Winston Todge
posted on 21/12/06 at 01:07 PM |
of course I'd probably find out if I got my finger out and actually booked the #@*&ing test!
Too true! I thought you had it finished by MNR at some point? What's left to do Rog?
smart51
posted on 21/12/06 at 01:35 PM |
Birmingham SVAed my Vortx. They didn't like the seatbelt upper mounting but for a different reason. They said it was 0.5mm too low. The
measured it 3 or 4 times, readjusting the dummy each time. It was very subjective due to the string and spirit level rig that they use. He looked at
the mounting closely and asked me to remove one of the SVA bolt covers to check the bolt type. He didn't question the strength though.
chockymonster
posted on 21/12/06 at 02:08 PM |
quote: Originally posted by Dillinger1977
thats interesting, did he suspect that they might be whipped off post-sva or something?
Im trimming all of the stuff that may have been behind a bumper bar anyway. better to be on the safe side..
The seatbelt mount is a big worry though.. presumably its the same as mine and I dont fancy messing with that should it fail..
He agreed that they should be used as the floor height for the radius test, however "in his opinion" if someone put their hand out to
break their fall they could injure themselves.
I'd lost the will to argue at this point! I'm now working through the 4 page fail sheet (big writing!)
I'm making up an exhaust guard to resolve the radius problems on the exhaust can.
The rest is pretty straight forward, I just have to hope that I can get it registered before my covernote runs out.
chockymonster
posted on 21/12/06 at 05:02 PM |
I've just received my 4 page fail sheet.
The most relevant part to this is
5.2 A seat belt anchorage or the surrounding vehicle structure is of inadequate strength and likely to fail.
His explanation is
N/S + O/S top seatbelt anchorage points have no triangulation and bracing to spread the load effectively into the chassis.
TimC
posted on 21/12/06 at 05:35 PM |
I think I'd take it to another SVA centre!
zxrlocost
posted on 21/12/06 at 05:48 PM |
dead sound these SVA people
chockymonster
posted on 21/12/06 at 06:34 PM |
I can't.
SVA retest will use my current file until June 18th. It's easy to rectify, just a pain in the neck.
I've put all of the fail points up on my website and need to work through them, the major ones from my point of view are N/S + O/S front lower
swivel washers fouling on swivel joint on steering lock to lock, exhaust edging, emissions and the seatbelt points.
I know how to deal with all but the swivel joint washers. One thing of note in the fail sheet is this comment about brake bias locking - "A roll
pin will be considered acceptable providing it penetrates the full diameter of the component."
[Edited on 21/12/06 by chockymonster]
Dillinger1977
posted on 22/12/06 at 10:10 AM |
not entirely finished, mainly the engine wiring. Its pretty much done as it is, I just havent had the time to SVA it. maybe next year
-Rog
amalyos
posted on 22/12/06 at 08:18 PM |
His explanation is
Dion (Numnuts) and myself both had the same problem with the belt anchorages.
Solution was to turn up some sleeves to put over the originals, and bolt through a cap on the top.
Chelmsford accepted that, I think it was just a case of now it looks stronger,
We told Mark and Chris about it, hope they do something for future builds, as the SVA seem to be inconsistant on this issue.
chockymonster
posted on 22/12/06 at 09:06 PM |
They look much beefier.
Can you remember what spec you had it made up to?
Winston Todge
posted on 27/12/06 at 02:03 PM |
I find this amazing as some SVA testers may pick this issue up as 'not upto standard' and then pass it with a sleeve over that would have
a negligible effect on strength.
Also I would have thought if the sleeve was made slightly taller than the original thinner MNR mount then when the harness bolt was torqued up it
would 'pull' the original mount upwards and actually have a detrimental effect on its strength... Wouldn't it?
I would have thought the strap over the rear of the mount and bolted through the rear bulkhead would be stronger and more safe?
Chris.
amalyos
posted on 27/12/06 at 09:27 PM |
Even though the sleeve is not welded to the plate, it does move the effective pivot point of the load out, so it will reduce the loads on the weld.
Dion did drill through his posts, and added a bolt through with a spread washer underneath, but I couldn't do that as I have the RT+ chassis,
which has different trianglation.
Steve.
Winston Todge
posted on 3/1/07 at 12:14 PM |
Congratulations Paul! Great job on passing the SVA!
Just gotta get mine on the road now and then organise some sort of ride/drive out in the South...
Enjoy it!
Chris.
Dillinger1977
posted on 4/1/07 at 09:47 AM |
amalyos, where did you get those sleeves for the seatbelt mounts?
they do look nice and chunky. Im about to book sva soon and as a more permanent solution is way beyond what I can manage, i'm hoping the
percieved chunkiness might please mr SVA.
anyone a dab hand with a lathe?
-Rog
chockymonster
posted on 4/1/07 at 10:34 AM |
Rog,
Steve and Dion used a 40mm piece of rod with a hole bored through it to fit over the existing mount and a chamfer to fit over the weld.
There's a 5mm or so washer over the top
Dion drilled through the bottom of the tube and bolted a big plate to the bottom of each harness mount.
Now, this is where you'll laugh. I took Dion's pictures with me to SVA yesterday to show the other way of doing it and my examiner would
have still failed me on it as there was no triangulation to spread the load into the chassis.
The major issue I have with the SVA procedure is the level of interpretation that is used. You can't hand on heart say that something will
definitely pass. What I found really scary was speaking to my examiner when I booked the retest and him telling me he'd seen my pictures of my
modified harness mounts!
Agriv8
posted on 4/1/07 at 10:53 AM |
Rog,
Oh dont assume they don't do there home work. I belive there is at least 3 that have accounts and I am sure there are more who view only.
I suspect most use it to advise builders on how other have pased SVA 'Withing there INTERPRATATION of the SVA words'
Regards
Agriv8
chockymonster
posted on 4/1/07 at 10:57 AM |
Or to discover how builders get around rules! Key example to this was the words refering to pinning my bias bar! "The locking method must pass
through both sides of the adjustment assembly"
chockymonster
posted on 4/1/07 at 12:32 PM |
ready to enter the dragon's den!
7:45 in the morning, it was cold and wet
chockymonster
posted on 4/1/07 at 12:34 PM |
Waiting for my MAC Certificate and the examiner to take some pictures of my car for their records (of how it was before bits fell off on the way
home)
G.Man
posted on 4/1/07 at 12:52 PM |
Sob...
I so wish I had gone for that colour...
Opinions are like backsides..
chockymonster
posted on 4/1/07 at 01:11 PM |
quote: Originally posted by G.Man
Sob...
LOL!
The sad thing is I can't get a picture that does it justice. It's so hard to photo. It's much, much brighter in the flesh. In direct
sunlight it's brilliantly bright.
RichieC
posted on 4/1/07 at 09:53 PM |
Well done Paul, top job.
Enjoy, Rich
G.Man
posted on 4/1/07 at 10:51 PM |
Sob...
LOL!
I know, I know, but hey ho, I can use decals on mine... and can change the colour when i want...
Need a zx6r colour scheme i think from about 4 years ago...
Dillinger1977
posted on 5/1/07 at 08:45 AM |
on a pure white car i'd always be tempted to do the Toyota Castrol decal job on it.
not sure how it'd work on a non-toyota seven though.
-Rog
