Author: Subject: Breaking 2.0 DOHC Sierra
twinturbo
posted on 14/11/08 at 08:45 PM Reply With Quote
Breaking a sierra 2.0 DOHC
Good engine complete with loom and ECU.
BOX gone
Other bits and bobs..
TT
matt_claydon
posted on 14/11/08 at 08:52 PM Reply With Quote
Is it drums at the back? If so could you measure the driveshaft diameter please? I'm after the not-very-common 28mm ones (normal is 24mm for drums). I think they were XR4i only but it's worth a try!
Many thanks...
[Edited on 14/11/08 by matt_claydon]
twinturbo
posted on 14/11/08 at 08:55 PM Reply With Quote
Not 28mm and they will have to stay on anyway as the car needs to roll to the scrappy.
Soz..
Rob
dubstar_04
posted on 15/11/08 at 09:08 AM Reply With Quote
u2u sent
M$RK_VXRD
posted on 16/11/08 at 10:07 PM Reply With Quote
im in need of a steering colum with the bracket to hold it up, the coweling and ignition with key!
do you still have it if so how much are you wanting for it?
also do you still have the engine if so how much is that going for?
p.s. i only need the section of the steering colum that slides over the steering rod!
thanx regards mark
twinturbo
posted on 16/11/08 at 10:10 PM Reply With Quote
engine with loom and all anciliaries ecu.. ~£70
column.. not sure I have it
