ChrisW
posted on 3/12/03 at 12:54 PM |
I'm using a Polo rad to cool my v6. hoping it will be good enough! It's about 2/3 the surface area of the Scorpio one but thicker and I
imagine is has more cores.
If a polo rad will fit your car could you not put two in one behind the other?
Chris
My gaff my rules
craig1410
posted on 3/12/03 at 01:01 PM |
Chris,
Yes I had thought of that but it's probably a lot of work to get all the pipes linked up and water tight. Might be easier to just get a single
radiator which is the right size and thicker (ie. More rows)
Craig.
GO
posted on 3/12/03 at 01:02 PM |
I thought about the old double rad trick, plumbing could be tricky trying to get the outlet of first to inlet of second. Might be worth a look but
I'm not sure you'd have enough depth behind the nose??
Would be prob 3 times thicker than just one (allowing for extra plumbing).
[Edited on 3/12/2003 by GO]
posted on 3/12/03 at 06:26 PM |
i was thinking of putting the radiator inside the chassis, as i have loads of space inside the nose between the rack and the front of the engine.
shorter hoses and weight further back, plus the nose can go tighter...
if i find one that fits, i will!
Stu16v
posted on 3/12/03 at 09:08 PM |
Does anyone know how many rows the Polo radiator has?
Two rows, IIRC. There is an equivelant sized one available off a certain model Golf (unfortunately I dont know...) which is dimensionally the same,
but thicker (3 row).
I have never seen reports of overheating in traffic or otherwise with a sorted cooling system using a Polo rad. But as mentioned earlier, they
are 4 pot motors. The RV8 may roughly equivalent BHP wise, but there is another 1500cc worth of engine in there making the power in the first place.
FWIW, the 'custom' Westy rad can struggle to keep a RV8 cool.....
craig1410
posted on 4/12/03 at 10:27 PM |
Guys,
Take a look at this one. The friend I was referring to earlier has decided to buy this and I must admit it looks the business. It is from a Land Rover
Discovery Tdi.
Two more images to follow
Craig.
[Edited on 4/12/2003 by craig1410]
craig1410
posted on 4/12/03 at 10:28 PM |
![](http://www.craig.chamberlain.name/locost/assets/LandRoverRad2.jpg)
craig1410
posted on 4/12/03 at 10:29 PM |
I should mention that this Locost chassis is +4" wider than book and as you can see has a Rover V8 3.5Litre engine with a Holley 390cfm.
mackie
posted on 4/12/03 at 10:47 PM |
Looks good. Designed to work in the Sahara no doubt. The Merc one is probably over engineered too.
craig1410
posted on 4/12/03 at 10:54 PM |
Mackie,
You're probably right but given that it cost just over £100 (RRP over £200) it doesn't seem like a bad deal. RPi engineering recommend
this as a suitable radiator to cool the RV8 effectively. I'm going to go around to my local scrappie at the weekend and try to find a similar
sized radiator on a car which is more likely to have cheaper spare parts availability. Maybe the likes of the Golf VR6 might be worth a look not that
I'm likely to find one of those at my scrapyard...
Craig.
ps. Just checked, the VR6 radiator is £79 from eurocarparts. I wonder what size it is...
Donners90
posted on 4/12/03 at 11:02 PM |
Luego
Luego sell a radiator for their Viento V8. Maybe it'll be worth asking them for dimensions and specs?? I'm not sure if they have had any
problems cooling, but a few laps round Rockingham would have put some heat into it!!!
Donners90
posted on 4/12/03 at 11:06 PM |
This is a Viento V8. One built by a customer. Picture taken from Luego website! Not sure if the rad has been supplied by Luego tho.
[Edited on 4-12-2003 by Donners90]![](http://locostbuilders.co.uk/upload/a70515-v8+rad.jpg)
