<<  1    2  >>
Author: Subject: pre SVA check
DarrenW
posted on 8/12/05 at 04:30 PM Reply With Quote
How is exhaust can supported? If you have used rubber bobbin type thing it may not be immediately obvious that you have a hard steel square edge just under a thin skin of rubber. If this is same as mine then it need to be trimmed. I made a piece of ali, curved and adged then stuck this on with PU adhesive.
My mount is square Fiesta engine mount (2 steel plate with studs sticking out, rubber in middle - steel plates are not immediately visible but constitute an adge that has to be radiussed).
Handbrake cable connections - i failed for using u saddles. Had to convert to commercially made nipples.
dom7
posted on 8/12/05 at 06:44 PM Reply With Quote
Originally posted by antonyg
Love the dash is that an aluminium surround around the dials?
[Edited on 7/12/05 by antonyg]
Yes it's aluminium
dom7
posted on 8/12/05 at 06:47 PM Reply With Quote
Originally posted by marshall
the dash has to be padded
Why has the dash to be padded ?
It's 25mm radiused at the botom !
dom7
posted on 8/12/05 at 08:08 PM Reply With Quote
Originally posted by Marcus
ISTR holes in grille should be no more than 45mm. I have 4 horizontal rods, and was advised to fit mesh behind at first SVA. I did and liked it better so its still on.
Marcus
Do you think if I fit my old grille behind this one it will be ok ? (it's a grille usually used in a fire place and I changed it because I thought it was to charp for Mr SVA) Rescued attachment 3qav1.jpg
dom7
posted on 8/12/05 at 08:11 PM Reply With Quote
Originally posted by chrsgrain
Where did the dials come from?
Chris
from a Ford Puma like the engine and the wheels
dom7
posted on 8/12/05 at 08:14 PM Reply With Quote
Originally posted by Jumpy Guy
where did you get the bonnet catch covers?
They are home made, in little moulds, with black coloured silicon
dom7
posted on 14/12/05 at 08:54 AM Reply With Quote
I have made an appointment for SVA on december 20th in Exeter.
Hope it will be ok
posted on 14/12/05 at 10:03 AM Reply With Quote
A pass would be a nice Chrismas present for you. Hope it all go'es well
Hornet
posted on 14/12/05 at 12:19 PM Reply With Quote
Hi dom Beautiful looking car....
2 questions... Looking at the large photo of full car, The angle of view of your front indicators may be a fail. Of course it may be the photgraph but the rule is something like.. 50% of the lights surface should be visable from the angles 45 degrees to 80 degrees.
Secondly.. do you have side repeaters as the ones on your wing again may be a fail?
Cheers and good luck John
<<  1    2  >>
