V AND
THE BATTERY IS READING 13.5V. LEFT RUNNING WITH FULL BEAM ON AND DID NOT STUTTER OR STRUGGLE SO HOPEFULLY THIS IS THE PROBLEM. IF SO CAN I LEAVE THE
CABLE ON BETWEEN THE SUPERDREAM AND BATTERY OR DO I NEED TO FIND THE WHY THE CIRCUIT IS OPEN, EVEN THOUGH EVERY THING WORKS FINE?
CHEERS DEAN
[Edited on 7/11/05 by ockwell1980]
ockwell1980
posted on 7/11/05 at 11:16 PM |
i would like to thank everyone who as helped me in tracking this little problem down. just one thing in the superdream wiring diagram on knocking
about on this form it say the red/white should go to the starter relay, now i've no doubt this should go back direct to the +of the battery but
on mine where do you think it goes because it def is connected to the red/white of the fireblade loom.
cheers dean
shortie
posted on 8/11/05 at 12:04 AM |
Red/White on the blade loom is the wire from the starter relay that gets a direct 12v feed from the battery.
Rich.
