blakep82
posted on 26/11/08 at 07:46 PM |
how is my crank pully held in place?
ecotec X20XEV, is the crank pulley held on with a key shaft? tapered? or any other method?
would welding with the pulley still on the crank be a bad idea? i think it would be.
not needing a big weld, just 8, say 1cm long each, plenty of time between welds to stop it heating up too much
________________________
philw
posted on 26/11/08 at 08:00 PM |
It's held with a woodruff key, just do the bolt up kin tight
Must try harder
blakep82
posted on 26/11/08 at 08:24 PM |
cool
impact gun ok to take it off with?
speedyxjs
I would say welding it on would be a bad idea. Im not sure how much effect it would have if it was imbalanced
Mark G
posted on 26/11/08 at 08:28 PM |
cool
Yep.
If you weld it on you'd really struggle if you wanted to take the cam belt off.
philw
posted on 26/11/08 at 08:29 PM |
cool
Sure is, don't lose the key or the washer
Must try harder
philw
posted on 26/11/08 at 08:31 PM |
Not only that you will f/up the front crank seal, plus not sure if the alloy oil pump housing would like the heat.
Must try harder
speedyxjs
posted on 26/11/08 at 08:45 PM |
I think we read it wrong. He asked
Woops
Danozeman
posted on 26/11/08 at 08:51 PM |
What are you welding? Are you planning to weld something to the pulley? That would make it very unbalanced??
Dan
TOO BADD
posted on 26/11/08 at 09:11 PM |
Crank Bolt torque setting.... 250 nm !! 2nd stage 40-50 deg. Strong arm stuff
blakep82
posted on 26/11/08 at 09:27 PM |
just thinking trigger wheels...
i'm not welding the pulley to the crank!
philw
posted on 26/11/08 at 09:35 PM |
Oh yeah, just re-read op, duh it's been a long day, why can't you use the standard VX system?
Must try harder
blakep82
posted on 26/11/08 at 09:40 PM |
I'm using megajolt. the vx system seems to use a cam sensor. don't think that agrees with megajolt.
and i've got carbs. so i think the vx system is spark and injection, so i don't think it would have worked.
whats those 4 little torx head bolts in the pulley? would i be easier taking the pulley off with them instead?
bigrich
posted on 26/11/08 at 10:46 PM |
4 torx bolts removes the pulley the centre bolt releases the crank gear for the cambelt.
blakep82
posted on 26/11/08 at 11:01 PM |
cool, easier to undo the 4 torx bolts then
cheers guys!
mediabloke
posted on 27/11/08 at 12:03 AM |
Gotta say it - that'll look heaps better than my install - the 1.6 just uses the single bolt to retain the sprocket & pulley, so the only
option was to bolt it to the front.
Wish I'd looked out for a 2l sprocket & pulley. If anyone's got a set, give me a yell... ![](/images//smilies/bigsmile.gif) ![](/images//smilies/wink.gif)
posted on 27/11/08 at 11:36 AM |
drill small holes and use roll pins? or even pu the trigger wheel on?
blakep82
posted on 27/11/08 at 06:31 PM |
PU?! really? does that work? would be a good call if it does!
where can i buy PU locally? i don't want to buy a cartridge of it on the net and pay for delivey and stuff. i'd like to just go in a shop
and buy some, but where would i get it, and whats it called?
I was just going by the instructions on the megajolt/autosport labs site, where they show them welded on
[Edited on 27/11/08 by blakep82]
