mongrelwestie
posted on 9/11/08 at 07:26 PM |
drum brake question!
why is it whenever you fit new shoes or just take the old ones out fr a bit, you can never get the bloody drum back on and when you do it barely
turns!
RS2000 live axle ones in case you can help
twybrow
posted on 9/11/08 at 07:33 PM |
Grind off the ridge that will be worn in the edge of the drum - that will help get 'em on.
mongrelwestie
posted on 9/11/08 at 07:37 PM |
cheers, i can get them on but there just very tight once on
DIY Si
posted on 9/11/08 at 07:44 PM |
Are the adjusters wound all the way out?
Sun Tzu, The Art of War
mongrelwestie
posted on 9/11/08 at 07:45 PM |
you mean the little spindle wheel, yes?
posted on 9/11/08 at 07:50 PM |
Is the handbrake adjuster backed off? Is the self adjuster mechanism free and backed off? Is the handbrake linkage in the drum free? Is the wheel
cylinder siezed? Is the master cylinder push rod over adjusted? Is the drum distorted, especially if you clouted it with a hammer on the outer edge to
remove it? Just a few items to be going on with.
mongrelwestie
posted on 9/11/08 at 07:57 PM |
its not connected to anything! all new parts? i think its just a bastard
