DIY Si
posted on 3/10/06 at 05:18 PM |
bit closer
Sun Tzu, The Art of War
DIY Si
posted on 3/10/06 at 05:20 PM |
and the head before fitting
yes, there is a gap between the valves, but it's only 40 thou wide! It's a small step down from an out-and-out race head.
DIY Si
posted on 3/10/06 at 05:39 PM |
It drinks that much fuel and air that the inlet manifold turns white on the outside of the bend with ice! And it happens during the summer too. Only
bad points are that you need earplugs to drive for more than 30 mins! And it can be heard from over 3 miles away!
posted on 3/10/06 at 08:09 PM |
Excellent! I really want to get another mini sometime.
Drove to Silverstone for the 35th Aniversary in my brothers mini with 45DCOE and straight cut drops/box and my ears were ringing for a couple of days
after!
Amazing how many people have come up and told him his gearbox is on it's last legs LOL. It also has a bit of primary gear rattle (286 scatter
cam and ultra-light steel flywheel don't help!) and some old boy knocked on his window and said he should stop the engine ASAP as his cam chain
was going to snap any second
DIY Si
posted on 3/10/06 at 08:15 PM |
Mine's a bit like that. The idle varies between 800 and 1500 rpm depending upon it's mood! I've not had anyone say things like that,
whihc is a little suprising, but I have had may people stop me and ask what the hell lurks under the bonnet as its one of those enignes that sounds
"different", ie highly tuned, rather than boy racered. I know of another local mini that's louder than mine, but is a near standard
998!
NS Dev
posted on 4/10/06 at 07:07 AM |
heh heh, mini is just one of those cars isn't it, now I want another!
Oh well, will have to settle for the grasstrack one!
Nice car, leave it looking like that, chop the bulkhead and sidedraft it so you can't see the carb and stick it back on the road........go on
you know you want to!!!!
smart51
posted on 4/10/06 at 07:13 AM |
I originally posted this in the wrong thread
The Wartsila-Sulzer RTA96-C turbocharged two-stroke marine diesel engine makes 5,608,312 LB Ft of torque and 108,920 BHP at 102 RPM from 25,480
litres. Its thermal efficiency can excede 50% so fuel consumprion is only 1660 gallons per hour.
5608312*108920/25480 = 23973
http://people.bath.ac.uk/ccsshb/12cyl/
NS Dev
posted on 4/10/06 at 07:19 AM |
That is a pretty effective engine!!!!!!! 50% thermal efficiency we can only dream of on any of our engines, bike or car!!!!
Agriv8
posted on 4/10/06 at 07:24 AM |
Id fit one but Id need to buy a sligthly larger engine crane ?? ill stick to the V8
NS Dev
posted on 4/10/06 at 08:17 AM |
couldn't you pay for the crane with the fuel saving over the v8??
smart51
posted on 4/10/06 at 08:55 AM |
You might need a bit of a bonnet scoop as well.
tks
posted on 4/10/06 at 09:13 AM |
the only thing
wich you can calculate is how effeccient
or capable is a engine..
this is by talking about BHP / 1000cc
its like BHP / KG or BHP / 1000Kg..
sow a 3,5litlres wich produces 320BHP
will give less results as a 1000xx bike engine with 150BHP and thats just true!
because with 3,5 times the displacement is should generate 3,5times the bhp´s...
Tks
NS Dev
posted on 4/10/06 at 09:29 AM |
Again not true!
Yes, that will prove how much bhp per litre an engine will generate, but just because my 0.49cc model plane engine generates huge bhp/1000cc
doesn't mean it will be any good at propelling my locost!!!!!!!
As you go through all of these measurements, and in turn rule them out as measures of how they will make a car "go", you will see why I
picked the arbitrary measurement I did!!!
A high specific BHP engine on its own is no good
A high peak torque engine on its own is no good
A high revving engine on its own is no good
A high peak bhp engine on its own is no good
What I hoped to get over with the numbers game, and think I have done, is that it is the whole package that is needed to be "effective" in
powering a car.
In terms of winner for my little numbers game, sticking to naturally aspirated engines fitted to road legal cars, I am pretty sure I know what it is,
but can I find a spec anywhere on tinternet!!!!!......
If somebody can find a spec for an Opel-Cosworth 2.5 litre KF V6 then put it up on here (yes I know there is only one road car with one it it but
there you go!!!!).......................
I think you will be looking at over 45 for the (bhp x lbft) / cc equation!!!!!!!
posted on 4/10/06 at 10:11 AM |
Was justing looking through a list of power/torques I found at http://www.drivetorque.co.uk/cars/car_specs.htm and I was surprised that big V8's
that you'd expect to be in a relatively soft state of tune provide high numbers to Nats original engine "goodness" formula.
e.g. GM LS1 as found in Vauxhall Monarao, 329bhp, 344 lbft from a 5.7 litre engine gives 19.8.
Best I can find so far is the BMW M3 CSL engine, 360bhp, 274lbft from 3246cc giving a score of 30.4. Not quite "locost" though.
[Edited on 4/10/06 by MikeRJ]
smart51
posted on 4/10/06 at 10:25 AM |
quote: Originally posted by NS Dev
In terms of winner for my little numbers game... Opel-Cosworth 2.5 litre KF V6 ...
The sulzer diesel beats 45!
NS Dev
Using purely "vague recollection" values for the KF V6, I think peak power was around 415hp and peak torque was around 290lbft, which from
2500cc gives 48!!! Engine also has excellent power density, at around 90kg all up weight!!!
The road legal car it was fitted to was Andy Burton's "306R4" rally car.
The Sulzer diesel, excellent as it is, won't go in a road car!! LOL
[Edited on 4/10/06 by NS Dev]
Agriv8
posted on 4/10/06 at 11:13 AM |
Oh it won't fit even if I shave a bit of the sump and fit a foam aftermarket air filter ? thats a shame
New forum ? Locost Freight Ship I assume that what the engine is designed for being 102 RPM and all that tourque.
ned
posted on 4/10/06 at 11:24 AM |
just thinking my daily driver diesel:
140*259/1896= 19.12
beware, I've got yellow skin
NS Dev
posted on 5/10/06 at 08:13 AM |
them there turbos blow the plot away again!!!
smart51
posted on 5/10/06 at 09:03 AM |
How about this one, a lombardini 686cc diesel
30 Lb ft, 17 BHP, 686cc = 0.74
mcerd1
posted on 5/10/06 at 09:28 AM |
pug 106 (TU9 carb)
(45 x 72)/ 954 = 3.4
with the factory data -> add real life and 14 years and it's probibly more like 35x60/954 = 2.2
NS Dev
posted on 5/10/06 at 09:37 AM |
bloody hell!!!!
Lets have a "find the lowest" contest then!!
Might be amusing.
I don't know the cc of a typical briggs and stratton 3.5hp mower engine but they have got to be contenders!
What about a harley???
Coose
posted on 5/10/06 at 09:45 AM |
Ok then, 'er indoors' Mk1 '66 Mini: -
24(bhp) x 59 (lb.ft) / 998 = 1.42!
Spin 'er off Well...
smart51
posted on 5/10/06 at 10:13 AM |
piaggio air cooled 50cc 4 stroke moped engine
2.9 lb ft, 4.4 BHP, 49.9cc = 0.255
ned
posted on 5/10/06 at 10:15 AM |
bloody rubbish bike engines LOL
