bob
posted on 10/5/06 at 07:26 PM |
Well done geoff
Thats what i call a nice fail,your as good as there.
Dave J
posted on 11/5/06 at 11:17 AM |
Nice one Geoff, rectifying the problems should be a doddle.
Shall we see you at Newark?
All the best
Dave.
posted on 11/5/06 at 11:39 AM |
Regarding the mirror test - I only scraped through because the tester was 4" taller than me! I think that he gave me the benefit...
However, I realised afterwards that I could (a) swivel the stalks upwards, and (b) rotate the mirrors to give a better view. Option (a) is perfectly
within the rules, but option (b) may fall foul of the 'minimum width and height' rule - but my mirrors are quite large.
amalyos
posted on 12/5/06 at 03:10 PM |
quote: Originally posted by BKLOCO
Geoff,
As you may know I've got my SVA on Friday at Chelmsford.
Could you answer a couple of questions for me?
1. When did he do the emissions check. First/last/ middle
2. how much attention did he pay to seatbelt mounting height? Did he actually measure using a block on seat base?
3. What time did you finish? I'm hoping to get to work after!!!
4. Can you book a re-test there and then?
Brian
Were you the Yellow seven I saw heading into the test centre today? (I work just round the corner from there).
How did you get on?
Steve.
BKLOCO
posted on 12/5/06 at 06:43 PM |
Brian
How did you get on?
Steve.
Yep That was me with the maroon renault Clio behind as a back up car.
see the new post for how I got on!!!!
wilkingj
posted on 14/5/06 at 09:57 PM |
Ok... Fixed it all now. Ready for a re-test
Indicators:
Solved with some 55mm Extensions courtesy of a mate with a lathe.
![](/galpreviews/7DSCF0022.JPG) ![SVA Fail - 55mm Extension](/gallery/7DSCF0022.JPG) SVA Fail - 55mm Extension
Mirrors Raised a little
Need to fill the holes in
![](/galpreviews/9DSCF0023.JPG) ![SVA Fail - Raised Mirrors](/gallery/9DSCF0023.JPG) SVA Fail - Raised Mirrors
No piccy of the roll pins in the brake bias bar.
Best Regards
Geoff
http://www.v8viento.co.uk
Dave J
posted on 15/5/06 at 12:55 PM |
Looking good Geoff.
All the best with the retest![](/images//smilies/bigsmile.gif)
Dave.
