<<  1    2  >>
Author: Subject: Wishbone Advice please.
posted on 2/12/06 at 10:29 AM Reply With Quote
I'd make the balljoint plate more triangular and just fit one more bolt like a lot of pressed steel bottom arms use Rescued attachment cortina-b-j-s.jpg
Colnago_Man
posted on 2/12/06 at 11:48 AM Reply With Quote
Thanks for the continuing advice. I've been starring at the car all morning and may have come up with the conclusion the Zimmerframe shocks are too long. My ride height at the front is 7.5 inches and 6 inches at the rear. I got SWMBO to stand on the front end this morning (not impressed - all dressed up and ready for Xmas shopping!) and the front dropped by nearly an inch...(okay you boffins how heavy does that make my wife??).
The Zimmers measure 13inches centres in their current position. Rescued attachment rideheight.JPG
locostv8
posted on 2/12/06 at 03:06 PM Reply With Quote
Thats what I was talking about. I would't wory about the shocks till the weight of and engine and radiator were installed. Generaly you want the lower arms to be paralell with the ground at rest and the tie rods should be paralell with the lower arms.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
Colnago_Man
posted on 5/12/06 at 09:38 AM Reply With Quote
I'am less worried about the shock length than I am about the angle of the steering arms.
Even with 140Kg stood on the front end the ride height only changes by a single inche.
I might try and wind the huge bolt up on the Zeemerides to see if that drop the ride height enough to make a difference. Any idea where I get a spanner that big from!?
NS Dev
posted on 5/12/06 at 09:49 AM Reply With Quote
goodness me, lots of things here!
Firstly, take the shocks off again, and jack the car up under the front of the chassis at your intended ride height (which should be with lower wishbones pointing slightly downwards towards the outer ends)
Then set front tracking paralel.
Then drop the jack 1" and see what happens to the toe-in/out. Then raise it 2" and see what happens to the toe-in/out.
Looking at your rack position it will probably vary quite a bit.
I am purely guessing but the rack looks like it needs to be quite a bit lower to me.
You will have horrendous bump steer set as it is now.
Once you have that sorted, then work out your shock lengths, which on a bookish chassis with bookish wishbones will be 12" on the front. 13" are too long.
Throw the zeemerides in the bin, they are a waste of time entirely.
get 230-260lb springs for the front end if you are using a crossflow, put on your 12" shocks and set the ride height.
<<  1    2  >>
