big_wasa
posted on 13/8/13 at 07:11 PM |
Erm, I am sure I can sort some thing out.
A how to write up is a fare bit of work just for one or two.
Lingy
posted on 24/3/14 at 08:18 PM |
So can you do us a loom mate?
Case_Sensitive
posted on 6/5/16 at 10:55 AM |
This thread is long since zombied, but, inspired by Big_wasa, I'm doing a full strip of my ST170 loom, and rebuild it 'lighter'.
I was fortunate enough to start from a full MOT'd car, so I shouldn't be missing anything. I did sell the console with the clock and
hence my immobiliser-armed LED, but that should be a 50c replacement.
All Ford interconnects (unions that join wire to another wire, or go through bulkheads etc) have been cut out, leaving only connector to connector
links).
I'm doing up a big spreadsheet of every connector I need (I'll caveat this;
I'mbuilding a MEV Rocket, so no doors, alarm, AC, power steering etc), what
colour the stock wires are, and what pin on what connector/fuse/relay they go to. There's a tab for the Fuses and relays too.
Initially I'm doing track-only, so v1 won't have lights, horn etc.
Should be finished the theory part in about a week or two, and I've wired up about 20% of the connectors for real in the garage. Probably a
couple of months till turn over, it's a one-day-a-weekend project.
Absolutely wouldn't be possible (for me) without the Ford wiring diagram, and I use the connector and component references from it throughout.
Probably going to need it to use my guide.
[Edited on 6/5/16 by Case_Sensitive]
http://mevowners.proboards.com/thread/3946/rocket-st159
Case_Sensitive
posted on 18/5/16 at 11:44 AM |
Progress so far. Again, this is for an ST170 engined kit-car, and presumes you have the original wiring loom, or want to use the same colours.
https://drive.google.com/file/d/0B-1teQkzjga4dTdBMVN4ZXRuNjg/view?usp=sharing
big_wasa
posted on 18/5/16 at 02:50 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=190440
Case_Sensitive
posted on 18/5/16 at 04:14 PM |
Yep, this thread is invaluable, and I was inspired by the video of yours mounted in a wooden crate; I made one for my own lump, which has been
converted into a welding table since the engine/gb were dropped into my Rocket.
There are a few bits I'm doing differently, some of the connector designations are for the standard Zetec rather than the ST170-specific ones
and a couple of things your first post leaves out that I'd include (like the VVT, Crankshaft pos.). If I can make it look alright, I'll
do diagrams of some circuits.
big_wasa
posted on 18/5/16 at 04:30 PM |
More information the better. Each one I do I get the info over a little better.( not my strong point) See the Zetec SE.
My next one is for a mid engine.
Coming soon Focus rs managed turbo Zetec.
ttbiker
posted on 18/5/16 at 04:47 PM |
Hi Wassa, I just recently got my ST170 MGB up and running it should be on the road in the next couple of weeks, I'll post some pics up when I
get chance..
Case_Sensitive
posted on 18/5/16 at 04:57 PM |
Brilliant! Is that a fuel tank or N2O?
My heart will likely ultimately take me back to aFord Racing Puma, and the Sigma / Zetec SE
big_wasa
posted on 18/5/16 at 06:51 PM |
get chance..
Look forward to seing them
big_wasa
posted on 18/5/16 at 06:54 PM |
Yeh it's a converted fire extinguisher for a fuel tank.
I love the simplicity of the Zetec e.
Vindicator666
posted on 18/5/16 at 10:31 PM |
only see page 5?
for some reason i can only see up to page 5, anyone else having the same issues?
ttbiker
posted on 24/8/16 at 08:56 AM |
get chance..
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2IMAG0497_zps1s7cgxo2.jpg
ttbiker
posted on 24/8/16 at 10:44 AM |
Here's the full car Wassa..
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=IMAG0493_zpsrqfdbgoc.jpg
[Edited on 24/8/16 by ttbiker]
big_wasa
posted on 24/8/16 at 02:55 PM |
Nice work so you got the inlet in OK.
ttbiker
posted on 24/8/16 at 04:37 PM |
Yes no problems, it's runs really well maybe looking at supercharging it next year
hairball29
posted on 28/9/17 at 04:05 PM |
Evap codes question
Hi, all
First time here and I really hope someone can help me with a nagging problem i have.
I live in the states and I have a Caterham with an '04 SVT motor and I need to get it through emissions here in Georgia. Emissions here
doesn't actually mean what comes out the exhaust, it means they plug a reader into the OBD port and fail it if any codes exist, whether or not
they're related to exhaust gas! It's strange, but i'm stuck with it.
My problem is that my car has codes p0453 and p1451 permanently in the system due to how the wiring and/or switches were modified for this car, but i
see from reading this thread that it's possible to install a resistor to perhaps tell the ECU (pin 56 perhaps?) that all is well with the tank
pressure and stop the codes reappearing.
The other requirement from the man is i have to have MIL on the dash. I can't see from the diagram which pin relates to the MIL. I think
it's pin 2 from what else I've read, but I wonder if anyone can help me figure the above out? If so, does this pin switch to ground or +
voltage when a code is present?
I've called mechanics and garages and most won't go near this car because it's weird. The car's also a pain to start, but
that's my next challenge for when I can get it roadworthy
thanks in advance
[Edited on 28/9/17 by hairball29]
jeanp
posted on 9/2/20 at 06:09 PM |
Hi everybody!
I posted few months ago some questions about restarting my ST 170 engine: Someone of this blog give me an advice, so I followed the Excel sheet on
this post and now, the engine run! Magic!!!
Well, now I've some questions about a pipe and 3 hoses: for the moment I just put plugs and scotch tape but if you can help me to find what to
do with, it 'll be great!
the problem is that I don't know how to do to put a picture on the post!!!
big_wasa
posted on 10/2/20 at 12:38 PM |
The "how to" thread gets more traffic and there for replies.
Really need a photo
jeanp
posted on 1/6/20 at 06:43 PM |
Hello!
I hope everybody is fine!
I restarted the engine in the car for the first time this afternoon
a little video:
https://studio.youtube.com/video/it3kjWm0zzs/edit
on the video it seems great, but in reality there is some problems...:
The engine idling run few minutes , but when acceletated, it stalls
After checking the fuses, I find the fuel pump relay fuse (15A) blown; So I replace a new one and I do the same and same result ; I tried third time
and again!!!
I don't understand!?!?
The second thing is my fuel pump: I find it very hot after 6 minutes running (the pump is a Sytec (Bosch type 044) 200 liters/hrs),and it's
close the fuel tank....not my best idea!
Can you give me some advice, or something to check, please?
Jean
Cobra289
posted on 1/6/20 at 06:50 PM |
video doesn't work. (the link is incorrect)
jeanp
posted on 1/6/20 at 08:06 PM |
sorry,
try with this
https://www.youtube.com/watch?v=it3kjWm0zzs
big_wasa
posted on 1/6/20 at 08:14 PM |
Take that gauze of the maf for a start. It upsets it for some reason.
big_wasa
posted on 1/6/20 at 08:16 PM |
That exhaust manifold will strangle it.
Cobra289
It looks like there is a problem with the filter (clogged) or the tank pressure system.
