roadrunner
| posted on 9/4/07 at 06:55 PM |
All jacko's hard work painted up .
  engine + cradle (not fitted)
roadrunner
| posted on 9/4/07 at 06:56 PM |
And here it is , fully fitted.
  fitted engine
[Edited on 9/4/07 by roadrunner]
| posted on 9/4/07 at 08:08 PM |
ive fitted one of those and never realised there were two more mounts at the bottom of the gearbox Might use them this time!
Toady1
| posted on 9/4/07 at 08:10 PM |
bloody hell! your beating me big time!!!!!
tim windmill
| posted on 10/4/07 at 08:45 AM |
that looks very nice Brad, next job the wiring?
roadrunner
| posted on 12/4/07 at 07:52 PM |
  R1 endcan
roadrunner
| posted on 12/4/07 at 08:05 PM |
MMMMMmmm , nice and shiney.
  new header tank
£45 ebay
roadrunner
| posted on 14/4/07 at 09:58 PM |
Got most of the wiring sorted now, just need a cdi unit to complete, i had to splice the stop/start switch, the clutch switch and the stand switch,
i've connected the white ign wire from the car loom to the red and black wire at the starter relay in the bike loom, need to sort out the speed
sensor , as i have no connection for that, just hope it all works when i try it in a week or two.
roadrunner
| posted on 15/4/07 at 08:17 PM |
All wiring and plumbing done now, still waiting for CDI unit.
I have been doing a search for gear linkages, and i think i will use 8mm threaded bar, should be easy to use and adjust.
Just need my other parts from MK , pick them up next weekend, with any luck.
Wont be long now.
[Edited on 15/4/07 by roadrunner]
| posted on 15/4/07 at 08:46 PM |
what have you sorted for the cdi? There was one on ebay recently, should end soon. I bought all the other crap off him! If you are really stuck i
have a cdi for mine, would need replacing though
My gearlever once failed beside a welded thread (not my handywork), so dont weld on the threads!
roadrunner
| posted on 15/4/07 at 08:54 PM |
I am watching one at the moment.
roadrunner
| posted on 18/4/07 at 09:42 PM |
Got my CDI unit sorted now, just waiting for delivery, gear linkage is a pain in the arse to work out, but once you've started, it soon falls
into place,
  gear linkage
It just bolts directly below the drivers side engine bracket, very simple ,and locost, but should work a treat.
| posted on 18/4/07 at 09:55 PM |
dont suppose you know the diameter of the splines on the gearbox do you?! I need to get myself a lever!
Paul TigerB6
| posted on 18/4/07 at 11:25 PM |
should be able to get a lever off ebay - paid about £4 i think for one for the ZX9R
mad dad
| posted on 19/4/07 at 09:29 PM |
Lookin good...you're not hanging about are you
roadrunner
| posted on 20/4/07 at 11:28 AM |
It would be done quicker, if i was'nt waiting for my eaxhaust manifold.
jacko
| posted on 22/4/07 at 08:45 PM |
Hi Brad hows it going iv had no computer for a week or so is it running yet ?
Graham
roadrunner
| posted on 29/4/07 at 09:37 PM |
Got everything finished now , bar the exhaust, it also looks like i've spliced the clutch switch wrong, hence me not having a spark at the
moment, i have spliced the two wires at the connector together, rather than the green/yellow to earth, i also made the cdi unit very hot, hope
that's not knackerd, we will find out soon enough.
If i go to Stoneleigh now ,it will be in the tin top.
roadrunner
| posted on 13/5/07 at 06:48 PM |
Got the last remaining parts from MK on friday, wont be long now.
roadrunner
| posted on 16/6/07 at 07:52 PM |
All finished and ready for Newark.
  pass side
Well chuffed.
roadrunner
| posted on 16/6/07 at 07:53 PM |
  new bonnet
roadrunner
  back
roadrunner
| posted on 16/6/07 at 07:54 PM |
  front pass side
roadrunner
| posted on 16/6/07 at 07:55 PM |
  drivers side
mad dad
| posted on 19/6/07 at 10:55 AM |
looks really nice so how did it go at Newark, silly question but do you prefer the bec now you have done it?? do you find the 17" wheels ok i
can't make my mind up whether to use 15's or 17's....
