Jesus-Ninja
posted on 7/8/08 at 08:19 PM |
oh, if you want, you can just use the IVAs.html file, which is the main text, without the links to original page numbers and the graphics (few as
they are). I used it with my eBook reader quite nicely.
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
Jesus-Ninja
posted on 7/8/08 at 10:19 PM |
sorry folks. the html conversion wasn't that great. many (most?) of the sentences are broken up and out of order. I'll have another look
when I am in front of a real computer and not remote desktopping from my phone!
tomprescott
posted on 28/10/08 at 09:32 PM |
quote: Originally posted by RichieW
It might stymie the fashion for BECs a bit. The bang for your buck wont be as good if you're having to pay for the reverse box type thing. (CEC
builder here so I don't know what they're called.)
Quaife calls it a reversing box, good guess richie!
Gonna have to build quicker to get it passed while its still relatively cheap, seems like Govts gonna use car builders to get the UK out of a
recession!
phil clegg
posted on 22/11/08 at 05:45 PM |
iva inf 26 ?
on a mot course last week a friend of mine spoke to a sva tester about my build (haynes).he suggested it would not pass the new test from april due to
rule inf 26 ,i can not find this on dvla website ,why would he say my and other locost type builds will not pass,if this is how he understands the
new rules should i take my car elsewhere or am i building an ornament he said bring before april 1st which i can not do ,ideas anyone, phil
t.j.
posted on 28/11/08 at 12:02 PM |
Did "this inspector" say why, or is it just "someone who heard about bIVA".....? Just read the manual and concluded if it is
possible. Guessing is not the right thing to do. It makes people nuts.
26 is about de Front Fog lamps, they are optional so..... don't mount them or mount them as required.
[Edited on 28/11/08 by t.j.]
Jesus-Ninja
posted on 28/11/08 at 01:04 PM |
Some punctuation?
Seriously though, as already said, don't fit them or fit them correctly. This seems to be one of the easier regs to understand.
I'm currently in conversation with VOSA to understand visibility issues which are much less clear.
[Edited on 28/11/08 by Jesus-Ninja]
t.j.
posted on 21/1/09 at 06:49 AM |
Latest versions here:
IVA v3.0 manual
Scouse Monkey
posted on 2/3/09 at 04:37 PM |
Are they keeping the SVA for goods vehicles?
can you build a special goods vehicle...eg a special post van 7 and then modify it a bit after? :-)
(yes i am being tongue in cheek)
Any confirmation on the price yet? £500 seems an awfully big hike that will hit a lot of you hard. Are they trying to stop people building kit cars?
Is there some reason they may - high fatality rate, pressure from the EU etc? I can't see it tbh.
Omni
posted on 24/3/09 at 06:32 PM |
quote: Originally posted by andys101
If the UK implemented the new EC Directive there would be no such thing as kit cars as the directive doesnt allow them.
However each member state can self legislate, which is what the uk have done.
Just read your Building status thingy! Are you an SVA/IVA Tester?
O
James
posted on 25/3/09 at 12:25 PM |
Errrrr good guess...... Yes.
Don't be frightened I'm here to help.
Andy.
Welcome to the site!
Or the madhouse as we call it!
James
- Muhammad Ali
AdrianH
posted on 12/5/09 at 06:21 AM |
Just noticed we are up to version 3 from 28/04 published May
Link
Adrian
[Edited on 12-5-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
tks
posted on 14/5/09 at 10:25 PM |
bias bars....
Note 5: Bias bars and other mechanical adjusting devices fitted to twin
master cylinders must have no means of adjustment. However they will
be deemed acceptable if the all nuts etc are fully welded to their relative
threads and all the threads originally intended to provide adjustment are
welded along their length i.e. permanently rendering them un-adjustable.
AdrianH
posted on 4/7/09 at 08:26 PM |
Just for information another version June 09 is on the web page.
Not sure what differences there are between this and the May version
http://www.transportoffice.gov.uk/crt/vehicledealershipsandimporters/isocertificationandtypeapproval/individualvehicleapprovalinspectionmanuals.h
tm
Adrian
[Edited on 4-7-09 by AdrianH]
flange nut
posted on 11/7/09 at 11:14 PM |
IVA diagonal split braking requirement
A Sierra master cylinder has three outlets. One from the chamber nearest the brake pedal and two from the front chamber. Would it be OK to split the
brakes by piping one of the front outlets to a front brake the other to a rear brake and then splitting the single outlet front and back?
It looks like that the requirement for diagonal split braking is going to make it impossible for people to use twin master cylinders and a bias bar.
I can't see how that would work.
From the IVA manual, Brakes section 09A
4.
The vehicle must be fitted with a split (dual) circuit brake system with each part of the system operating on at least two wheels (one on each side),
capable of operating in the event of a failure of the service brake or its power assistance.
Geoff
minitici
posted on 12/7/09 at 08:25 AM |
4.
Geoff
This is NOT necessarily a diagonally split requirement!
A front/rear split meets the above requirement of "each part of the system operating on at least two wheels (one on each side)"
flange nut
posted on 12/7/09 at 06:19 PM |
Thanks for the reply Minitici.
Geoff
4.
Geoff
FEZ1025
posted on 9/11/09 at 05:50 PM |
The IT numpties have been at it again they've moved the stuff & left broken links. No idea how long it will stay
HERE before they decide to break it again.
Alan...
Fozzie
posted on 9/11/09 at 10:39 PM |
Alan, see sticky under this one in the 'IVA/SVA' section .....
Fozzie
Alan...
FEZ1025
posted on 11/11/09 at 05:19 PM |
Fozzie
Is this not the sticky under the IVA/SVA section?
Alan...
Fozzie
posted on 11/11/09 at 07:22 PM |
You will see 3 stickies in this section, denoted by an arrow to the right of the thread title....
GeoffMM
posted on 19/11/09 at 09:05 PM |
Wow that was difficult to find!!
http://www.businesslink.gov.uk/Transport_Theme_files/124_IVA_M1_Inspection_Manual__Version_4.pdf
woodsy144
posted on 15/4/10 at 04:21 AM |
I am sorry, I must be blind,
Can some one point me to the direction of the IVA manual and the emissions standards
Thanks...
iank
posted on 15/4/10 at 07:19 AM |
Thanks...
One post up
( http://www.businesslink.gov.uk/Transport_Theme_files/124_IVA_M1_Inspection_Manual__Version_4.pdf )
Emissions are chapter 2
[Edited on 15/4/10 by iank]
Anonymous
iank
posted on 27/5/10 at 08:45 AM |
New version available with new relaxed rules on brake bias adjusters.
New Manual v4.510
Anonymous
rodgling
posted on 7/8/10 at 05:09 PM |
Version 5.01 (26/7/2010) is now available:
http://online.businesslink.gov.uk/Transport_files/124_IVA_M1_Inspection_Manual__Version_501_0710.pdf
