Kamikza
| posted on 10/2/06 at 10:08 PM |
he yes
this is prety much it ?
| posted on 10/2/06 at 10:59 PM |
Aixam cars
they use a similar type engine. I think theirs' is a Kubota diesel same as is used to power refigerator units on lorries. They don't show
any pictures with people in them but these cars are tiny two seaters.
http://www.thorpe-morieux.org.uk/aixam.htm
Kamikza
| posted on 11/2/06 at 07:26 AM |
TANKS
Yes tanks but does somebody have plans for a simple suspension
flak monkey
| posted on 11/2/06 at 08:49 AM |
What sort of suspension do you want? How much engineering knowledge have you got? Can you weld properly?
All make a large difference as to what sort of suspension to use as some designs need a lot more design work and fabrication than others.
If you want somthing pre-made then maybe the suspension from an old mini would be suitable, very simple and suits a light car, can be converted to
coil overs quite easily as well. Only downside being that its a front wheel drive car.
Your first problem is finding a rear wheel drive (I assume thats what you want) donor, that you can take the hubs from, once you have decided on that,
you can decide what sort of suspension to use.
Sera
http://www.motosera.com
Kamikza
posted on 11/2/06 at 03:58 PM |
he
Tanks i am tinkin taking a suspension of a fiat 126 .We dont have minis if you faind it is wery ekspensive on the odther hand 126 is under 200 eur so
i will buy that and go from that yet tanks ill post my progres on the forum and yes i can weld
