<<  1    2  >>
Author: Subject: GRP inlet manifold - why not?
Volvorsport
posted on 12/11/07 at 06:05 PM Reply With Quote
more stuff
www.dbsmotorsport.co.uk
getting dirty under a bus
Volvorsport
posted on 12/11/07 at 06:11 PM Reply With Quote
more stuff
posted on 13/11/07 at 10:35 AM Reply With Quote
hmm, some nicework there volvosport.
could you write a few words on how you made these?
basically what materials - filler/resin did you use? the CF one, hand lay up or use of vacuum former? flanges - does the manifold continue inside the flange hole or butts up to its face? thickness of flange? any reason why flange cannot be made from GF?
I am not looking for bling just functionaility and cheapness so would be using glass matt, making a 2 formers to make 4 inlets then joining onto 2 flanges.
Volvorsport
posted on 13/11/07 at 01:14 PM Reply With Quote
std layup in polyester resin , the carbon was also hand layup .
theres a guy drag racing a turbo bike engine with theses apparently , not sure how he got on with them .
i glued the carbon intakes to the ally using a high temp epoxy cure .
they got tested on QED dyno , moved the power band upwards, theres some sort of variable reflection going on due too the curve of the intake .
<<  1    2  >>
