ned
| posted on 12/4/06 at 04:31 PM |
That looks exactly how mine did pat
Ned.
beware, I've got yellow skin
Avoneer
| posted on 12/4/06 at 04:43 PM |
Thinking of linking the two together with a vertical strip held on by the bolt heads.
Pat...
Avoneer
| posted on 12/4/06 at 06:53 PM |
Might just do that...
But booked the garage to paint on Friday!
Besides, not got any 50mm box.
How about a flat strip from the bottom bolt hole, to the top bolt hole and then bent at 45' inwards and welded to the "flappy" sides
above the top bracket?
Also, any ideas for the towing eye - 10mm round welded onto the bottom of the front chassis rail?
Pat...
MikeR
| posted on 12/4/06 at 08:07 PM |
buy two rear axle brackets of jroberts!
Just get him to leave in the bit he removes for the axle - voila.
If he posts them tomorrow you might ....... aaah, heck, no you won't its wednesday.
errm.....
3mm strip from metal supermarket and make your own brackets.
| posted on 12/4/06 at 09:16 PM |
Pat, i have lots of 50x50x3mm erw in the garage, feel free to pinch some if you get convinced!
Avoneer
| posted on 13/4/06 at 10:57 PM |
Cheers guys (and Joel)
Towing eyes now added (exhaust clamps as per hicost) and extra flat welded on the trailing arm brackets. Should be strong enough for now.
Pat...
Avoneer
| posted on 13/4/06 at 10:59 PM |
Trailing arm bracket mod:
Avoneer
| posted on 14/4/06 at 11:33 AM |
Yep - METAL READY.
Cheers for the comments my Hicost - if you approve, it makes me fell better!
Started a new thread for the painting.
Pat...
Volvorsport
| posted on 14/4/06 at 01:00 PM |
what about some triangulation in the very front of the chassis , forget the tube names
www.dbsmotorsport.co.uk
getting dirty under a bus
Triton
| posted on 14/4/06 at 01:01 PM |
From the pics you are missing.......
some sunshine
www.tritonraceseats.com
www.hairyhedgehog.com
Avoneer
| posted on 14/4/06 at 02:28 PM |
And some rear wheel arches ;-)
There is one diagonal top to bottom at the front behind the bones.
Didn't want to add any more and don't want to open a can of worms by discussing it either !
Cheers eveyone.
My "built by committe" car will be finished soon.
Pat...
Triton
| posted on 16/4/06 at 07:59 PM |
Wings......now where did I put them :
robinbastd
| posted on 16/4/06 at 09:32 PM |
Ebay wasn't it Mark?
http://smuttygifts.com/
Avoneer
| posted on 16/4/06 at 09:53 PM |
Not bonded to a pedal boat are they?
Pat...
