jos
posted on 13/2/07 at 09:35 PM |
c drive
jos
posted on 13/2/07 at 09:36 PM |
search for a file called
LFS_S2_ALPHA_V.exe
iiyama
posted on 13/2/07 at 10:50 PM |
quote: Originally posted by ecosse
quote: Originally posted by iiyama
Im down to a consistant 1:41 now....
About the same here, I think some major setup work is required before much below 1:40 will happen for me though
Alex
You got that right! Might have to get the old steering wheel and pedals down from the loft. Should shave some more off with that rather then using a
mouse!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
ecosse
posted on 13/2/07 at 11:02 PM |
"Should shave some more off with that rather then using a mouse!"
LOL, I'm already on the steering wheel and pedals! ![](/images//smilies/shocked.gif) ![](/images//smilies/bigsmile.gif)
Although I'm now getting 1:39's fairly regular
Alex
matt.c
posted on 13/2/07 at 11:04 PM |
Right then!
When is the big locosters race?
Gergely
posted on 14/2/07 at 01:37 PM |
Good to see many are interested! Some points:
- You will not see a LOCOSTBUILDERS race on the online races list until Saturday unless we decide to try earlier as I will host it from my computer,
so its not a server constantly up and running...
- The race is Saturday 20:00 UK time, password: locost
- If we are too many to join (I believe around 11 people should be max and even that is to be seen with my computer and Internet performance...),
would someone else be able to host a 2nd server? Just in case... We could even split the servers, one with FWD, one with RWD cars, or different
tracks, or based on lap times to give more even races... Anyone able/willing to in case we are too many on Saturday?
- Below is a link to download car settings, worth a try, far better than the default settings. Save the file into your LFS folder/data/settings and
you will be able to select them in the game.
LFS Setups
Gergely
[Edited on 14/2/07 by Gergely]
ecosse
posted on 14/2/07 at 01:48 PM |
I could probably run a server if required, I've got a few machines sitting around doing nothing anyway I'll have a look at the
requirements tonight.
Alex
Gergely
posted on 14/2/07 at 04:22 PM |
Cool, try it tonight! I might see if I have some time to check if LOCOSTBUILDERS2 is available for a round or two then...
But not sure I will have the time...
Saturday is still on though!
Gergely
jos
posted on 14/2/07 at 05:00 PM |
am i down as another driver,
pretty please
Gergely
posted on 14/2/07 at 07:51 PM |
I'll have a look at the requirements tonight.
How is it going? I am online and OK to test for another half an hour or so... got my wheel and pedals out as well...
Gergely
matt.c
posted on 14/2/07 at 08:21 PM |
Cool, Im in
FWD first for me.
ecosse
posted on 14/2/07 at 08:30 PM |
not long in, bringing a server online now, details shortly
Alex
ecosse
posted on 14/2/07 at 08:57 PM |
anyone about?
Server is running at 82.40.227.165 default port, password=locost
could someone try this to make sure I've got the firewall forwarding correctly?
Alex
Gergely
posted on 14/2/07 at 08:59 PM |
Just tried, I see the server, but no response, can't get in. I remember having the same prob. 2 ports need to be open, let me get you which ones
in a minute!
Gergely
posted on 14/2/07 at 09:01 PM |
This is what is on the LFS forum, and it worked for me just to open the two ports mentioned:
IP-Address: If the server has more than one IP-Address you can specify which address should be used by the LFS-Server.
Port: Specifies which port the server should use to connect to the Internet. Usually this can be left at the default value 63392.
ADVICE: If the server connects to the internet through a firewall the TCP and UDP ports which are used by LFS (default: 63392 and 29339) have to be
forwarded (http://portforward.com/routers.htm) to the server.
ecosse
posted on 14/2/07 at 09:02 PM |
2 ports! typical crap docs
wait a minute does it need the same port out the way?
Trying now
[Edited on 14/2/07 by ecosse]
iiyama
posted on 14/2/07 at 09:03 PM |
whats the server name??
Gergely
posted on 14/2/07 at 09:04 PM |
locostbuilder2
Make sure you select private servers from the list
ecosse
posted on 14/2/07 at 09:09 PM |
you should be able to connect directly to the IP as well 82.40.227.165 by specifying local network.
I can see the connections coming in, but they just time out!
iiyama
cant get in. Tells me it dosent recieve guest info....
Gergely
posted on 14/2/07 at 09:10 PM |
same for me...
Gergely
posted on 14/2/07 at 09:12 PM |
iiyama, can you see if you can get in my server I just put up? name: locostbuilders, password locost
iiyama
posted on 14/2/07 at 09:24 PM |
nope...cant get in. Same problem
Gergely
posted on 14/2/07 at 09:28 PM |
we could get in, but not play, lag was huge... can you try to get in again? If you can't you also need to open ports, i think... but I am no IT
expert at all... I am rubbish...![](/images//smilies/sad.gif)
ecosse
posted on 14/2/07 at 09:30 PM |
I just started another "locostbuilders2" if anyone wants to try no pass set
