MK9R
posted on 22/1/09 at 07:52 AM |
only just seen this, awesome!!!!!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
cloudy
posted on 25/1/09 at 04:42 PM |
Wiring is pretty much done, and have modified the Photon lights with an LED sidelight...
[Edited on 25/1/09 by cloudy]
www.warnercars.com
nitram38
posted on 25/1/09 at 06:14 PM |
I need to get my finger out!
I've still got loads to do!
Very nice work James
suparuss
posted on 25/1/09 at 07:14 PM |
im very impressed with your build! i can remember you starting it a bit before i dissapeared, i cant believe you are almost finished! very nice work,
well done i hope you pass the sva.
Russ.
Valtra
posted on 25/1/09 at 07:45 PM |
Russ.
Another monumental effort ....we are not worthy etc etc
body work photos are mid blowing
"If it looks like it works and it feels like it works, then it works"
cloudy
posted on 26/1/09 at 06:50 PM |
Yet more wires fitted today, I think aside from the temp and speedo sensors it's all done. The speedo hall sensor I will run down screened cable
which I will chassis ground, It's a KOSO unit so can be rather flaky..
Had a bit of a nightmare with my SVA paperwork which I sent last tuesday on RM recorded 1st class, the tracking number said it hadn't been
delivered still this morning, called SVA office and they had received it weds - tracking system must have a problem...
Not sure how long to expect to wait for the call saying the details have been passed to the SVA test centre?
James
www.warnercars.com
FUORISERIE
posted on 26/1/09 at 09:26 PM |
great pictures cloudy...!!, are those aftermarket front mounted lights ? or are they bespoke ?
Italo
nitram38
posted on 26/1/09 at 09:30 PM |
James, you mentioned an Led sidelight.
Is that in the lamp housing?
Any info, pictures of this?
I am planning on using the lucas landrover style sidelights for mine.
cloudy
posted on 26/1/09 at 09:44 PM |
Italo, the lights are "Photons" available from Russ bost of this forum
Martin, the back of the directing lens has two manufacturing flats, I put a 5mm hole through one of these and epoxied a 8000mcd megabright LED in it -
It's in the high beam unit so all 4 lamps are illuminated during normal driving - They are not massively bright but have the option of adding a
second LED in each if SVA needs
James
www.warnercars.com
nitram38
posted on 26/1/09 at 09:47 PM |
Will the led's survive the heat of the halogen lamps?
Just as an aside, your dipped beam must stay on when you put your main beam on on twin light setups.
On single lights this does not apply
[Edited on 26/1/2009 by nitram38]
cloudy
posted on 26/1/09 at 10:03 PM |
Bugger! The sierra switches dont do that - no problem i'll just wire the main beam relay signal onto the dipped so they are both forced to fire
together - is this stated in the sva manual anywhere?
I bench tested the high beams for half an hour with the LED only becoming lukewarm, there isn't much light hitting it
www.warnercars.com
nitram38
posted on 26/1/09 at 10:08 PM |
It is definitely an sva rule.
At least you found out now!
cloudy
posted on 26/1/09 at 10:31 PM |
The only mention I can find is on section 9.1 page 4 where it states
(If the lamp is of a gas discharge type)
dipped beam remains on when the mainbeam is on
along with other rules such as must have a washer system..
Presumably that only covers HID lights?
Can you explain where it's stated?
James
[Edited on 26/1/09 by cloudy]
www.warnercars.com
nitram38
posted on 26/1/09 at 10:45 PM |
James......Oops
I have just spent half an hour re-reading and it looks like you are right.
Sorry to give you a heart attack!
cloudy
posted on 26/1/09 at 10:52 PM |
I may go armed with some electrical tooling just in case! There is a case for it I suppose as there is a momentary point during the relay switchover
where the lights are off, though only for a tiny fraction of a second....
James
www.warnercars.com
nitram38
posted on 26/1/09 at 10:54 PM |
I'm still going to wire mine so that they are both on.
cloudy
posted on 26/1/09 at 11:00 PM |
I think I will too, if I can simply jump across the relays....
James
www.warnercars.com
Doug68
posted on 27/1/09 at 06:19 AM |
What instrument panel is that? I can't see it referred to in the thread.
It looks really good I'd like to investigate them further.
Thanks,
[Edited on 27/1/09 by Doug68]
Doug. 1TG
Sports Car Builders WA
cloudy
posted on 27/1/09 at 09:11 AM |
It's a KOSO RX1N
www.warnercars.com
cloudy
posted on 29/1/09 at 06:00 PM |
Wahoo, VOSA have cashed my SVA cheque - hoping for the call any day....
James
www.warnercars.com
Valtra
posted on 29/1/09 at 09:59 PM |
James
When the phone call comes your stomach will instantly drop and your heart will pound , as you realise how little time you have to do a million and one
jobs . The very best of luck to you
cloudy
posted on 29/1/09 at 11:00 PM |
Hopefully it's not too many jobs - list is:
Fit cycle wings
Fit fuel tank (when it arrives)
bolt in seats/belts
fill and bleed brakes
Nut covers
Clip back all wiring
Battery terminal covers
Speedo calibration
Fit driveshafts...
I'm sure that list will double!
www.warnercars.com
Fred W B
posted on 30/1/09 at 11:09 AM |
All the best with the final push
Do you have to add wheel alignment to the list, or did you do that earlier?
Fred W b
cloudy
posted on 30/1/09 at 11:32 AM |
I did do that earlier but will redo it in case anything has moved in the reassembly...
james
[Edited on 30/1/09 by cloudy]
www.warnercars.com
cloudy
posted on 30/1/09 at 01:36 PM |
I was expecting a call to say my details had been passed on, but instead a letter arrived on my doorstep today from Leighton with a test date of 27th
Feb - the race is on!!
Date is a friday - not sure if thats a good day or not to have it?
James
www.warnercars.com
