Johneturbo
posted on 25/11/08 at 08:28 PM |
maplins Thatcham immobilser
http://www.maplin.co.uk/module.aspx?moduleno=219349
anyone fitted one of these? seems pretty good and cracking price
or should i pay a bit more and go for a toad from the bay!?
Richard Quinn
posted on 25/11/08 at 08:31 PM |
That looks really good for the money. I've got a Toad which was considerably more expensive. I wouldn't think that either are
"Thatcham Approved" unless fitted professionally. The Toad definitely isn't
DavidW
posted on 25/11/08 at 08:48 PM |
That looks like really good value.
It says it will search for the transponder for 30 seconds after door open. Assuming it is supposed to work off a cabin light circuit, do you think it
would work if you wired to the accessory position on the ignition key?
Johneturbo
posted on 25/11/08 at 08:49 PM |
I'll fit it myself it's for peace of mind really
as i didn't have one on the last car, only a master switch and releasable steering wheel
the £14.98 i don't mind wasting, it's the wiring it all up to find it really is only worth £14.98![](/images//smilies/bigsmile.gif)
Johneturbo
posted on 25/11/08 at 08:54 PM |
Hmmm not sure about the searching after the door is open.
i think the toad version also has that from what i've read on here you just leave it unwired
so hopefuly it's also triggered from the ignition
just had a think, if say your cabin light circuits fuse was to blow it must still un-arm from the ignition
[Edited on 25/11/08 by Johneturbo]
DavidW
posted on 25/11/08 at 09:03 PM |
That makes sense.
Ben_Copeland
posted on 25/11/08 at 09:13 PM |
It'll be wired to the door switch that controls the light. But its a earth switch so if the fuse blows on the interior light the switch still
switches and still works for the alarm....
Not so helpful on a car with no doors i'm afraid.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
MikeR
posted on 25/11/08 at 09:18 PM |
Nothing to stop you from wiring to the key switch tho - or perhaps having a start button in the car or something. Perhaps you could have a pressure
sensor on the seat!
bobster
posted on 25/11/08 at 11:29 PM |
i've wired mine into the battery master switch. on turing the switch the immobiliser roams for around 30secs. not the greatest range on the
sensor loop though and key has to be right in the side of my pocket to be picked up. just a bit worried as now not using a key i have no steering lock
so car could get towed away.
iiyama
posted on 26/11/08 at 07:40 AM |
Ive got one of these fitted:-
http://cgi.ebay.co.uk/MOTORBIKE-MOTORCYCLE-BIKE-ALARM-IMMOBILISER-2008_W0QQitemZ190255164070QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item1902551640
70&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1308
Excellent piece of kit and the service and help from them is fantastic.
I havent got a steering lock either and hadnt considered it being towed! Ill have to get a crook lock or summit.....
If its broke, fix it. If it aint broke, take it apart and find out how it works!
stuart_g
posted on 1/12/08 at 02:55 PM |
I got a Meta 357V2 off ebay for £100 brand new, that's less than half what the bike shops sell them for. Cat1 insurance friendly and for a
motorcycle so doesn't have all the unwanted features of a car alarm. Works superb and is very loud. Being CAT 1 it has all black wires so if
some scroat got at the wiring as it can be a bit vulnerable in a 7 type car it is not clear which wire does what.
I know £100 is not very locost but I want to protect my investment as much as possible and also wanted something reliable. It would really wind me up
if I got stuck somewhere because a cheapo immobiliser went faulty. I know even the most expensive electrical items can go faulty but at least it may
lessen the chances.
just my 2p worth.
adithorp
posted on 2/12/08 at 04:30 PM |
Don't worry about the door switch, just leave the wire off. They "search" for the fob signal for 30 seconds or so after either the
door opens or the ignition switches on. Thats how most work anyway.
adrian
http://jpsc.org.uk/forum/
chrsgrain
posted on 2/12/08 at 05:10 PM |
^^^^ like what he said - I left that wire unattached and it worked fine.
Chris
Johneturbo
posted on 27/12/08 at 08:58 PM |
Just thought i'd update on this.
i fitted the maplins imobi and you're right the door switch isn't needed, it will search from the ignition being turned on.
all the trace wires are black just like any thatcham imobi.
hopefuly it won't let me down like most other stuff i've bought from maplins Hmmm!
DavidW
posted on 2/1/09 at 06:18 PM |
Thanks for the update, I've ordered one too.
DavidW
posted on 6/1/09 at 11:06 PM |
My Maplins immobiliser arrived today.
All the wires are black.
It might be a stupid question, but did you just use a multimeter to work out what connects to what?
RoadkillUK
posted on 7/1/09 at 10:55 AM |
Have another look David, I believe they are numbered near the ends
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
DavidW
posted on 9/1/09 at 10:15 PM |
Thanks, you were right.
