ahb
posted on 15/11/08 at 07:52 AM |
Fog light switch
I've wired up my rear fog light to the redundant ford wiper switch and included a fog warning lamp on the dash.
Does anyone know if the switch needs to be marked "FOG" for sva. Should this pass?
Al.
[Edited on 15/11/08 by ahb]
Hello!
marmot0
posted on 15/11/08 at 08:22 AM |
think you only need labels for the new IVA
adithorp
posted on 15/11/08 at 09:06 AM |
There's no requirement for switches to be labled at SVA. It will be needed when IVA comes in.
adrian
http://jpsc.org.uk/forum/
Dickyboy
posted on 15/11/08 at 09:19 AM |
I failed the MOT after rebuilding the Scamp cos the washer and fog lamp switches weren't labelled
ahb
posted on 15/11/08 at 10:45 AM |
Thanks all.
Hello!
Danozeman
posted on 15/11/08 at 01:56 PM |
AS said above i dont think youl pass an MOT with no labels. Partly cos the tester wont know where it is.
Dan
mad-butcher
posted on 15/11/08 at 05:11 PM |
just a thought but isn't it a requirement that the fog only works when the headlights are on.
Tony
iank
posted on 15/11/08 at 06:25 PM |
Tony
Not mentioned in the SVA manual (it does say it can't be brake pedal operated (!))
MOT says it can be operated even when lights or ignition are off.
http://www.motuk.co.uk/manual_110.htm
Anonymous
mad-butcher
posted on 15/11/08 at 06:38 PM |
very confusing because technically it's an offence to drive with high intensities on when the weather conditions do not necesitate use of above,
and we all know what a pain in the arse it is when driving of a night behind some morron who has left them on from the day before.
tony
