Samuele
posted on 3/2/20 at 08:09 AM |
Is there anyone who can tell me exactly which starter I need?
If possible, I would like to install an High Torque starter motor.
I mount a Zetec Blacktop 2.0 engine
Hydraulic Pinto clutch with the parts listed below:
https://www.retroford.co.uk/product/zetec-lightweight-rwd-flywheel-3-9kg-z035/
https://www.burtonpower.com/raceline-alloy-wet-sump-pan-kit-ford-zetec-e-rwd-silver-top-fz655.html
https://www.burtonpower.com/bellhousing-rs2000-dual-lhd-rhd-bh3.html
Samuele
posted on 17/2/20 at 02:06 PM |
It has been a long time of inactivity on the work of the Fury, but something has ended anyway.
After trying in vain to get the Headlights covers, it was decided to do them by themselves.
After several tests, it finally worked and I made a few more for myself.
The headlights are 7 "and here too I didn't like the original solution very much.
Especially the original metal ring did not match well with the lighthouse, also the measures were too different.
so he made a new fiber ring that fits perfectly and hides bolts etc.
The Hood should soon be finished, too, with high Air Vents for the radiator.
The brackets for mounting the differential are finished and a test for the intake horns with a different shape is in progress.
The idea is to move the airbox down so as not to modify or cut the hood while maintaining the right volume of the airbox.
[img][/img]
Samuele
posted on 17/2/20 at 02:15 PM |
peter030371
posted on 18/2/20 at 10:48 AM |
Looking good
