<<  1    2    3  >>
Author: Subject: Zetec the difinitive guide
big_wasa
posted on 15/3/05 at 08:50 PM Reply With Quote
You ask about price...
well my first motor was the 1.8l from an orion this was £50 on ebay..This seems to be the going rate or about £100 from a breakers guaranteed.....
This turned out to be buggered so I sold the bits on ebay(as faulty) for £55 and was still left with flywheel /sump/rocker box/ignition coil breather and lots more
Ive just borght on friday my 2ltr from my local breakers that also surply Tiger..This was £200+vat...You will pay over double for the extra 200cc .On paper the bhp does not look worth the extra, but it has lots more torque and this gives your acceleration...having owned mondeo's and escort's/orion's the heavier mondeo will kill the escort of the lights every time and is well worth the extra cash..
bob
posted on 21/1/07 at 11:05 AM Reply With Quote
Old thread but worth a read,i've been out of action in the garage for the last couple of months (knee problem) but the pinto was outed in october and i have all the parts needed bar an air filter to fit the zetec.
I've used all the information from this thread to gather my parts so big thanks to everyone for there input.
Many many different variations on plumbing can be a tad confusing,but hey if it works it works.
Any more info and pics though can only be helpfull to others.
Rudy
posted on 21/1/07 at 02:21 PM Reply With Quote
My car is not on the road so I do not know how well is my engine. However I used mondeo ecu: it is quite simply to have it work if you have "electri schematic". If you not have it let me know I will scan and email.
Engine starts also without maf, lambda sensor, and other sensor. So you can get your engine running quit easy like I had. Rescued attachment Motore1649.JPG
Sorry about my English
mad4x4
posted on 21/1/07 at 10:28 PM Reply With Quote
If this is the ultimate guide then watch the crankshaft pickup.
If the engine was from an automatic the crankshaft pickup need to be changed to the manula one when you fit the manual flywheel. Part cost £5 from FORD. need to be fitted before fitting fly wheel.
Scot's do it better in Kilts.
bob
posted on 21/1/07 at 11:02 PM Reply With Quote
Do you mean the crank position sensor (CPS)
stevebubs
posted on 22/1/07 at 01:55 AM Reply With Quote
Loads of pics from my xflow-zetec conversion in the Fury gallery on gallery.cantcatchme.net
zetec
posted on 22/1/07 at 03:15 AM Reply With Quote
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 22/1/07 at 09:00 AM Reply With Quote
Originally posted by bob
James
I'm still baffled,you didnt re-read the posts far enough.
Its zetec and ignition for it,the pinto will get binned.
James is suggesting that you fabricate a plenum for your Zetec so you can retain the OEM Ford Zetec injection/ignition system just like Mark did to his Pinto. Have your baffles now been removed?
[Edited on 22/1/07 by MikeRJ]
bob
posted on 22/1/07 at 09:28 AM Reply With Quote
Hello Mike
I did look at trying to use the original plenum as the 1.6/1.8 uses a slightly smaller one in bulk than the 2 litre,and it is possible to fit the 2 litre throttle body on the 1.8 plenum.
Still to big though so i looked at home made plenums,with most of them looking like a dogs dinner and some not working efficiently and ending up on ebay i decided on bike carbs for now.
stevebubs
posted on 22/1/07 at 07:30 PM Reply With Quote
trust electrical do a suitable low-line plenum....
bob
posted on 22/1/07 at 08:26 PM Reply With Quote
Cheers steve
I've gone the fireblade carbs route for now,Bogg Bros are making the manifold now so i should have it by the end of the month.
I've also some zx6 TB's which if they split i might have a go with maybe next year, although there is always something else for me to spend my allowance on
TangoMan
posted on 22/1/07 at 10:08 PM Reply With Quote
I am getting along quite well with my conversion but though I should advise caution on the inlet side.
I have had to shorten my inlet manifold as there was not much gap between the rear TB and the brake Master Cylinder.
I will soon be sorting out the spaghetti wiring of the MegaSquirt.
Don't worry, I do intend on wrapping the other primaries but I ran out of wrapping.
[Edited on 22/1/07 by TangoMan]
Summer's here!!!!
fideel109
posted on 24/1/07 at 05:42 PM Reply With Quote
Managed with some alternations to get a black top into an Avon. Rescued attachment grondplaat Avon 009.jpg
<<  1    2    3  >>
