Deckman001
posted on 20/9/06 at 08:14 PM |
As JB has stated, it's a three person job, I did it with two peeps and it envolved a lot or running about around the car, three people make it
easy, my set up is luego gold peddle box with bias by the way
Jason
tks
posted on 11/10/06 at 10:31 AM |
its true
i´m with him!!
i had the same problems! my rears had air in the circuit!!
the fronts not!
brakeing whas chit with balance bar 70at front..
wy? the rear piston goed in easyly and you are applying force with a angle!
and you loose allot..
i guess that the handbrake is the way to go when the pedal doesn´t work!!
Tks
tks
posted on 11/10/06 at 10:33 AM |
2 peeps!!
The rear caliper with one boltmounted
and nipple upwards...
its more a question of haveing a nice peace of 6x4 transparent hose
for seeing the bubbles....
also it won´t work if you don´t compress the air sow letting the fluid walk won´t exit the air..
Tks
