<<  1    2  >>
New Topic New Reply
Author: Subject: build update
badding
posted on 29/9/07 at 02:45 PM Reply With Quote
matt.c
posted on 29/9/07 at 08:53 PM Reply With Quote
My sensor is about 1mm away from the drive shaft bolt. Will have to wait and see if it works or not. If it doesn't work then i will do it your way. Thanks.
Today i have loosened the rear brake pipes to add extra on the length and fitted handbrake cable clamps and now i have a working handbrake!!
Also fitted clutch and accelerator pedal stops so the cables dont get stretched.
Still trying to sort out the rad pipe hoses!!! Been 3 days now trying to figger out all the reducers and "T" pieces needed!!! Its doing my head in!! I wish all the pipes where the same! Some are 32mm and some are 25mm, 10mm etc all having to be joined together!! Also cant find anywhere that has the "T" pieces sizes i need!
All the fun of building a kit car!!
[Edited on 29/9/07 by matt.c]
matt.c
posted on 29/9/07 at 09:02 PM Reply With Quote
Also what is this?
Its joined to the engine by a nipple and i dont know what to do with it?
badding
posted on 29/9/07 at 09:24 PM Reply With Quote
It's a filter, the pipe on the other end goes to the carburator and then back to your engine.It's a modification on the later engines to heat up the carburators in the winter.You see small black pipes between your carburators, the carb on the right should connect with a pipe to that filter.I will see if I have a pic of my engine...
[Edited on 29/9/07 by badding]
badding
posted on 29/9/07 at 09:28 PM Reply With Quote
Ah found a pic..
badding
posted on 29/9/07 at 09:31 PM Reply With Quote
badding
posted on 29/9/07 at 09:36 PM Reply With Quote
For the rad I used the original zx9r rad.I think that's the easiest way... Rescued attachment CIMG1968.JPG
matt.c
posted on 29/9/07 at 10:20 PM Reply With Quote
cool thanks.
I now wish i used the bike rad now as the pipes are hell on my rad!!!!
I hope you dont mind but i used the pic of that pipe from your archive. I dont have that filter/pipe on mine so i will have to find one now!
Anyone have one of these spare?
flak monkey
posted on 3/10/07 at 11:58 AM Reply With Quote
Come on Matt, I thought you would have had it finished by now Seriously though, its looking good.
Been a bit busy these past few weeks, but I'll pop round soon and have a look
[Edited on 3/10/07 by flak monkey]
Sera
http://www.motosera.com
roadrunner
posted on 3/10/07 at 07:02 PM Reply With Quote
I have'nt used them pipes Matt, i just blanked them off at the inlet.
<<  1    2  >>
New Topic New Reply
