<<  1    2  >>
Author: Subject: Aly body panels - are pop rivets butch??
Mr Whippy
posted on 21/4/08 at 12:57 PM Reply With Quote
If you think you have it hard, just look what is involved in building a kit plane, all those panels riveted by hand and no dents allowed Rescued attachment kit plane.jpg
907
posted on 21/4/08 at 01:13 PM Reply With Quote
^^^^^^^ What! no balsa?
MikeR
posted on 21/4/08 at 04:50 PM Reply With Quote
Rivet spacer pic
thats the thing, i've spent the last couple of days trying to think what it looks like. Nip to the gardening store, buy a wooden trellis and your away
(or tell my dad to make one - he's retired, it would occupy a good afternoon that)
vinnievector
posted on 21/4/08 at 10:35 PM Reply With Quote
blind rivets
the rivets you are looking for are called cherry max rivets they come from the states but 90% of the aircraft in the world use them so they are easy than you think to get hold of did a quick search on ebay for you and there are two guys on there selling them .sorry did not know how to link but just type cherry max rivet on your search . i ave them fitted to my car ,i chose to rivet mine with uni head type 5/32 ali use a 4.1 clearance drill and 3 to 4 in pitching's this should give the car some structural integrity .plus i wanted to give it a retro feel to the car asi could of used csk rivets instead ,i would not recommend you guys going any larger in dia as you will not have the equipment to pull the rivet do not try to use the steel ones as you need a special gun to pull them your ok with pop pliers from 5/32 4mm alu down 1/8 3.2 mm 3/32 2.5mm use a small amount of silkaset around the shank as this will stop any mostuoir getting in you should be left with a flush rivet you also have the correct lenght thease are measured 1/16 in 2mm there abouts . measure thickness of your sheet sides then the thickness of your tube add to gether this should be your length
1/16 = a 1 dash size the last didgets are the lenght on the part number look up cherry max rivets they can explain better than i .vin
[Edited on 21/4/08 by vinnievector]
oldtimer
posted on 22/4/08 at 08:37 AM Reply With Quote
Butch Rambo Rivets or Graham Norton Bends!!
So, thanks for all the imput.........I will be doing Rambo style exposed rivet heads!! I have never been one for clean looks so the SAS look it is! thanks for all the info.
Regards
Martin
<<  1    2  >>
