<<  1    2  >>
Author: Subject: threads on a track rodend.
Nick Skidmore
posted on 18/2/06 at 02:21 PM Reply With Quote
If someone can do a sketch / drawing I'll make a pair, photograph them and post it here.
If there's enough interest I'll see what price the can be made at.
Any good?
posted on 18/2/06 at 03:14 PM Reply With Quote
threaded extensions wouldnt have helped me with this one, i have a set anyway. I only needed 20mm adding, which is too little to do without chopping some off.
The long and short of it is it works fine welding it, the only problem being MOT time. I'll just put the original ones back in then, and crawl down with 3 threads holding them on.
Does anyone have a good reason why welding them isnt safe, rather than not legal? They are only steel afterall.
Jon Ison
posted on 18/2/06 at 04:30 PM Reply With Quote
Joel, if its under the gaiter out of sight forget about it.
posted on 18/2/06 at 04:32 PM Reply With Quote
The idea with 1/2" unf female extension is that the Escort rack track rods won't allow cutting 14 mm threads but should be OK at 1/2" UNF -- get my drift
They woud also be very handy for builders wanting to use MK1 Escort racks or Triumph racks.
[Edited on 18/2/06 by britishtrident]
posted on 18/2/06 at 05:38 PM Reply With Quote
Mk1 track rod ends don't fit the Cortina or Sierra taper do they?
posted on 18/2/06 at 05:40 PM Reply With Quote
well, its still in one piece. Tomorrow will be the real proof i guess.
All i need to do now is finish the trailer overnight to get it there!
posted on 18/2/06 at 08:33 PM Reply With Quote
The idea was the female thread would be 1/2" and male 14mm to allow mk1 racks to be adapted to mk2 track rod ends or with use a die to put 1/2" threads on the mk2 Escort which is too small a dia to accept a cut 14mm thread.
<<  1    2  >>
