<<  1    2  >>
Author: Subject: Fitting dynojet kit to an R1
progers
posted on 21/1/06 at 10:09 AM Reply With Quote
Glad you got it sorted. Using 140 mains suggests that your exhaust is probably a bit restrictive in some way (manifold and/or can). If you get the urge for a bit more power you'll know what you need to improve.
Anyway, enjoy driving!
Paul
skydivepaul
posted on 29/6/06 at 10:42 PM Reply With Quote
very glad you posted this topic. i am just fitting the dynojet kit and was not sure which hole the main air jet is. the manual is about as clear as mud.
I will set it up as per the instructions but at least i know to go to the 140 mains if necessary. Which position did you end up with the needle setting. 1 to 6... 1 being at the top. cheers Paul
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
G.Man
posted on 30/6/06 at 04:06 AM Reply With Quote
6 is richest ie bottom groove as that lets more fuel in
Opinions are like backsides..
smart51
posted on 30/6/06 at 07:17 AM Reply With Quote
Mine is currently set to the richest groove on the needles - that is with the needle as far out of the jet as it goes.
What I did was try a selection of grooves each with the 140 and 144 main jets. I drove at low engine speed, mid engine speed and high engine speed at low throttle, mid throttle and full throttle to see how it felt and sounded. I also tried rolling the throttle on and off plus snapping the throttle on and off.
It was terrible at some settings, marginal at others but there was only one setting where it was good at everything.
Guinness
posted on 2/7/06 at 07:34 AM Reply With Quote
I think, to be fair to Dynojet, the kits are designed to be used on bikes, most of which will still run the standard airbox, and the mods might be a new air filter and exhaust and / or can. This is the sort of range of adjustment they are looking to cover. (Although I do agree the descriptions in the instructions could do with being a little clearer!)
We have a foam filter and a much better flowing exhaust system. My dynojet kit for the ZZR came with a range of needles and jets. I fitted the 155's to start with and the clips on the needles as instructed. As you found it was very rough and spluttered.
I spent a few days experimenting with needle position and jet sizes. Eventually settling on drilling the mains out to 205 and the needles right out with two washers under them. Now it goes like a rocket.
I am planning a trip down to Holeshot next month to get it set up properly on their rolling road, as I think that'll be the only way to ensure that it is right throughout the rev range.
Mike
Coose
posted on 2/7/06 at 04:50 PM Reply With Quote
Mine has a TTS kit which they have developed especially for a BEC installation usinf a foam filter and a decent exhaust. It works a treat!
Spin 'er off Well...
robbydee
posted on 2/7/06 at 07:27 PM Reply With Quote
why do i need to block this hole ??
what difference will it make? is it worth doing?
robbydee
posted on 2/7/06 at 07:29 PM Reply With Quote
robbydee
smart51
posted on 2/7/06 at 08:14 PM Reply With Quote
Which hole? the idle air jet? On my car, blocking them makes the engine sound brokend and kills the power by a staggering amount. unblocking the holes restored normal service.
I used silicone sealant, that way it was easy to remove.
skydivepaul
posted on 2/7/06 at 08:18 PM Reply With Quote
Thats the one i have fitted it is part no TTS-4364 it is designed for BEC with R1 engine foam filter and free flow zorst. I havent run it up yet with the kit installed but i will post results when it is running.
What settings did you end up with coose?
I have the recommended settings in for starters 144 mains and #2 needle.
cheers
Paul
HD CCTV
IP security systems
Coose
posted on 3/7/06 at 09:01 AM Reply With Quote
I have an All-Bikes spec 4-2-1 exhaust (as per Rich Miles' Striker) and have used his settings. They were: -
144 mains
Needles on 3rd notch
Air screws out 3.25 turns.
I've never had to touch it since, except for the occasional carb balancing (once a year)!
<<  1    2  >>
