<<  1    2  >>
Author: Subject: Keep R1 airbox or sock filters?
zxrlocost
posted on 17/2/06 at 12:45 PM Reply With Quote
my bike engine came with a k&n in the air box already.
me thinks ill keep it
posted on 17/2/06 at 12:51 PM Reply With Quote
G.Man, are you talking about the ally airbox for the ZX12R. If so, we were given the design and drawings for it and intend manufacturing one in the very near future.
G.Man
posted on 17/2/06 at 12:52 PM Reply With Quote
Originally posted by Winston Todge
Ta for that Mark.
Finally, what's a 'kit airbox' Mark? Is it the BSB or WSB term for factory race kit?
Cheers again,
Chris.
Chris
A kit airbox is one that the bike manufacturers develop for their race bikes and sell to race teams (or give to if factory supported) for use on their race bikes..
They are usually VERY expensive..
Other kit parts include things like, gearboxes, clutches, radiators (usually ally and huge) and other parts not restricted by certain race class rules...
Opinions are like backsides..
G.Man
posted on 17/2/06 at 12:53 PM Reply With Quote
Yup thats the baby... if you do make some for sale I will be VERY interested...
INDY BIRD
posted on 18/2/06 at 08:40 PM Reply With Quote
I Have a blackbird engine with a std airbox turned upside down and fits under JUST, and seems to run very well but needs tunning on RR dyno as top end a bit flat,
if i fit a k&n filter will this need re jetting?
sorry to but in on r1 question but i was also going to get a foam filter but the induction noise may be a issue for track days, certainly on my brothers ZX12R the engine noise is way louder than the exhaust with a carbon R1 can so could be a probelm???
any ideas grateful?
sorry for the hi-jack of the pol
smart51
posted on 18/2/06 at 08:47 PM Reply With Quote
I looked at my air box today and then tried to look at the foam filter on my car when shutting the bonnet. It seems that the filter just touched the bonnet when closed. No room at all for the air box.
It is the shape or volume of the box that is important? If I made one with the same volume and used the top half of the existing box with the inlet tubes moulded into it, would that have the same effect?
G.Man
posted on 18/2/06 at 09:11 PM Reply With Quote
Best bet is to build an airbox that fits to the bonnet, that way you can take off the bonnet and airbox as one...
Yes the shape is important for ultimate BHP, but better to have it breathe well than strangle it...
A good airbox is a series of chambers, much like an exhaust to baffle the noise...
need like a Box on the inlets, then the bonnet becomes the top when fitted..
Rubber seal around the box to make it airtight, then a duct to the front of the car to draw in cool air... or chambers fed from a bonnet scoop, even better...
Winston Todge
posted on 19/2/06 at 09:51 AM Reply With Quote
Interesting about the airbox smart...
My plan at the moment is to take the airbox into work and laser cut out an exactly symmetrical shape of the carb openings, then reverse them and re glue them in place and use silicon to seal any other big gaps.
Then perhaps use an MNR scoop or similar to give clearance for the top of the airbox. Definitely don't want a huge box stuck out of the top of the bonnet...
Any comments?
Chris.
dern
posted on 19/2/06 at 04:06 PM Reply With Quote
I'm going for an airbox if I can find one simply because of the noise aspect.
I don't believe that the argument that the manufacturers made the optimum solution in the airbox because imo they made the optimum design given the space restrictions of the bike. Therefore I don't think you can say that it can't be improved on.
Regards,
Mark
R1 (2003 FI) powered Locost in progress
Fireblade/Impreza
smart51
posted on 20/2/06 at 01:11 PM Reply With Quote
Here's a question. If manufacturers spend millions to get the best possible solution, how come you can get more power than the stock set up when using presumably inferior aftermarket parts like a foam filter and kit car exhaust?
gttman
posted on 20/2/06 at 01:29 PM Reply With Quote
probably because the originals are designed to actually keep the noise down.... wereas these aftermarket parts can't even get you on most tracks let alone through SVA.
how are people justifying gains or losses?
You can very easily gain power and make the engine slower......
10bhp at peak may only be a gain for 1000rpm and a huge loss everywere else, thus be slower on the road. Its the rev range thats important.
I'm using a std airbox with K&N purelly so its quieter..... I can't for one min beleive that its better that a sock etc.. as the air is sucked from around the engine rather than above it.
ChrisGamlin
posted on 20/2/06 at 06:11 PM Reply With Quote
The manufacturers part is probably near perfect for what they want it for hence the large cost in developing it, but there's a number of factors thrown into that pot which means its not usually perfect for outright performance, its usually a compromise of good performance with good noise suppression, working over a very wide temperature range etc.
[Edited on 20/2/06 by ChrisGamlin]
ChrisGamlin
posted on 20/2/06 at 06:33 PM Reply With Quote
Having said that, the reason an airbox can be better than an open sock / sausage filter is as Hellfire and GMan have touched on, because of the quality of air delivered to the carbs / TBs. As well as controlling where the air is picked up (ie making sure its cold), with an airbox you can control the flow of air towards the throttle openings much better so hopefully providing laminar non turbulent air to the throttle mouths. With an open sock/sausage filter the filter itself will disturb the air as its sucked into the throttle mouths as well as all the other uncontrolled air moving about in the engine bay etc, so although there may be more air available in the viscinity, because its turbulent less of it will flow into the throttle mouths.
I currently run a sock filter as the stock R1 airbox would block my forward vision, but will hopefully be fitting an aftermarket airbox that someone I know is developing both to reduce noise and provide better quality airflow to the engine.
smart51
posted on 20/2/06 at 07:09 PM Reply With Quote
So you know of someone developing an R1 airbox that will fit under a bonnet? Do tell.
ChrisGamlin
posted on 20/2/06 at 07:22 PM Reply With Quote
Not for me no, even if it sat flat on the throttle bodies it still wouldnt go under my bonnet
Im not sure of dimensions yet but hopefully it will be shallower than the stock airbox - I'll let you know more info when I have it.
Winston Todge
posted on 21/2/06 at 10:00 PM Reply With Quote
I'd certainly be interested too Chris!
Keep in touch.
<<  1    2  >>
