DIY Si
posted on 7/1/07 at 10:34 AM |
I can't remember what make it is, but the variable fan controller on my MGB has something similar. It has a curved bit of rubber that sits
between the coolant hose and the casing and has a tiny little channel in it for the wire to go through. It's never leaked and came as part of
the kit for it.
Sun Tzu, The Art of War
the moa 2
posted on 7/1/07 at 11:56 PM |
had another look at it tonight took the coolant pipe off and it looked fine as if it would have sealed, but there is just the smallest of lines where
its not quite filled.
What we did was use a combination of silicone and a peice of rubber hose which we cut and used the wire to fill the gap we had cut and then siliconed
that . It was a very awkward and bodge kind of job and it failed because of that.
It didnt leaked for a couple of days and was fine but then it did.
I dont want to do it again without being convinced its gonna work as its such a job draining the coolant each time.
Anyway managed to just about get my oil lines sorted didnt work out too bad just need to swap 1 fitting and were there.
[Edited on 7/1/07 by the moa 2]
G.Man
posted on 8/1/07 at 04:43 AM |
i never had one leak with just clamping the wire with the silicone hose and a tiny amount of teflon tape..
Opinions are like backsides..
the moa 2
posted on 12/1/07 at 07:14 PM |
Not had ago at the water hose yet but received my hose and fitting from pace today and they didnt charge me anything so well pleased with there
helpful customer service.
[Edited on 12/1/07 by the moa 2]
G.Man
posted on 12/1/07 at 11:49 PM |
Ordered the davies craig ewp80, should be better than the crappy bosch which doesnt flow enough water...
G.Man
posted on 12/1/07 at 11:50 PM |
PS.I am gonna remove thermostat and run full time
