owelly
posted on 9/3/12 at 09:03 AM |
As said, you can hear it firing but I would say it needs to be spinning over faster.
I know you have said that you have checked the ignition timing but I known proper grown-up mechanics fit plug leads to thr correct firing order, but
with the rotor arm turning the wrong way so you have the timing correct for just one stroke.
http://www.ppcmag.co.uk
theduck
posted on 9/3/12 at 09:33 AM |
Lost count how many times I've checked it to be honest. The arm spins clock wise and myleads are positioned
4 2
3 1
I have tried it rotated 180degrees to be certain I wasn't 180out and got no firing at all then.
So it sounds as though now maybe my battery is too weak? I actually had jump leads on in that video as well!
lotusmadandy
posted on 9/3/12 at 10:32 AM |
Your firing order seems to be correct 1,3,4,2 and you have done
all of the checks for timing.
I have just watched both videos and it is turning over slowly but you
can hear the engine catching on 1 cylinder.It could be
that your battery is discharged and there isnt enough power to
turn it over and give a nice fat spark.
theduck
posted on 9/3/12 at 11:11 AM |
SWMBO is at home so just got her to put multimeter on the battery and it's showing 12v
lotusmadandy
posted on 9/3/12 at 11:27 AM |
Well that doesnt seem a million miles away.
I have just put a meter on mine and it shows 12.7v
I will still say that the engine is turning over slowly though.
Ivan
posted on 9/3/12 at 11:30 AM |
Your battery base voltage should be 12.6 Volts so it might well be not strong enough.
theduck
posted on 9/3/12 at 12:05 PM |
Ok so i'll get the jump leads in it later and see what it's putting out with those on.
What else could cause slow cranking?
Edit: will check and clean earthing point and the bellhousing to starter mounts as well.
[Edited on 9/3/12 by theduck]
lotusmadandy
posted on 9/3/12 at 12:13 PM |
The engine hasn't been rebuilt has it? A fresh engine can be very tight
to turn,many years ago we sometimes had to tow freshly built pinto's to get them going.
theduck
posted on 9/3/12 at 12:37 PM |
Not rebuilt, with exception of bolting on the required Sierra bits its as it was as it came out the cortina.
posted on 9/3/12 at 12:55 PM |
What does it show when you are cranking though? Also measure between starter terminal and engine block whilst cranking and you will see if you are
getting any significant voltage drop through e.g. a bad connection or knackered solenoid.
leon51274
posted on 9/3/12 at 02:04 PM |
What about the starter. When i had my crossflow rebuilt the starter was just not up to the job, i checked everything, timing, new battery, jump leads,
plugs, earths, wires, you name it, turned out that the starter just wasn't up to the job anymore. Put a new starter motor on and bobs your uncle
it fired up no problem.
theduck
posted on 10/3/12 at 01:44 PM |
Just checked following voltages
Between battery terminals 12.62v
Between starter +ve and earth 12.51v
Between battery terminals when cranking 9.7v
[Edited on 10/3/12 by theduck]
leon51274
posted on 10/3/12 at 01:57 PM |
I would say your battery is knackered! I'm sure someone will confirm.
theduck
posted on 10/3/12 at 02:07 PM |
Am inclined to agree. Hoping it's just battery though and not starter as well.
Have just tried it with jump leads on and got no improvement. Infact battery drained quite quickly.
Quick video to show that once battery/starter issue is sorted we will have life though
http://i1128.photobucket.com/albums/m492/stumac1985/5c9b530a.mp4
leon51274
posted on 10/3/12 at 03:03 PM |
If you want any further advice/searching then i strongly recommend this forum.
http://www.turbosport.co.uk/forumdisplay.php?179-X-Flow-Pinto-BDA-and-Twincam
There are some blokes on there that really are pinto specialists. You'll have to register but there's loads of info on peoples pinto and
crossflow woe's. I found it most helpful.
Hope you get it sorted soon
Regards
Leon
theduck
posted on 10/3/12 at 03:20 PM |
So new battery and...
http://i1128.photobucket.com/albums/m492/stumac1985/60391456.mp4
Thanks for the link Leon. Will check it out.
theduck
posted on 11/3/12 at 11:06 AM |
Had another look at dizzy timing and did appear slightly out, in the sense the pick up points weren't aligned.
And a quick video, it's definitely closer to starting!
http://i1128.photobucket.com/albums/m492/stumac1985/75bd4996.mp4
theduck
posted on 11/3/12 at 11:56 AM |
Got it started, kind of. Getting huge backfires though ![](/images//smilies/sad.gif)
lotusmadandy
posted on 11/3/12 at 12:10 PM |
Move the dizzy until it runs without backfiring.
It is firing while the valves are still open.
theduck
posted on 11/3/12 at 12:32 PM |
IT LIVES!
But... It won't idle, and I have smoke coming out a hole on the manifold I thought was a coolant connection... Anyone tell me what should go
in here?
Oh and of cause, a running video!
http://i1128.photobucket.com/albums/m492/stumac1985/c438f366.mp4
theduck
posted on 11/3/12 at 01:16 PM |
Bit of research and pretty sure I'm right and it is a coolant connection and it's just coolant burning off.
Time to rebuild the front end and connect up coolant system!
